SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 11-19-2013 | 11:19 AM
  #2596
WIGMAN's Avatar
Currently these packs are in stock.
3.7V 4000mah 25C Inboard
7.4V 5000mah 50C Traxxas & Deans
7.4V 4300mah 50C Shorty, Inboard
7.4V 9400mah 60C Traxxas & Deans (soft pack)
7.4V 5600mah 70C Saddle Pack
7.4V 6500mah 70c Traxxas
7.4V 7200mah 70C Traxxas
11.1V 5600mah 60C Traxxas
14.8V 5000mah 50C
14.8V 4600 70C Short Case
There may be more packs added as the order that came in yesterday is gone through and pre-orders shipped out.
There is another order expected in early next week that will have more of the 4600 2s shorties in it.
WIGMAN is offline
Old 11-19-2013 | 11:31 AM
  #2597
jmackani's Avatar
Originally Posted by fq06
Pretty sure the Hyperion has a setting for end voltage, I set my powerlab to terminate charge at 8.39v.
Right, if the case is roar approved with a sticker they don't need to check. Just a guess, the non roar packs out there have the same size case as its become an industry standard, its the cells or just the fact that the lipo maker didn't pay for roar approval that leaves the pack without roar approval.
Danny said before that the 7200 is at the cases limit and any normal pack swelling that you would have with a 6500 or 5500 or whatever is pushing against the case with the 7200 where the smaller packs do not. So the same thing is going on in there but it is not noticed with the smaller mah packs.
Actually the sticker is no longer required from the vendor. The sticker Glenn is referencing is related to the the one that tech inspection placed on the battery. Too many fancy ROAR approved labels were ending up on batteries that were not on the ROAR approved listing.
jmackani is offline
Old 11-19-2013 | 11:48 AM
  #2598
I'm a little new to Lipo's but, can you tell me which balance plug is used to charge SMC's?
Thanks...
981PCAR is offline
Old 11-19-2013 | 12:18 PM
  #2599
WIGMAN's Avatar
Thanks...
Just e-mailed Danny and this is what he said.
It's the JST-XH connector which is used by most companies and is considered the standard
WIGMAN is offline
Old 11-19-2013 | 12:30 PM
  #2600
Thanks for doing that!!!!
My inexperience is probably getting in the way but it seems I have two options in balance boards that work with my Cellpro charger; CP-GP/KO and CP4S-TP/PQ4S.
Does this ring a bell?
Also, do you always charge through the balance board, bypassing the deans connector?
Thanks!!
981PCAR is offline
Old 11-19-2013 | 12:49 PM
  #2601
mashimarowu's Avatar
Thanks!!
No, you need to connect the balance plug and deans connector to charge your lipo batteries.
mashimarowu is offline
Old 11-19-2013 | 02:13 PM
  #2602
dtr's Avatar
dtr
You need the CP-GP/KO, the description reads it has xh connectors.
dtr is offline
Old 11-19-2013 | 04:03 PM
  #2603
Thanks guys. I do have the GP/KO connector already, but is that the best way to charge? Is there another way I could connect both the dean's and balance plug?
981PCAR is offline
Old 11-19-2013 | 04:10 PM
  #2604
WIGMAN's Avatar
You can not charge through the balance port all that is for is when you do a balance charge it will monitor the cells to make sure they charge evenly.
No matter what charge mode you use the charging will be done through your deans plug, your charger should have a port where a deans plug can be plugged in so you can plug your battery into it. You dont have to hook the balance plug up in order to charge, the only time it will be used is when you do a balance charge.
WIGMAN is offline
Old 11-19-2013 | 04:18 PM
  #2605
ImageX's Avatar
NO. They are two separate connections. One is for carrying power and one is for monitoring.
ImageX is offline
Old 11-19-2013 | 06:57 PM
  #2606
Chevis's Avatar
Thanks!!
Which Cellpro charger do you have? You can charge through the balance plug, but you are limited to 4A.
Chevis
Chevis is offline
Old 11-19-2013 | 07:29 PM
  #2607
silveraider14's Avatar
any word on when some 7200 inboard packs will be in?
silveraider14 is offline
Old 11-19-2013 | 07:37 PM
  #2608
Chevis
I have the little Multi 4
I can't seem to find anywhere on the charger to accept a deans....
981PCAR is offline
Old 11-20-2013 | 03:13 AM
  #2609
WIGMAN's Avatar
http://www.revolectrix.com/m4_video_tab.htm
Here is a video for your charger, Never seen one that only charges through the balance port. Depending on which cells you get from SMC I would not really reccomend this charger, you really want to be able to charge at at least 1C, this charger while highly sophisticated will only charge at 4 amps which does not get you up to a 1C charge on any of SMC's packs. Danny actually reccomends charging at 2-3C for best performance and longevity of your packs.
WIGMAN is offline
Old 11-20-2013 | 04:03 AM
  #2610
DriveItLikeYSIT's Avatar
How many amps do you need to charge at 2-3C?
DriveItLikeYSIT is offline
