Old 05-14-2012, 08:58 PM   #2071
shanwright's Avatar
Trader Rating: 25 (100%+)
Smile
Originally Posted by Perez View Post
Hey Maver,
What is the part number of the Motonica brakes? Did you glue them on to old brake pads or modify it to fit?
thanks
steve
Hey That was my next question
Steve H
shanwright is offline   Reply With Quote
Old 05-15-2012, 02:17 AM   #2072
maver's Avatar
Steve H
ok.
I did so ':
removed the old brake linings by boiling the pills, then finished with sandpaper, then I glued the new two-component linings.
Code linings Motonica P81 M07110 .
regarding the long straights usually I add 1 to the sprocket tooth and take off the crown 1. but so 'doing the crown is broken. therefore the ideal ':
pinion 16 crown 52 for the first pinion 21 and crown 47 for the second.
so 'does not break and draw length ratios.
sorry my bad English.
maver is offline   Reply With Quote
Old 05-15-2012, 03:26 AM   #2073
hi no trouble with your english its better than my spelling was before i found spell check greg
greg.dawn is offline   Reply With Quote
Old 05-15-2012, 06:32 AM   #2074
mick8488's Avatar
Default MTX5
Hi Guys,
Finally found this great thread about the MTX5!
However, after reading a few pages of it so far, it seems like this gear stripping issue is a real problem (obviously, right?).
However, I can report that I haven't had any problems with my car so far. I run on a small track in Cairns (that's a small city in northern Australia for our international friends - great holiday spot), which is always dirty and chock full of rocks and other nasties, but no stripped gears. I only had a few issues with the clutch spacing (my own fault) and a bit of debris stuck in the top end carb needle causing flameouts. Now that I've sorted that out, she's singing a good tune down the front straight
One thing that might make my car an exception is the fact it's a 2012 edition MTX5, which I understand incorporated a few fixes into the design. However, I have also noticed a lot of chassis flex when engaging the throttle servo. The difference is that the whole engine and 2-speed clutch assembly move/flex as one unit, so the mesh I believe stays intact during running. I'll keep you posted on how I go, but maybe I got lucky, I'm not sure yet. On a related note, my pinion gear mesh is slightly offset, and pointed towards the spurs. This gave me the best mesh and tightest tolerance between both gears. I am running a 2010 Nova Plus-12 3sct (purple head), so the fit may be a bit different because it's an older engine. I'd be keen to hear from others about their experiences with mounting the engine.
Also, does anyone have any opinions on the Zeppin Racing CNC 3.2mm MTX5 Carbon Chassis? I'm considering one of these for future use, seeing as carbon fibre doesn't bend or tweak like aluminium. Heat dissipation could be an issue though.
And finally, any thoughts on the Font Solid Axle Set (Spring Steel) from A Plus. What diff setup are most guys using at the moment?
Cheers,
Mick
NOVAROSSI WORLD s.r.l.: RACE ONE OR CHASE ONE
mick8488 is offline   Reply With Quote
Old 05-15-2012, 07:44 AM   #2075
maver's Avatar
Originally Posted by mick8488 View Post
Hi Guys,
Cheers,
Mick
Hello.
I answer for my experience (I have the mtx5 from October 2011)
T2002 version should solve the problem of the rear differential gears with Teflon often broke, have changed the differentials above the shoulders and put the satellites in steel, so it has no relation to the crowns that break.
at Novarossi engine, I only tested models (keep-on, plus 12 and flash purple head) and I can say that if you make a connection without spaces and perfect online does not break the second gear, paying particular attention to the friction that has too few problems, in my opinion:
1: spring plate which must be free to rotate in the strain
2: distance strain bell minimum 0.5 mm.
3: Always new strain.
4: clutch shoes cut into the spine to give more 'movement and weighted to eliminate slippage and give more strength to push.
the carbon frame has been tested ..... advice not to mount it was a disaster.
regards
maver
Old 05-15-2012, 07:46 AM   #2076
Bishop's Avatar
Actually I have been keen for a long time to try a carbon chassis on a nitro car, for that main reason, being they usually stay true, in terms of heat, one of the guys who first started making carbon chassis's for nitro (somewhere on this forum), said the heat was a non issue, during development he claimed there was no change in engine running temps.
Only problem with carbon, is getting the weight up to current legal limit in most places, could be an issue, but you could speculate if weights come down, some makers could switch to carbon to bring down that weight, I know KM have a option carbon chassis for their car now.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 05-15-2012, 08:01 AM   #2077
Hi,
maybe can you make a pic. from your clutch shoes so I can see how I have to cut it?
I also use a nova engine and I havenīt stripped a gear yet.
SebO is offline   Reply With Quote
Old 05-15-2012, 10:41 AM   #2078
roadrage's Avatar
Trader Rating: 14 (100%+)
What websites does everyone use to get parts? Besides amain and rc mushroom
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 05-15-2012, 09:27 PM   #2079
mick8488's Avatar
Hello.
regards
maver
Hi Guys,
Thanks for the info. Maver, could you expand on your bad experience with the carbon chassis? Were the holes drilled incorrectly? Did it break? What brand was it? Zeppin?
Also, what front diff is everybody running? Would the spool from A Plus be the way to go?
I buy from a variety of stores (online and local), but I would definitely recommend Darren at Online Hobbies for all your Mugen parts. They are based in Sydney, but are always prompt with delivery no matter where you are. They also stock Contact tyres and Max Power engines. Been dealing with them for more than six years. Service is tops!
Cheers,
Michael
Old 05-15-2012, 10:04 PM   #2080
roadrage's Avatar
I can't seem to find a 16 tooth online? Any pointers would be great
Austin Wolfe
Old 05-16-2012, 12:25 AM   #2081
maver's Avatar
Originally Posted by SebO View Post
Hi,
sure.
as soon as I will show you photos.
Old 05-16-2012, 12:37 AM   #2082
maver's Avatar
Angry
this and 'a good question.
In fact you can not do because the mugen did not make the pinion 16.
having tried to stretch the second with 21/47 I broke the crown of the second gear, I have to go 20/48 for not having problems (?!)
I believe that one can not increase the difference of teeth from the current 5 to 6, worsens the situation, (53 +15 = 68) (48 +20 = 68) (20-5 = 5) (53-48 = 5) this is correct.
mugen does not understand why 'of the pinion 16.
Old 05-16-2012, 12:46 AM   #2083
maver's Avatar
Hi Guys,
Cheers,
Michael
the problem is the temperature ..... the crowns were jumping all the time, I used the chassis of zeppin.
I mount the original frame, I changed bearings (km) and pulleys (A-plus).
maver
Old 05-17-2012, 07:39 AM   #2084
mick8488's Avatar
Hey on another note, did anyone have to put extra spacer under the rear shocks in order to mount them properly on the MTX5. I found that if I didn't, the threaded screw to adjust ride height would hit up against the screw used to secure the rear upper arms.
Old 05-17-2012, 08:16 AM   #2085
maver's Avatar
it 's true. what 'happens only if the shock likely to last hole.
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 – Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
