MTX 5
#2056
This is what I have done:
First I have lined up the spurs and pinions by simming out the flywheel.
Than I made a brace between the diff and radioplate (Carbon).
We have run about 70 rounds and till now no stripping 2e spur.
At this moment I can not upload pictures but will do that asap.
#2057
Most cars (who don`t have the stripping problem) have a fixed brace wich won`t allow sideway flex.
Just brainstorming though with you mugen lovers.
Hoping to get a fix for you guy`s so we can have fun racing in stead of annoyings
#2058
Hello All,
We tested the brace, we tested low brake, we tested smooth second shift, we exchanged the axle with complete gear boxes from one car to others cars, we tesetd different motors, we tested a complete new car (I am in a club with seven other MTX 5 drivers)... NO solution to the stripping of the second spur. We have broken more than Seventy 2nd spurs. And very often, after one or two laps only !!!
The ONLY solution (this one works, even if we are a lot to think the spurs material is the problem because too hard) is to follow Robert advice when he speaks about the alignment of the engine. If the engine is perfectly perpendicular to your chassis and that you have the minimum of play between second spur and second pinion, you have more chance to preserve your 2nd.
These last 3 weeks, we all follow this advice and we keep our spurs much more time.
Food for thought, friends.
#2059
not sure if this helps but as you can see grinding down one of the fins helped by being able to move the carb more to the right. I then hook up the linkage and move the carb back to the left until there was a small gap between the carb and tank.
#2060
Thank you! Will give it a try.
#2061
we have had little trouble with gears we think it was more worn pinions once the little square bit wears off we striped gears 2 only the brace is only to keep chassi straight it flexes from side to side but has limited flex when brakes are on grand son said it still handel's about same as with no brace is still a quick car a lot better than his old mtx4r he said but what do you believe from 15 old its new and 4 is old
greg
greg
#2062
Hello Greg,
With new pinions (because new cars) and new spurs, we broke the second spur about only one or two laps many times. With and without brace.
With brace, the car is too much slow, and understeers a lot.
Hope it can help.
Hope it can help.
#2063
Hi guy,
I was wondering if anyone has tried to see if there is any relationship between gear ratios and stripping. I was wondering if different ratios might give better meshing. Also check if the engine has moved on its mounts ie after setting the mesh, measure accurately from the main drive shaft to the thrust retainer on the clutch use digital calipers. And race!! If you strip a gear. measure again and see if the mount have moved. I have heard that after a major impact gears have stripped a few laps later. I wonder if the mount move on the chassis and the solution might be to sand off the anodizing on the underside of the engine mounts, anodizing is very slippery!
Food for thought guys.
Also check the mesh after every race.
#2064
good luck with the stripping guys, you can have all tips brace, shims, no play, play etc etc but just a little misalignment on the engine will do the trick and strip! all over in the entire rc community,
good luck
#2065
not sure but when using 0.6mm shims behind the flywheel cone on my picco engine, i had 2,25 turns in on the spring nut, i do like this since i only tie the nut whenever racing and after racing i loose the nut, it preserves the spring (btw i use metal nut from the mtx4, not the alum that came with the kit)
good luck
good luck
I thought it worked pretty well. Definitely shot out faster than the gold spring but would recommend using the silver on high traction tracks. As the track got greasier and traction decreased, the car's rear end started step out. But during the qualifier in the morning , it was pretty awesome.
I'm headed down the KO propo race in Los Angeles next weekend and will try it there as well. I just saw my qualifying heat and I'm there with Swauger, DJ Apoloro, Paolo M., Kimbrow, Burch, and a few others. It will be intense just driving next to those guys!
And, not a single stripped gear yesterday... I have only stripped one since i have started to run. It is definitely about alignment. If you have still have issues with your gears, have a local sponsored mugen driver help you set it up correctly.
#2066
Hi Guys,
I've tried both the pad compounds offerd by Mugen and even the soft pads will not pull the car up with a full lock. yes i know you don't want that, but if it can lock up i can always dial out the brake, and yes i know it's got a bit to do with the chassie flex too. But has anyone tired any thing super soft and grippy.
What else works?
The pads in the mtx are off the mrx and i wonder if we could go softer and look for more grip then is need on an 1/8 scale.
Steve H
What else works?
Steve H
#2068
hello all
I solved the problem so brake ':
I changed the brake lining pads of putting the Motonica (1mm thick).
now my mtx5, without modification, good brakes without applying too much brake, so doing I do not have excessive bending and brakes very well.
hello
maver (italy)
hello
maver (italy)
#2069
hello all
hello
maver (italy)
hello
maver (italy)
What is the part number of the Motonica brakes? Did you glue them on to old brake pads or modify it to fit?
thanks
steve
