Like Tree5Likes
SC10 4x4 Thread
Old 02-18-2012 | 05:57 PM
  #17791
Evil Genius jr.'s Avatar
Originally Posted by CoyoteSlash
Thread the 5.5 nut onto the Shaft where the shock would go, and use it as a counter to you threading the 7mm Nut to tighten down the shock post. Easy. (of course plastic isn't going to hold up to you twisting a hex against it.) That plastic is only supposed to hold the shaft from spinning when removing the shock, Not the Shock post installation itself.
And can you rephrase your question? What tools? You mean send me your diff for me to cut and send bearings with? or what?
Yes, could someone send a diff and bearings and have you do it for them.
Evil Genius jr. is offline
Old 02-18-2012 | 06:11 PM
  #17792
CoyoteSlash's Avatar
Yeah, Only problem is then when diffs go poof (like what's been going on without a bearing mod) I get blamed for it.
I'm only going to be sending out new diff housings with the bearings. Then your gears and installation, and shimming are on you. This just saves everyone alot of hassle, imo.
If that is a "make or break", you guys can PM me and we can talk. Otherwise, no.
CoyoteSlash is offline
Old 02-18-2012 | 06:37 PM
  #17793
MantisWorx's Avatar
smart choice, thats the best way for all IMO
MantisWorx is offline
Old 02-18-2012 | 06:40 PM
  #17794
Good choice, didn't think about it like that.
Old 02-18-2012 | 07:04 PM
  #17795
Thanks you two, glad you agree.
Ordering several Diffs monday. Should be able to send out next Monday, the 27th. All items are in stock currently. SO!
You can start PMing me now.
(I'll do an official post monday, so people can see what we are talking about who don't read.)
Old 02-18-2012 | 07:12 PM
  #17796
ive only ran my sc10 4x4 about 4 race days now 3 races each day. and my rear diff is bone dry. can that cause it to make a grinding slipping sound and have me lose power when i get on the throttle. all the gears look ok but just to be safe im buying all new front and rear diff gears and housing.
dougwalter911 is offline
Old 02-18-2012 | 07:15 PM
  #17797
Mizchief's Avatar
Last time I build my front diff, I put very small bead of silicone calk around the seal top and bottom and that stopped the leaking.
Getting the diff back apart may be difficult, I haven't had to yet, but I figure a small flathead screwdriver should get the job done.
Mizchief is offline
Old 02-18-2012 | 07:29 PM
  #17798
JEFFs SC10's Avatar
get a rebuild kit, save yourself some money. lack of fluid can cause some of that noise, but more than likely you are missing the shim. its very likely the diffs weren't tightened correctly from the factory.
JEFFs SC10 is offline
Old 02-18-2012 | 07:33 PM
  #17799
Hey symmetricon. I was trolling the for sale section looking for any deals and saw your ad. Giving up on this truck?
jamr1130 is offline
Old 02-18-2012 | 07:50 PM
  #17800
Mizchief's Avatar
Here is what a successful long jump might look like:
http://www.youtube.com/watch?feature...&v=S6_gUS8ByXA
Mizchief is offline
Old 02-18-2012 | 07:56 PM
  #17801
JEFFs SC10's Avatar
saw same thing
Old 02-18-2012 | 08:38 PM
  #17802
That's a little odd.
Old 02-18-2012 | 10:15 PM
  #17803
darryl80's Avatar
what pitch size pinions does the sc10 spur gear use?
darryl80 is offline
Old 02-18-2012 | 10:35 PM
  #17804
Is this actually a 4x4 SC10? or are you still being Completely oblivious?
If it is the 4x4:
32 or 48 depending what you want to run.
Please Read Page 1
Old 02-19-2012 | 02:59 AM
  #17805
I added a small amount of green slime on both sides of the seal.. should do the trick and come off with ease.
Arakon is offline
