Spektrum
Old 07-24-2006 | 09:00 AM
  #1711
Originally Posted by fpart
Thats the problem. When you think if you are careful you can do odd things to debug a problem. At least when I make a mistake, people don't fall out of the sky....lol
The just get shot down!
It sounds that this mod is not for you bro...
cvt01 is offline
Old 07-24-2006 | 09:24 AM
  #1712
bvoltz's Avatar
Here is the link to the mod.... If you choose to do it...
http://www.rctech.net/forum/showthre...hlight=M11+MOD
Personally I do not have a M11, but I do have an EX-10 and did the mod... very simple... Looks great...
bvoltz is offline
Old 07-24-2006 | 04:52 PM
  #1713
Thumbs up
Originally Posted by Skiddins
Hi guy's
I've just bought a Futaba T3VC radio and I'm looking at upgrading to 2.4GHz.
Which module would you recommend? and is the receiver out yet that doesn't have an aerial wire sticking out at all?
Skiddins
Hi,
I'm running the HRS spektrum in my 3vc, works great, but any of the spektrum systems will work. I'd recommend the pro series though, with the cool micro receivers, and ability to use either digital or analogue servos you can't go wrong
That receiver that has no aerial wire is being made by Futaba but it's not out yet. You would also have to buy the module made by Futaba as well to run that receiver
Hope this helps
Seano is offline
Old 07-25-2006 | 10:08 PM
  #1714
have searched the threads and could not find the answer to my question can anyone help, has anyone tried using the system to play the VRC game
cheers for any help
judge10tpt is offline
Old 07-26-2006 | 02:35 AM
  #1715
coons88's Avatar
Not sure, but if nobody else knows I can tell you next weeks as I have an adapter on the way
coons88 is offline
Old 07-26-2006 | 06:18 AM
  #1716
RCGaryK's Avatar
cheers for any help
Yes, it works great
RCGaryK is offline
Old 07-26-2006 | 06:24 AM
  #1717
bvoltz's Avatar
cheers for any help
I have a EX-10 with the pro installed, and no problems.
bvoltz is offline
Old 07-26-2006 | 08:33 AM
  #1718
Just recieved my Helios with spektrum pro module and a micro reciever and have to say im well pleased with it! One question though does anyone know at what voltage the failsafe activates (it would be even nicer to know it was protecting my Lipos to) Oh and i love the micro reciever so so small and the ariel wouldent even reach the roof of my m18!!!!!!!
Cotti is offline
Old 07-26-2006 | 09:15 AM
  #1719
RCGaryK's Avatar
it's not a voltage that the failsafe kicks in at, it's at a loss of signal. The SR3500 has a minimum operating voltage of 3.2V if that's what you wanted to know.
RCGaryK is offline
Old 07-26-2006 | 09:54 AM
  #1720
Dan the Man's Avatar
Can't find any info about whether the Spektrum is compatible with the Hitec Eclipse Pro Car 3-channel stick radio...anyone know?
Dan the Man is offline
Old 07-26-2006 | 11:25 AM
  #1721
RCGaryK's Avatar
Does that radio use the same module as the CRX and SRX? If so it should work.
RCGaryK is offline
Old 08-02-2006 | 07:14 PM
  #1722
Im having a problem with my Spektrum suddenly.
Symptoms:
- I lose my connection at the far corners of the track. Esp the one near some power lines they are working on but not sure if that is a coincidence (it is also the furthest corner away)
- Power Lines?
- Something wrong with my Spektrum receiver (micro)
- Something wrong with my Module? I dropped it a couple months ago and broke the clip on the inside. Tried repairing that twice unsuccessfully. Hadnt had problems after doing that until recently.
- I have tried both with and without the cap. When I had the cap in the battery slot versus the accessory it seemed to fix it for a bit but when I added my brushless back it got bad again.
Ideas?
Equipment:
- Spektrum Micro Receiver
- Sphere Comp ESC
- Regular and Lipo battery. Seemed worse with the Lipo
- Brushless and Brushed motors (seemed worse with brushless)
- With and without fans attached it did it.
Also Im going to run 3 fans next week hardwired to the battery. Do I need to be concerned?
or8ital is offline
Old 08-02-2006 | 07:44 PM
  #1723
Orbital,
I had the same problem about 7 months ago. My pan cars went full throttle whenever they went certain distance away from me.
Later I realized that my antenna cover came apart as I mistakenly hit a fence. During that time, I immediately put it back in place without checking the wire inside.
So I took apart my antenna and made sure that the wire inside is well extended rather than coiling together. Up until now, my spektrum never failed me even at 70meters away from me near a large array of fence.
azmio is offline
Old 08-03-2006 | 06:25 AM
  #1724
Azmio, I assume you mean the antenna on the radio side? When I took my module apart there did seem to be quite a bit of antenna in the module part rather then the antenna tube. I couldnt figure out how though to make sure it was fully extended in the tube. How do I do that?
or8ital is offline
Old 08-03-2006 | 07:05 AM
  #1725
Gary:
Hi,
when running the 3500 (or any Sekturm Rx) with a KO Speedo is there anything I will have to do like bump up the voltage on the B.E.C.?????
also where do I get the antenna with the longer wire so I can do the antenna install in the radio. I,d feel much better with the antenna in the radio than hanging off the back of the radio.
TimXLB is offline
