Spektrum
Old 06-30-2006 | 08:48 AM
  #1621
Tubaboy's Avatar
Originally Posted by HarshGuy
...on another note, and don't know if it's been mentioned before, can you run a "power accessory" off of the bind plug on the micro recvr? Specifically a motor fan?
Isn't the bind plug removable? I thought the receiver still has 4 available slots to plug things in. Aux., Batt, steering, throttle. Not sure though, since I don't own one.
Paul
Tubaboy is offline
Old 06-30-2006 | 08:57 AM
  #1622
HarshGuy's Avatar
Paul
Yes it's removable and the bind plug has a wire from negative to signal, positive is "blank" ..so I *assumed* that I could plug in a negative/positive only perpheral (like a fan) ...but I'd hate to try it, turn the car on and KAPLOEYYY!!!
HarshGuy is offline
Old 06-30-2006 | 09:13 AM
  #1623
RCGaryK's Avatar
Yes, you can use the "Bind" slot for power. If you look at the Bind plug, it's leads "short out" the outside 2 pins....a fan or other accessory uses the outside and middle pin.
RCGaryK is offline
Old 07-01-2006 | 12:06 PM
  #1624
I try the SR3500 micro receiver today with a 7T mod, the car has some(a lot) glitch on the right hand side of the track, last week with a 12T mod it was fine. I have a capacitor plug in the receiver, I'm using a KO VFS-1. Any idea why? Only the right hand side of the track. I later put the old SR3000 receiver back on, The car works perfectly, no glitch at all.( still with 7T mod) What can I do?
caveman is offline
Old 07-01-2006 | 12:29 PM
  #1625
Joep's Avatar
I tested the micro too today with my 12T V2. And 2 strange things:
  1. I had twice a real big glitch and lost the car (failsafe was working)
  2. With the transmitter on (but also when I turned the transmitter off!!) the throttle was on/off every few seconds.
I did put the SR3000 back in and the problems were gone.
Is this a known problem, or is again my ESC?
Joep is offline
Old 07-01-2006 | 06:36 PM
  #1626
RCGaryK's Avatar
First issue I've heard of with the 3500's. I won't be in the office until Wednesday, but I'll pass this on and see if anyone else has heard anything. The hottest motor I've run with mine so far has been a 10T V2 in my XXX-4 4wd buggy and it ran perfectly. Like I say, I'll see if I can find anything out.
Question though:
What transmitter, modules (standard or Pro series), ESC, and servos? Thanks guys.
PS: Caveman- If you have the handheld programmer for the VFS-1, crank the BEC voltage to 4.0 volts and try that. I know Robert from KO told me to crank the BEC up when I mentioned I was first going to Spektrum when I was running a Helios.
RCGaryK is offline
Old 07-01-2006 | 07:17 PM
  #1627
2-Bad's Avatar
I ran my Pro/micro for the first time on Friday night (19t)... no problems to report... it's all good here
2-Bad is offline
Old 07-01-2006 | 07:22 PM
  #1628
Originally Posted by RCGaryK
First problems I've heard of with the 3500's. I won't be in the office until Wednesday, but I'll pass this on and see if anyone else has heard anything. The hottest motor I've run with mine so far has been a 10T V2 in my XXX-4 4wd buggy and it ran perfectly. Like I say, I'll see if I can find anything out.
Question though:
I use a Futaba 9551 digital servo and standard module with Futaba 3PK, it has been problem free with SR3000 receiver(after re route the antenna inside the module). So I think the module is fine. I have the handheld programmer, will set it to 4.0volts and give it a try, thanks for the reply
caveman is offline
Old 07-02-2006 | 01:10 AM
  #1629
big al's Avatar
any body here know what the transmit time (latency??) is for the dx2/3 radios?? I had a Ko ex-11 before and my dx2 feels faster, my airtronics 258 servo also seems more responsive..is it my head??--Al
big al is offline
Old 07-02-2006 | 01:17 AM
  #1630
Got Xray?'s Avatar
Hi guys,
I recently snapped my spektrum arial about 1cm from where is goes into the reciever.
Can i send this back to spektrum and get them to fix it?
Also ive heard there was an upgrade for the reciever and transmitter module...is this free or will it cost?
Thanks in advance,
Nick
Got Xray? is offline
Old 07-02-2006 | 05:36 AM
  #1631
I ran the 3500 with a 4.5 and 4800 lipos in my TC yesterday and I had no problems at all.
Davenport is offline
Old 07-02-2006 | 05:39 AM
  #1632
X2's Avatar
X2
I have a Pro series module and Micro receiver coming tomorrow, i'll post if I have any problems.
Hopefully i won't have too.
X2 is offline
Old 07-02-2006 | 08:26 AM
  #1633
RCGaryK's Avatar
Originally Posted by Got Xray?
Hi guys,
Thanks in advance,
Nick
The upgrades involve a firmware update for the module and receiver and are free of charge. I'm not sure if the warantee covers the antenna or not, I'd say call product support just to double check though.
RCGaryK is offline
Old 07-02-2006 | 09:26 AM
  #1634
Jon Kerr's Avatar
Well Gary, you and Ron were right. 2 weekend down and so far I'm very happy with the Spektrum Pro system.
Jon Kerr is offline
Old 07-02-2006 | 10:32 AM
  #1635
ChrisP's Avatar
I haven't been able to find an answer to this but, can you use the older SR3000 receivers with the 'Pro' modules? I'll be eventually moving over to SR3500's but until then I need to know if my existing receivers will still be compatibile if I get the new module.
ChrisP is offline
