Spektrum
Old 07-13-2006 | 02:22 PM
  #1681
kyle "hitawall"'s Avatar
Originally Posted by RCGaryK
Try rebinding the receiver you got back from repair
i tride that but ther is no power to the reciever
kyle "hitawall" is offline
Old 07-13-2006 | 02:49 PM
  #1682
RCGaryK's Avatar
Make sure you have the polarity on the plugs right...
Try a receiver pack...
Other than that, you've got me stumped
RCGaryK is offline
Old 07-15-2006 | 08:21 PM
  #1683
pinggoy's Avatar
got a question i im about to buy somebodys spektrum and a radio. when i installed the receiver and plug in the wires and try to turn it on , it just keeps on running it wont stop my radio wont do any thing.. please help...and i trust this guy so im pretty sure there is nothing wrong with it....
pinggoy is offline
Old 07-15-2006 | 08:29 PM
  #1684
TimPotter's Avatar
Will, I PM'ed you..... It just needs to be Bound....
TimPotter is offline
Old 07-16-2006 | 09:41 AM
  #1685
SA_Racer's Avatar
I have 2 problems that I need help with
1. I bought a Pro receiver for my radio, and it bound without a problem, but if I use the telemetry module with it I keep losing signal. Sometimes when I turn on the Telemetry it doesn’t link up to the radio, I then have to turn it off and back on to make it register. When I use it with the standard receiver I don’t have this problem. The new receiver seems to be fine without the telemetry module attached.
2. When I use the telemetry module. It doesn’t matter whether it is connected to the receiver or directly to the car battery, It doesn’t show more that 4.08volts, and the RPM counter is very inconsistent. When holding the car in my hand and running full speed, I register 20000RPM, but when I drive on the track it sometimes jumps to 65000 rpm, this is with a stock motor.
Thanks for the help.
SA_Racer is offline
Old 07-16-2006 | 11:16 PM
  #1686
B&O's Avatar
B&O
Isn't the pro system doesn't support the telemetry system?
B&O is offline
Old 07-16-2006 | 11:36 PM
  #1687
AngryAsian's Avatar
I think that's the mini you're thinking of...
the mini doesn't support it, but the Pro does?..
AngryAsian is offline
Old 07-16-2006 | 11:49 PM
  #1688
DirtyDog3375's Avatar
Does anyone know (for certain) if you run digital servos (Futaba 9550) with the 3500 micro rx, do you still need a power cap to ensure there is correct voltage being supplied to the rx?
DirtyDog3375 is offline
Old 07-17-2006 | 12:00 AM
  #1689
andrewdoherty's Avatar
The pro supports telemetry. I read it just this evening on Spektrum's site.
andrewdoherty is offline
Old 07-17-2006 | 12:13 AM
  #1690
SA_Racer's Avatar
any ideas?
SA_Racer is offline
Old 07-17-2006 | 06:17 AM
  #1691
RCGaryK's Avatar
SA_Racer, I don't know, I'll pass your question on to see if I can get an answer.
B&O and Angra Asain:
The Pro Series SR3001 receiver (the bigger one) DOES work with the telemetry modules. The only receivers that are not compatible with Telemetry are the SR3500 Micro receiver and the HRS receiver.
Dirty Dog, I am running JR 9000s and 8800s Servos in my 1/8 scale buggy and truggy along with 2 electric sedans and my Mini LST. I have yet to need to use the Voltage Protector.
RCGaryK is offline
Old 07-17-2006 | 08:12 AM
  #1692
thanks for the info RCGaryK. Much appreciated. I have just got mine and have not yet fully tested it properly (under racing conditions). I was just a little concerned hearing some people say varying things about the system on this thread and also another thread on RC Tech.
Old 07-17-2006 | 08:50 AM
  #1693
RCGaryK's Avatar
No sweat. And don't forget, in a nitro car, I'm using dual 9000's or dual 8800s..no worries.
RCGaryK is offline
Old 07-17-2006 | 10:22 AM
  #1694
Originally Posted by Turbonium
i have put the Spektrum module in my Helios, with the spktrum arial is coming out of the factory antenna hole.... kinda hard to describe how to do it tho. i had to take the module apart, and make a small hole in the case where the antenna wire can come out.
if i get a chance, ill shoot some pix this eve.
Wes
If you can, pleas post pictures so we can see to which direction should i think.
Have you had any glitchis after modification?
JanisK is offline
Old 07-17-2006 | 01:25 PM
  #1695
bvoltz's Avatar
If you are running a Q2 by LRP, you may need one as it does not put out 6.0v. I have one and I have to run a cap, but my sphere this runs fine without a cap...
bvoltz is offline
