Spektrum
#1606
Anybody have a good picture of the 3500 micro reciever installed in there car?
Just wanted to see how small it looked like installed. Orderd Pro series module and micro reciever but they dont come till the end of the week
#1608
#1610
Originally Posted by Jon3
Fitting Pro Module into 3PKS?
I've got my Pro module into my 3PKS, but I can't seem to get the cover back on afterwards. Am I the only one?
#1611
I have a strange issue and looking for input.
Configuration
When I switch everything on and very quickly steer from full left to full right continuously the Spektrum falls into fail-safe. And very quickly after that starts to operate again normally.
I know this isn't normal use. Because chicanes aren't that small, but it is just a strange thing.
I also retested this with 2 other receivers and had the same issue.
And I tested it on a short distance between receiver and transmitter and also at long distance. All with the same result.
Does anybody knows what is happening?
Configuration
- Transmitter: Futaba 3PK with the Spektrum SM1000 DSM Module
- Receiver: Spektrum SR3000 DSM
- Servo: KO PROPO PDS-2413 ICS
- ESC: LRP Quantum Competition 2
- Car: XRAY T2
#1613
#1614
You can't fit the cover after having the spektrum module installed in your 3PK.
And friday I'll post a photo of my spektrum micro in a T2.
I saw the pics a few pages back but it was with a big Brushless esc, wanted to see what it looked like next to a 'normal' esc.
#1616
#1618
Originally Posted by *sil80*
hey guys,
Just bought a spektrum dx2 and im using the z590 servo but i cant seem to get as much lock as id like from it? any idea? i have set the steering trim to 125.
#1619
Originally Posted by 17driver
You have to take a dremal and take a little material off and then it will fit.That's what I did.
I ended up just cranking down with a bit of pressure, and it ended up fitting in. Tight as heck, but it is nice and neat!
#1620
Originally Posted by JayL
well at the nat's tons of people, including me, ran DSM and wifi was going the whole time so id' say that was a freak or something is up with your router...
...on another note, and don't know if it's been mentioned before, can you run a "power accessory" off of the bind plug on the micro recvr? Specifically a motor fan?
