SC10 4x4 Thread
Hi Guys,
I need your help. I bought a new SC10 4X4 FT a while back. I have one race day on it. During practice on what would be its second race day it started to click. Reading on here I learned to shim the diffs. Now I could not find any instructions on “How” to shim the diffs. So I took them apart and I shimmed the four small gears so they were forced closer together. This seemed to increase the bit of the gears. They still felt free. So put everything back together. And after a few battery packs started to click again. I know it is not the belt and it is coming from the front diff. Now I am running 7K in the front 5K in the back for diff fluid. I was told that is what works at the track I run at. Could the 7K be to light? The diff gears do not look worn or damaged. But I have not been racing this truck because I do not want to damage them. Other than that when I drive the truck it feels great. I run my front clicker locked, and my slipper is set right.
Please help.
Please help.
Welcome Brian
The spider gears can appear to look ok but still need replacement .
Use the new shims included with the rebuild kit.Instructions include where to shim.
Tip
Donot use the shims on the outdrives outside the gear case.
Diff oil seems ok, most use 30k in front & 7k in rear.
Tip
Welcome Brian
Tip
Tip
I get to race my PINK today !!!!
Looking forward to the mass fun ...
Using the Lite set-up , it is performing great for me on our present layout ...
If your using the new thicker shims (0.5mm) on the inside you want to leave those (the ones on the out drives) off, other wise it will bind up the diff. The thicker shims on the inside push the large sun gear into the smaller spider gears for a tighter fit, and to reduce the chance of stripping the diff gears.
I am running both shims since I got the truck in 2011. They didn't seem tight when I assembled them initially. I have rebuilt the diffs a few times to put fresh grease(by the way Marcus recommended it over oil and I have to say it turns to oil after a while but haven't had a leak yet, Kyosho grease is awesome)and the gears were fine. I had a clicking noise and went through the car and found the front pulley bearing went bad (my mistake, I put the pulley on backwards), haven't heard the clicking since. But there are a few guys I know complain of it, so that's why I am commenting on it to further understand. My diffs have all the shims and work, wonder why the problem....when you guys take the outer shim(the shim outside the diff-case let's just call it that) off, do you have any end play on the out drive?
Hoosier
Reason we find many different shim combinations being used is all due to the tolerances in the gears & gear cases .
No extra end play from removing the outside drive shim when using the thicker .05 shim .
The real benefit in using the thicker .05 shim is its strength .
The thinner .02 shim under the sun gears would "cone" or bend allowing for extra slop & poor sealing for the oil .
The new gear cases steel bushing wear much better.
The diff performance has really improved with fewer oil or grease leaks now...
Here's she is right after tonight's race...
PINK Truck performed awesome tonight , O-yeah !!!!
Yes no tunnels ...
Lighter , less roll from the weight up high ...
Even the chassis stiffener is lowered 4 mm .
Dust is no issue on indoor clay really,
so ditch the covers
Note the slammed servo , a little lower for improved COG
Motor runs cooler with out the gear cover >>bonus
That's 3 x 7 gram on each side of servo , I also have 2 x 7gram next to motor pinion on chassis to help off set the 550 & ESC weight .
With the shorty you can run lower then normal giving extra performance in the turns .
Been working on the past 2 years , testing & experimenting .
Not all is my idea's , I used others as well my own .
so ditch the covers
5Likes
