Spektrum
#2401
The original grey module will also work with the newer receivers. I have the original module in my Ko Mars R with the Micro receiver. It works great but I have noticed a few minor things the more I run it.
At low speeds I will sometimes notice a hesitation in throttle followed by what can only be described as a small 'spike' in throttle. Only happens at low speeds when I'm cornering so I'm going to try another servo to see if that is the culprit.
The other issue I am experiencing is the neutral point on the servo. It feels like I'm constantly adjusting it on the radio, but again it could be the servo again.
I visited Spektrum's website and they speak of two similar issues in their FAQ section.
Any suggestions?
Any suggestions?
#2402
Thanks Skitee and Bobby...
so can I say that there is no major issue if I would to use the original grey receiver with the Pro module? what about the latency? does it follow Pro's or grey's time delay?
just would like to double confirm...
if so, i would buy the grey rx cos its cheaper...
#2403
If you use the SR3000 with the Pro module then the latency is the same as the original Spektrum system latency, if you want the lower latency of the Pro system then you must use either the SR3001(Pro Receiver) or SR3500(Micro Receiver)
#2405
#2406
http://xtremerc.com/pages/howto.php?howto=16&page=1
Took me forever to track it down a few weeks ago. Not even all that necessary because the modification is so simple. I spent more time looking for the tutorial than I did actually doing the mod
#2407
I'm running original grey module in my Ko Mars R with the Micro 3500 receiver.
Any suggestions?
#2409
lol I realized the same thing once i did mine, thank you though
Ask and ye shall receive...
#2410
I just started usin spektrum and had a steering servo problem..kopropo ex10 and pro module, all brand new
Using a hitec servo, it wouldnt go left somtimes ,on closer look it would hesitat to go in one direction .
removed servo and put on diff radio no prob, put on servo tester no prob.
changed to a hitec digital servo no prob on the spektrum....
??????? any ideas.
??????? any ideas.
#2411
ymmv,
Scottrik
#2413
