Like Tree5Likes
SC10 4x4 Thread
Old 07-27-2012 | 03:51 PM
  #27256
itchy b's Avatar
Originally Posted by SOuthernFRIED
lol.. I never used the bird cages. Mine are solid bullets as well..
I prefer the 1/4cut solids to the bird cages too
Much more contact area with the solids.
They have to work better
itchy b is offline
Old 07-27-2012 | 03:53 PM
  #27257
Suspended
Got mine from a member on here today! 1st run with it.
http://www.youtube.com/watch?feature...&v=0EtSd5LhWEw
RC-1 is offline
Old 07-27-2012 | 03:57 PM
  #27258
Wildcat1971's Avatar
Originally Posted by itchy b
I currently have a redline SC4x 4.5t motor in my truck.
Wondering if anyone has run these and what they think of their performance.
Need to get an esc for it as the one it came with is a sensorless esc and the motor is a sensored one.
Looking at the Hobbywing XERUN SCT-PRO Sensored ESC.
Ant thoughts on how the SC4X will work with this ESC?
I use that motor. I am running 14/62 gearing and it runs about 145 with my esc. It is a good motor. As far as the esc well. I am using an lt4 but I wont recommend it nor will I discuss why. I would look at the 150 amp dualsky. They seem good. The mmp is good if you dont use a savox or any other high amp esc. Stay away from the tekin. Also dont to get into that argument
Wildcat1971 is offline
Old 07-27-2012 | 04:02 PM
  #27259
Evil Genius jr.'s Avatar
Originally Posted by Wildcat1971
Lol. Did you puff those in your 4x4. 25c is to low. What motor were you using
Yes. I pufefd them in my 4x4.
I know but it is the only available gens ace and I wasn't waiting for turnigy.
Castle 1410.
Evil Genius jr. is offline
Old 07-27-2012 | 04:14 PM
  #27260
itchy b's Avatar
Going to use my ACE 14.5kg aluminium case servo so that shouldnt be an issue
Tekin is out of my price range so staying away is not hard
Will check out the gearing on the truck atm.
So you not a fan of the 120 HW for the SC?
Price is good if it does the job.
itchy b is offline
Old 07-27-2012 | 04:22 PM
  #27261
ryanpatrickgore's Avatar
rx8 is the boss right now, but one of those brushless hobbies esc's might be pretty decent for the price. i wouldnt count on epic support from hobbywing as they are chinese
ryanpatrickgore is offline
Old 07-27-2012 | 04:27 PM
  #27262
itchy b's Avatar
Here is the ESC the truck came with
http://www.modelflight.com.au/team_l...o_LOSB9557.htm
Works fine apparently but with a little cogging on take off as its unsensored
Price for an RX8 here is in the $260 mark
itchy b is offline
Old 07-27-2012 | 06:44 PM
  #27263
JEFFs SC10's Avatar
My v2 assembly is LOUD. Is anyone else's like this? I assembled per the instructions.
just found out I toasted another receiver.. gahh.
just rebuilt rear diff. put 5k in there, has almost none in there. no more clicky clicky noises.
JEFFs SC10 is offline
Old 07-27-2012 | 07:00 PM
  #27264
SOuthernFRIED's Avatar
My v2 is pretty quiet. You assemble with pins trailing balls?
SOuthernFRIED is offline
Old 07-27-2012 | 07:02 PM
  #27265
ilanstylz's Avatar
What are you doing to toast rx's????
ilanstylz is offline
Old 07-27-2012 | 07:14 PM
  #27266
ABN Hoosier's Avatar
I just ran my V2 for the first race this past Saturday. I am cleaning the car right now. I took off the gear cover and everything is fine. My was quiet as a mouse, except when it screamed down the front straight like a raped ape...
Has to be your mesh or maybe you have one of the blue plastic washers on backwards. My guess.
ABN Hoosier is offline
Old 07-27-2012 | 07:16 PM
  #27267
Sometimes a sudden noise in the drive train can be traced back to a worn pinion. I had a squeal in my 2wd after replacing a spur. Replaced the pinion and it was back to normal.
Old 07-27-2012 | 07:46 PM
  #27268
Smittydidit's Avatar
Default Taming the Beast!
Hello to all. After lurking on this forum for over a year now and reading with great intent on making my SC 10 4x4 fast and driveable, This is my first post. Having raced R/C cars now for 30+ years I had this little monster close but no cigar. After trying many things that have been written on this forum,Some helped,Some did not. Biggest improvments,Chassis brace, 8MM mod, Spring and oil changes, Exotek front locker. My setup now is very neutral and the car can be driven on a multitude of surfaces with a tire change, Maybe a slight ride adjust and it's good to go. The degree of intensity you members here have put into making this truck work is awsome!. I know many who just could not make it work and bailed out. So to all who have R&D'd and posted the findings,Thank You! In the future I will start posting some of my own mods that have helped make my truck better.
Mark Smith
Smittydidit is offline
Old 07-27-2012 | 07:53 PM
  #27269
ilanstylz's Avatar
Mark Smith
Welcome to the sc10 4x4 thread, if you don't mind me asking where do you race at?
Old 07-27-2012 | 07:55 PM
  #27270
JEFFs SC10's Avatar
well found out it wasn't the v2, it was my motor, the front shaft bearing is gone and making the rotor spin all over the place.
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRr
