MTX 5
Old 05-02-2012 | 01:50 AM
  #2041
hi i am sure i read some were that you have to lift engen up //it rubs on chassi but i coud be wrong as usual//pack engen mount wetch might fix your prob
greg.dawn is offline
Old 05-02-2012 | 02:06 AM
  #2042
Arahawak's Avatar
Ok I will try that.. I will post pictures later maybe that help in getting some help.. Lol
Arahawak is offline
Old 05-02-2012 | 11:58 AM
  #2043
Perez's Avatar
Originally Posted by Arahawak
Has anybody tried mounting a Sirio Nemesis on the MTX5?
Need some advise from those who had.
I can't seem to clear the carb.. Am thinking the only way is to shave the tank in order for the carb to be fully open.
Any ideas?
I have a sirio XXX and it was a really tight fit as well. I ended up having to use my dremel and barely grind down a fin from the motor so I could turn the carb more to the right. I can take a picture when i get home if you need.
Perez is offline
Old 05-02-2012 | 10:46 PM
  #2044
Arahawak's Avatar
Yes please
Thanks in advance
Arahawak is offline
Old 05-03-2012 | 02:33 AM
  #2045
Bishop's Avatar
Can anyone tell me off the top of their head, or measure if you have one handy, the thickness of any of the Mugen clutch springs?, I'm trying to see if I can find an off the shelf spring from something with a thinner and hence softer spring.
Bishop is offline
Old 05-03-2012 | 08:39 AM
  #2046
Perez's Avatar
I know that the height of a new spring is 10.0 mm tall not sure about the actual width until i get home...
Perez is offline
Old 05-03-2012 | 10:34 PM
  #2047
Perez's Avatar
1.78mm
Perez is offline
Old 05-05-2012 | 05:33 AM
  #2048
hey guys,just wondering if any of you guys are running 300k front diffs?how is it different from the stock 200k?
tq23 is offline
Old 05-05-2012 | 05:37 AM
  #2049
Originally Posted by Seisick
Sure, the silver one works superb, but its more sensitive to adjustments compared to stock one (gold) consistent in long runs I'd say, the black one won't work, to stiff
hey seisick,i know this is kinda old..but how many mm did u turn the spring in?
tq23 is offline
Old 05-06-2012 | 01:28 PM
  #2050
Perez's Avatar
I figure you should just set it the same as the gold and see how it works. I also have been thinking about running the harder spring as the gold one just seems to change during the longer mains. It often feels like the clutch nut backs out but after measuring it doesn't move at all.
I usually run 9.3 mm from the end of the crank to the top of the clutch nut when the motor is at BDC at the same point. This is including the .5 mm spacer behind the flywheel and motor. So, I reckon a good starting point would be at 9.0 with the silver mugen clutch spring i'm guessing. I'll try it next weekend and let you know.
Perez is offline
Old 05-07-2012 | 03:39 AM
  #2051
hey thanks perez..im going to try it out too..awaiting ur feedback too..
tq23 is offline
Old 05-07-2012 | 08:06 AM
  #2052
Arahawak's Avatar
Hi Perez.. am hoping you can post some pictures for reference on fitting the XXX on the MTX5
Arahawak is offline
Old 05-08-2012 | 06:55 AM
  #2053
zafira2310's Avatar
just got my MTX5 last month and just finish break in my reds engine. for some how i don't get any problem with gear stripping. i set the sims carefully and engine position correctly. but the problem is not the sims or engine mount. its the break and chassis.
why break and chassis? coz if i adjust the break linkage to much it also pull the engine (the chassis move front and back) I think is causing the gear stripping.
zafira2310 is offline
Old 05-08-2012 | 12:17 PM
  #2054
Perez's Avatar
Sorry about that, my car is in pieces , ill do it asap
Perez is offline
Old 05-09-2012 | 01:16 AM
  #2055
hi as all ways people will tell you it is a user problem and we are all stupid it dose not happen the only way to fix is to brace we used 1/8 steering arm back to diff still get flex and when it bends again you just adjust it again
greg
after market chassi is no better than mugen one
