Old 04-26-2012, 02:36 AM   #2026
blis's Avatar
Originally Posted by CanyonCarverR1 View Post
I know there's some great suggestions in this post. But I'll be damned if I can read it. Just a little sentence structure would really help you share your experience.
Meant with the utmost respect.
Awww man, that was classic!!! Must let everyone that might be wondering, Greg doesn't speak that way at all...
Anyway...
Our MTX5 pinion tips wore out. Our MTX4R tip would wear from a dirty track and wear pinions early. When using a new pinion, we replace the spur gears at the same time.
A smooth 2nd gear change is important. If 1st gear isn't long enough you get a harsh 2nd shift or you shift mid corner and you can strip both gears at the same time. To make sure gears are not rubbing together, separate them by using a spacer to move the bearing.
The thrust bearing retainer (black bit) was drilled off center on some of the kits that arrived in Queensland. Also check your engine mounts and ensure they are parallel and aligned and grease your out-drives, I think that is why ours seized.
When you get the car setup well, it's a good car.
hi on our 5 pinions wore out /2 a point and this damages plastic gears //on 4r it dos not mater as much if your track is dirty you will wear out pinions early but make sure you change pin//and gears at one time smouth 2 gear change is important not to much 1 gear//to long at our track and you get 2 hard or it changes in corner and you get 2 gears at once //striping 2make sure gears or not rubbing together move bearing or space with washer black bit on end of clutch was drilled of conter on some of the kits in QLD //look at engen mounts 2 see if they are parrell been some of them when you get it all right car will be good ///make sure you grease out drives i think that is what is making our diffs to tight greg
Love your work G
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 04-26-2012, 04:13 AM   #2027
djiewie's Avatar
Great translation Blis, Thanks. It takes some repeat reading before i understand wat Greg means. But its ok , respect.
djiewie is offline   Reply With Quote
Old 04-26-2012, 05:13 AM   #2028
Bishop's Avatar
http://www.redrc.net/2012/04/mugen-clutch-spacing-tool/
http://www.mugenseiki.com/b0543e.htm
I like it.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 04-26-2012, 06:00 AM   #2029
djiewie's Avatar
Why i ask you
When is it used ?? When i measure the clutchgap it is without endplay shimms.
When i measure the clutch in the car it only measures the endplay wich is between 0,1 and 0,15 mm so this tool is only used with the engine out off the car i asume. Racers do measure before a final but remove the rear bearing and the endplay simms, but the average racer will not do that i think.
Old 04-26-2012, 06:01 AM   #2030
Mazda614's Avatar
I should have patented my feeler gauges with a cut out years ago, nothing new here.
OS Speed T1201
Futaba 4PK 2.4Hz
Serpent 748 TQ
M16 Racing Fuels
Mazda614 is offline   Reply With Quote
Old 04-26-2012, 01:21 PM   #2031
PinoyCali's Avatar
Default Gear question
Hello All,,
If i change my gear from 53 to 54
Do I need to change the pinion?
PinoyCali is offline   Reply With Quote
Old 04-27-2012, 12:55 AM   #2032
Faiq-X4's Avatar
Originally Posted by PinoyCali View Post
Hello All,,
no need..
MTX-6
M11-X
Novarossi
JBRCC
Faiq-X4 is offline   Reply With Quote
Old 04-27-2012, 01:57 AM   #2033
Default mtx5
good job on the deciphering my post // bliss// that is just what i was trying to tell you peopel it all sounds good i my head it is just hard to write down if mugen got it right you all would have nothing to laugh at //i have got big shoulders ////greg/winger pop
greg.dawn is offline   Reply With Quote
Old 04-28-2012, 08:58 AM   #2034
Hi guys, good news from me! Racing whole day and not even a sign of second gear stripping. My solution was to put 2x0.1 shims between the first and the second gear spurs and threadlock on engine screws under the chassis And a handy tip from a racer on our local track - adjust your your second gear to engage five to ten meters after you leave the turn before the straight.
vi4o is offline   Reply With Quote
Old 04-28-2012, 09:55 PM   #2035
i know nothing to say to day ///ha
greg
Old 04-29-2012, 03:40 AM   #2036
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
greg
That's cause you have turned red!!!
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 05-02-2012, 02:13 AM   #2037
Arahawak's Avatar
Trader Rating: 32 (100%+)
Has anybody tried mounting a Sirio Nemesis on the MTX5?
Need some advise from those who had.
I can't seem to clear the carb.. Am thinking the only way is to shave the tank in order for the carb to be fully open.
Any ideas?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 05-02-2012, 02:17 AM   #2038
djiewie's Avatar
Maybe turn the carb a little
Old 05-02-2012, 02:18 AM   #2039
Default out of water
only just a little bit red but it will wear of really quick i hope the kids have fun greg
Old 05-02-2012, 02:34 AM   #2040
Arahawak's Avatar
Tried that.. Doesn't work
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
