SC10 4x4 Thread
i was running a reedy 550 and the temps were easily 170-180 with out fan.so i put in the fan thats in my last pic.
im running a 1410 castle motor now and with fan that was getting around 140.
my fan cage broke and i have no other fan except one thats rated at 5v and smaller then the muchmore one so i was gonna try to run with out one.
i admit, iam a temp freak.
no truck rolls very smooth
14/62 with the reedy (rtr reedy 550 motor)
i went out today with the 1410 motor, mmp with 10* of timing and no fan. i was geared at 15/62 and after 7 mins of hard running max temp was 163. i have an on board gauge so i can record the highest temp the motor gets. i also have the sensor at the back of the motor where you are gonna see the hottest spot.
also running a crc 40c 5300 lipo.
esc was at 125.
im gonna go down to a 14 and check temps again.
this system is new to me and im just getting the bugs worked out before we set out for the nats next weekend.
WC. The bottom end is all I can handle with the 12/62 gearing, My truck launches out of the corners. Especially with the Exoteck front locker. What it seems I'm down on is the last 30% of the straight. Not that anyone is blowing past me, Just seems as though I hit an acceleration "plateau" I guess you could say. Running no motor timing and 10 Deg through the ESC. Maybe I'm just looking for more without wanting to "Pay" for it. IE timing and boost.??
esc was at 125.
esc was at 125.
15/62 should be good i run a 4600 tekin at 14/62 and it comes off after a foll battery in the 160 to 170 rang with my rx8 or my mamba max but the mamba max will hit 200 ez with out a fan 13 tooth works good to but to much wheel spin
5Likes
