MTX 5
Old 12-02-2011 | 05:30 PM
  #1441
Arahawak's Avatar
Originally Posted by kcrunchone
Ok thinking that my hiatus from the game may have to end soon. I have a few questions since I have tons of MTX4 parts
Are there any parts that can be used once I go for the MTX5???
Just feeling out opinions of the new car as well, thanks in advance...
Only the belts.
Arahawak is offline
Old 12-03-2011 | 12:36 AM
  #1442
Smile Chassis flex
The mtx5 chassis flex and out of shape easily if you hit a curb or when the car went off track. Anyone know where to get thicker chassis plate for mtx5?
PeterL is offline
Old 12-03-2011 | 01:42 AM
  #1443
Default mtx5
belts engen scrues fuel we have same problem /greg
greg.dawn is offline
Old 12-03-2011 | 03:22 AM
  #1444
Hi
Chassis flex is THE most dificult part in car design. Mugen Seiki (by Robert Pietsch) designed it that way, so, i don´t see why chaging it... Really... More so if you realise thar this chassis won the european championship in it´s debut.
Best regards
Luís Cortez is offline
Old 12-03-2011 | 04:20 AM
  #1445
Bishop's Avatar
The 5 has a lot of flex, like what has been said it was designed that way, it's the complete opposite of say the Capricorn, which is built like a brick, different schools of thought, both will work if you work with it, and not against it.
Bishop is offline
Old 12-03-2011 | 03:52 PM
  #1446
Default mtx5
flex is great but how mutch is 2 mutch grandsons car is 4 race meats old and now has about3/4 mill bend in plate and no big crashes but still goes great so he tels me had a look at lars new cap and you could not bend it if you tried
Old 12-04-2011 | 04:07 AM
  #1447
Chickentrader's Avatar
I think that's what Kerry is referring to, he was quite taken by surprise about how stiff it is. It's as stiff as a brick; and some other MTX5 drivers today were also amazed about the difference between the two.
Where were you today? We were waiting for you.
Kindest regards,
Lars.
Chickentrader is offline
Old 12-04-2011 | 06:25 AM
  #1448
Seisick's Avatar
Mugen will be releasing optional chasis brace in the coming weeks!
So for those who don't want too much flex therell be an option
Seisick is offline
Old 12-04-2011 | 07:21 AM
  #1449
Bishop's Avatar
I'm both surprised and yet not surprised at the same time, many were always going to see the flex as a flaw, or have issues with it, so really the car could work just fine but people would still want to brace it, like some have already done.
You only have to hope Mugen come up with a neat looking solution, and not an ugly tack on to a very good looking chassis.
Bishop is offline
Old 12-04-2011 | 01:50 PM
  #1450
Default problem
Hi I have a problem with the strap of the front stabilizer bar, rubs me the universal joint set, which measure to use, the manual recommends 26mm
manchu is offline
Old 12-04-2011 | 02:45 PM
  #1451
Default Using other clutches on the MTX5
Hi All
Can someone confirm that you can use other clutches (Sirio, Capricorn etc...) on the MTX 5.
I only ask as the MTX 5 clutch does look rather long ???
Yeah Right! is offline
Old 12-05-2011 | 07:49 AM
  #1452
Seisick's Avatar
as long as both sides measure the same i see no problem using 27 or 28mm, it also depends on the amount of downstops you are using, the less downstops the closer
Seisick is offline
Old 12-05-2011 | 05:11 PM
  #1453
Smile
Mtx 5 option parts
Pm me for the link.
All parts from japan. Can't post link here.
PeterL is offline
Old 12-05-2011 | 05:26 PM
  #1454
sent pm
baldy is offline
Old 12-05-2011 | 05:56 PM
  #1455
Bishop's Avatar
Run them longer, that is what I did, they just touch at kit spec.
Originally Posted by Yeah Right!
Hi All
Not at this stage, not only in the clutch bell long, but the spur gears are set a fair way out compared to the old 4 and other cars, there is likely a reason they did this, not sure why.
My guess in companies like Cap may bring out a clutch bell to suit the 5 soonish, maybe.
Bishop is offline
