MTX 5
#2042
#2043
I have a sirio XXX and it was a really tight fit as well. I ended up having to use my dremel and barely grind down a fin from the motor so I could turn the carb more to the right. I can take a picture when i get home if you need.
#2044
#2045
Can anyone tell me off the top of their head, or measure if you have one handy, the thickness of any of the Mugen clutch springs?, I'm trying to see if I can find an off the shelf spring from something with a thinner and hence softer spring.
#2046
I know that the height of a new spring is 10.0 mm tall not sure about the actual width until i get home...
#2047
#2049
#2050
I usually run 9.3 mm from the end of the crank to the top of the clutch nut when the motor is at BDC at the same point. This is including the .5 mm spacer behind the flywheel and motor. So, I reckon a good starting point would be at 9.0 with the silver mugen clutch spring i'm guessing. I'll try it next weekend and let you know.
#2052
Hi Perez.. am hoping you can post some pictures for reference on fitting the XXX on the MTX5
#2053
just got my MTX5 last month and just finish break in my reds engine. for some how i don't get any problem with gear stripping. i set the sims carefully and engine position correctly. but the problem is not the sims or engine mount. its the break and chassis.
why break and chassis? coz if i adjust the break linkage to much it also pull the engine (the chassis move front and back) I think is causing the gear stripping.
#2055
hi as all ways people will tell you it is a user problem and we are all stupid it dose not happen the only way to fix is to brace we used 1/8 steering arm back to diff still get flex and when it bends again you just adjust it again
greg
after market chassi is no better than mugen one
greg
