MTX 5
#1292
too easy.
i could only imagine how incredibly punchy the clutch would be with a red shoe and an alluminium clutch bell!
#1293
one more thing, i strip 1 1st and 3 2nd gear yesterday and i finally found out cause by the too sharp pinion gear
problem gone after replace all spur/pinion gear.
love to drive this car
sorry, it's not a Benz, it's a TOYOTA CROWN from Japan.
#1294
i found out the reason today, a bad front bearing. i replace it to a MAX WC and this time ...
Glad you found the problem with your engine...
#1295
Thanks TomB....i was on a well prep track....it was crazy how the cap were able to come out the corners...i love what i have seen out of my mugen so far...Chippy its just a question an if u r a true racer you must know the caps clutch is a wanted part...
#1296
I will never use the Capricorn clutch on this car. Not saying that it´s not good. Just that there is no need.
Best regards
#1298
#1300
, ive only ran nova's and RB's and to b honest both engine's are very strong and hold tunes well, good you worked out your bearing issue
... keep me posted if you keep stripping gears, 4 in 1 day is alot
. btw your toyota looks like a benz 550, very nice toyota crown
#1301
The clutch has a big part in the massive acceleration though, but the driveline weight and efficiency also plays it's part.
At this moment Capricorn doesn't have a clutch which will fit the MTX-5.
#1302
very good
, i will attend the biggest event of the year here in HK on Nov 5/6 an i will race with my MRX/MTX 5, hope to have something to post back here
#1304
