Old 05-06-2013, 06:34 PM   #2791
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Dustin View Post
Looking for a good easy to drive setup for a medium sized track with some open and some tight sections. Are stock 200K/50K diff oils too thick for tighter tracks? Looking for some things to try, car seems edgy with stock setup.
Try 150 front 60 rear
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 05-06-2013, 07:02 PM   #2792
bigbank66's Avatar
Ok.....so there is no 2.0 sway bar???
bigbank66 is offline   Reply With Quote
Old 05-06-2013, 08:35 PM   #2793
NITTO550's Avatar
Nope!
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 05-07-2013, 01:06 AM   #2794
i heard mugen made some for team drivers
baldy is offline   Reply With Quote
Old 05-07-2013, 06:47 AM   #2795
HI im missing the springs for the 2 speed clutch shoe just wondering can I use the springs set from the mtx4r as that's all I can find on ebay?
Sakuraszero is offline   Reply With Quote
Old 05-07-2013, 08:16 AM   #2796
shanwright's Avatar
Trader Rating: 25 (100%+)
Thumbs up Would not be real hard to make them
I guess it would not be real hard to make them.
Just need some piano wire the size you want the shape I very simple.
Steve H
shanwright is offline   Reply With Quote
Old 05-07-2013, 08:19 AM   #2797
shanwright's Avatar
Default I recon its worth a try
Try them how bad could it be.
There are other places to get them too.
Steve H
Old 05-07-2013, 03:29 PM   #2798
deviltires's Avatar
the 2.2 sway bar works fine just lay your shocks down a hole
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 05-07-2013, 09:31 PM   #2799
bigbank66's Avatar
I am a team driver an i havent seen one....maybe im not high enough on the list...but if anyone know of a 2.0 rather than a 2.2??? Because if there is softer bar i want one:-):-)
Old 05-07-2013, 09:42 PM   #2800
Scott B's Avatar
Trader Rating: 43 (100%+)
Henry, just buy an extra 2.2 and dremal the middle to make it softer...
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 05-11-2013, 04:09 AM   #2801
NITTO550's Avatar
Ok I have a question. On the steering knuckle there is that carbon fiber piece which has 2 mounting holes for the steering rod. One position is forward the other is back . What is this for,?
Rich D..
Old 05-12-2013, 11:17 PM   #2802
maver's Avatar
that position has 2 effects: affects the amount of steering and more amends' ackerman (to a lesser extent than on saving servo).
maver is offline   Reply With Quote
Old 05-14-2013, 05:36 PM   #2803
afm
afm's Avatar
To set up Ackermann
Ackermann controls the difference in steering arcs between the front inside and outside wheels. The inside wheel always has a tighter arc in any corner. The amount of grip provided by the tires, in relation to the steering arc and speed of the car, create an amount of measurement called a “slip angle” for each wheel.
For some tires you need a greater difference in slip angles between the inner and outer wheel and for some you need less.
The angle of the steering rods can be changed by moving the steering rods inner mount position on the servo saver, or outer mount position on the steering blocks.
1. Inner Ackermann Position (servo saver) – Changing the forward/rearward position of the servo saver has the greatest Ackermann effect
Position #1 (forward) – less Ackermann effect (steering rods more angled)
Position #2 (rearward) – the greatest Ackermann effect (steering rods straighter)
2. Outer Ackermann Position (steering blocks) – Changing positions on the steering blocks is used to fine tune the Ackermann effect
Position #1 (forward) – more Ackermann effect (steering rods straighter)
Position #2 (rearward) – less Ackermann effect (steering rods more angled)
NOTE: It is recommended to use more Ackermann effect in low-to-medium grip conditions and less Ackermann effect in medium-to-high grip conditions.
AFM
afm is offline   Reply With Quote
Old 05-14-2013, 09:24 PM   #2804
NITTO550's Avatar
Thank you Maver and AFM. Great information!
Rich D..
Old 05-16-2013, 02:57 AM   #2805
doctormtx5's Avatar
mtx4 bumper assembly on the rear of the mtx5 chassis for protection\guard for the rear of the mtx5 car.
http://www.youtube.com/user/doctormtx5
doctormtx5 is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 – Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
