Spektrum
Old 10-08-2007 | 10:06 PM
  #2431
Robertw321's Avatar
Originally Posted by |JayFlores|2
connect esc to the battery..
press and hold rx button.. wait for it to flash many times.
press and hold tx module button and turn on radio.
wait for the tx module light to flash many times and both rx and tx module light will be in a solid state.
hth
The 3500 (micro) receiver does not have a bind button. It uses a plug in the first receiver slot to short the signal line to ground. With the plug, in turning on the ESC causes the light to flash indicating it's ready to be bound. Remove plug after binding.
Robertw321 is offline
Old 10-08-2007 | 10:59 PM
  #2432
A Ilievski's Avatar
Its all sorted now
I didnt know i had to change the settings from HRS to PPM.
A Ilievski is offline
Old 10-08-2007 | 11:37 PM
  #2433
rocketron's Avatar
Originally Posted by doriftu
hi,
so if I would to use my Futaba 3PK Spektrum module with the Losi DSM receiver, there will not be a problem right?
Sorry, if I asked a redundant question. I just would like to have a confirmation on that... it is much cheaper...
thanks for the great info!!
yes it will be fine (no smoke either ) but NOT if the HRS version of spektrum
rocketron is offline
Old 10-09-2007 | 12:20 AM
  #2434
nnick's Avatar
Shop Owner
Originally Posted by RCGaryK
It does work with the Spektrum modules, radios, and the DX3R. However I am not sure that the range is the same between the Losi and the Spektrum units. But if you buy a Slider have confidence in the fact that, if you want to use your own radio instead of the one it comes with, it will work.
It's sure looks like the spektrum one. I wouldn't be surprised if it's the same unit, after all Losi and Spektrum are both Horizon's
nnick is offline
Old 10-09-2007 | 12:35 AM
  #2435
Turbo Joe's Avatar
If you look inside, there's a Spektrum logo on the board.
Turbo Joe is offline
Old 10-09-2007 | 12:45 AM
  #2436
nnick's Avatar
Shop Owner
Funny thing is the price is low compared to spektrum one
nnick is offline
Old 10-09-2007 | 10:38 AM
  #2437
RCGaryK's Avatar
They are physically different receivers. One major difference you can see right away is the Losi receiver uses a bind plug, where the Spektrum receivers had bind buttons. The PCBs are different to accomodate each different bind method. While I don't know the ins and outs on the Losi unit it wouldn't surprise me that there are other differences as well.
RCGaryK is offline
Old 10-09-2007 | 11:11 AM
  #2438
Robertw321's Avatar
The Spektrum 3500 micro receiver does not have a bind button. It uses a bind plug.
Old 10-09-2007 | 11:30 AM
  #2439
RCGaryK's Avatar
The SR3000 and SR3001, which are the ones people are comparing the Losi receiver to, most certainly do have a Bind Buttons.
RCGaryK is offline
Old 10-09-2007 | 06:55 PM
  #2440
Robertw321's Avatar
You stated that Spektrum receivers had bind buttons. I posted a fact that the 3500 most certainly does not. If they are supposed to, my 3 are defective.
Unless I didn't go back far enough, I don't see where anyone compared the Losi unit to any Spektrum unit. The only posts I can find ask if the Losi will work with regular Spektrum transmitters and modules. None of my posts mention the 3000 or 3001 anywhere. What started my series of posts was someone having trouble binding his 3500 receiver to his Futaba radio and someone advising him to push the bind button on the receiver.
Old 10-10-2007 | 08:31 AM
  #2441
RCGaryK's Avatar
Originally Posted by SWTour
..I'm hearing the receiver for the new LOSI SLIDER that comes with the Spektrum radio will work in the regular Spektrum systems...
anyone here try them yet?
(They run about 1/2 the price of the normal spektrum receivers....)
Originally Posted by Turbo Joe
Yep...several of us have them. They seem to work just fine. myrcsupply.com has them for 30-something...I think 35-37 bucks or so.
Originally Posted by tfrahm
I liked the one in my Slider so much, I bought one for my XXX-R Dirt Oval late model, and it works like a charm! The only thing I've noticed is that if I'm down at ground level (not up on the driver's stand), the range is a bit short ("fail safe" has kicked in twice in 4 weeks at about 120' or so -- not every time, just once in a while). However, once I'm up on the stand, it's flawless all night long. (190' indoor dirt oval)
hi,
There are the posts where people were asking about the Losi receiver.
RCGaryK is offline
Old 10-28-2007 | 07:35 AM
  #2442
Default broken SR3500 RX case
I had a bit of an accident this weekend resulting in the case of my SR3500 micro RX splitting in half. Everything appears to work still as I still have throttle and steering control. Two of the tabs on the bottom that hold the top half on are gone and the bottom section has been split in half. The circuit board came away in one piece and is only fixed to the upper section by things being plugged into it still.
Is the only way to get this fixed to send it in to Horizon or does anyone know of a part number for just the receiver case?
Thanks in advance,
Chris
ckearns is offline
Old 10-28-2007 | 02:05 PM
  #2443
RCGaryK's Avatar
Thanks in advance,
Chris
The case isn't sold separately, but you can send it in to get checked out and taken care of.
RCGaryK is offline
Old 10-29-2007 | 05:52 PM
  #2444
As a follow up to my previous question, I've found that Horizon/Spektrum won't ship just the receiver case. They require the receiver to be sent in for repair to ensure the circuit board isn't damaged during the transplant.
The good part is that they'll do it for free.
Chris
ckearns is offline
Old 10-30-2007 | 06:23 AM
  #2445
abailey21's Avatar
R/C Tech Elite Member
That's good info, i wasn't aware of that.
abailey21 is offline
