Like Tree5Likes
SC10 4x4 Thread
Old 02-18-2012 | 06:29 AM
  #17776
Evil Genius jr.'s Avatar
Originally Posted by Mizchief
Do you mean the big hex side part of the shaft stripping the holders on the tower? If so then yes, I just tighten the shock down holding it with pliers and it stays on fine. I think there are some FT inserts you can get to fix that as well.
Yep those. I got to get some of those inserts!
Evil Genius jr. is offline
Old 02-18-2012 | 06:57 AM
  #17777
JEFFs SC10's Avatar
Is there a part no for those I had a problem on day 2 with those things.
Very curious to see how the idler helps with jumping. I'm not sure how it will help but as long as it does that's all that matters.
wet weather and having no saddles has foiled my 4x4 plans.
Mantis and you said my truck was dirty! hahah
JEFFs SC10 is offline
Old 02-18-2012 | 07:37 AM
  #17778
The manual says nothing of inserts.. I had the same issue, stripped right away. I ended up using pliers too.
Arakon is offline
Old 02-18-2012 | 08:00 AM
  #17779
Originally Posted by dougwalter911
I need HELP! I've taken my front and rear apart and looked in both gear boxes. the only thing i have not done yet is look in the diffs themselves. when i get on the throttle it makes a bad grinding sound and i lose some power. its not the clicker I've already tightened that up. any suggestions?
Any one have any ideas
dougwalter911 is offline
Old 02-18-2012 | 08:14 AM
  #17780
How does the mesh between your pinion and spur look? Does your spur look chewed up?
MCPilot is offline
Old 02-18-2012 | 08:30 AM
  #17781
Mizchief's Avatar
Sorry, I thought that's what these were, but now that I look closer I'm not sure:
http://www.amainhobbies.com/product_...t-C-Left-Right
Mizchief is offline
Old 02-18-2012 | 08:41 AM
  #17782
its perfect. no teeth missing. still looks brand new
Old 02-18-2012 | 08:42 AM
  #17783
Slotmachine's Avatar
Those are for raising the outer rear camber link location............
Slotmachine is offline
Old 02-18-2012 | 09:00 AM
  #17784
marksp's Avatar
Originally Posted by CoyoteSlash
495.99 will not be the final price.
It will sit right inside of 350.00
Yikes - when it first was orderable, the price was $349.98 less $50 coupon, net $299.98!
marksp is offline
Old 02-18-2012 | 10:07 AM
  #17785
MantisWorx's Avatar
more than likely the rear dif gears, order new ones and shim it from the get go and the noise should go away.
MantisWorx is offline
Old 02-18-2012 | 10:36 AM
  #17786
thebizz's Avatar
Start with the rear diff sounds like an idle gear, sometimes the sun gear get rounded also
thebizz is offline
Old 02-18-2012 | 04:10 PM
  #17787
Once again I am considering saddles. So inline or side by side? Why?
Old 02-18-2012 | 04:56 PM
  #17788
MantisWorx's Avatar
Inline, transitions quicker and the truck needs some weight upfront.
Old 02-18-2012 | 05:10 PM
  #17789
Do they remove understeer as much as side by side does?
Old 02-18-2012 | 05:42 PM
  #17790
CoyoteSlash's Avatar
Anyone else have any problems with the shock mounts stripping the shock tower?
CoyoteSlash,
Will be be offering the bearing mod to people with the diffs and bearing already just not the tools like you did with the pin mod?
Thread the 5.5 nut onto the Shaft where the shock would go, and use it as a counter to you threading the 7mm Nut to tighten down the shock post. Easy. (of course plastic isn't going to hold up to you twisting a hex against it.) That plastic is only supposed to hold the shaft from spinning when removing the shock, Not the Shock post installation itself.
And can you rephrase your question? What tools? You mean send me your diff for me to cut and send bearings with? or what?
CoyoteSlash is offline
