Spektrum
#1456
Originally Posted by minimadman2003
I have no idea how to tell if they require a software update other than to use them and send them in if you have any trouble with them shutting down. The module antenna routing is another story. They have a blurb on their website on how to check for that, but I believe it was more with the Futaba modules than Airtronics.
#1457
Originally Posted by dodgeguy
I just got a Spectrum for my M8. I do not think it has the latest software update. I am using a GTB with it. When I turn on the unit the motor runs at full speed until the green LED comes the receiver comes on. Then the GTB acts normal.
How do I find out if mine has the update? Does anyone know how long it takes for the update?
Spektrum kicks ass.
#1458
I have the fail safe correct now.
If Spectrum works the way it is suppose to. You can turn on the car then the radio. The receiver should not do anything until a bound transmitter signal is received.
#1459
I just bought a new receiver and it had a little green dot on the panel with the module part number. Does anyone know if that means it's the "latest" software? The receiver just came in to my LHS, so it can't be too old. Gary?
RC Razer, the Spektrum Z590 uses a 23 Tooth spline, same as JR.
While if you set the failsafe up correctly you technically "can" turn the car on first, then the radio, it's stil reccomended to turn the radio on just in case the failsafe isn't set correctly.
#1460
Thanks RCGaryK..
The led will not tell if you have the latest software...there are no indication on the recvr that will tell you if your recvr has the latest software.
Reason why i know this because I sent out an email to Spektrum Product Support and here is the copy of the email..
"The Spektrum receivers had a firmware update from the early production for the line and this was to resolve minor static issues. We have no way to distinguish the older receivers from the new. However, this was not a problem with the DX3 or DX2 transmitters themselves. "
#1461
Right, any ESD issues had nothing to do with the transmitters or the modules, it was in the receivers themselves which the new firmware fixes. I know I've been running the new software since before the Novak Race without one issue, on or off road, nitro or electric.
#1463
Has anyone worked with the new micro receiver SR3500? I noticed on the Spektrum web site, this receiver does not work with the telemetry section, but it has all the other features. Can anyone confirm this. I'm looking to get DSM but I'm waiting on the pro and size, which this SR3500 looks like the ticket, if it has telemetry....
Below is cut and pasted from the Spektrum web site: (http://www.spektrumrc.com/Products/D...ProdID=SPM1210)
"Think of it. All the no-pins, no-crystals, no-glitches, no-interference convenience and security of Spektrum's DSM 2.4GHz technology in a smaller package. Fact is, except for not featuring a telemetry section, its performance and circuitry are identical to that of our regular, race-proven SR3000 receiver. Plus the lowest latency, equal to that of the new Pro Series receivers."
#1464
I have one waiting for me that I ordered at the store. My understanding is that it does not do telemetry. In fact I think it might be the same case the telemetry module uses (very small). I'll try to post a review once I try it out. Does anyone know if it is the speed of the pro module? Also can I use a a non-HRS pro module in my 3pk since the micro module doesnt support HRS either. What do I lose?
#1465
i've used the new small receiver for several weeks and it doesn't support telemetry as i understand. As for comparison to the Pro again it is very similar. The case does appear to be the same as the telemetry nice and small
Binding with the loop is not a hassle as i had originally thought it might.
#1466
#1467
I've also run the Micro receiver and it works very well. It is true that it is not compatible with the telemetry system. The bind plug works perfectly, exactly like on the AR6000 receiver for the DX6. It also features the same improved latency as the new Pro Series equipment as well. If you liked the original system and aren't going to use telemetry, you'll love the SR3500!
#1468
The telemetry module is junk anyway so that shouldnt be a problem for anyone. Is there a non-HRS pro system I can run in the 3pk? What would I lose by running that setup (since the micro receiver doesnt work with the new HRS system)?
#1469
Binding with the loop is not a hassle as i had originally thought it might.Is there something else you need to buy to bind the new 3500 reciever to the module????
I am getting the Pro system tomorrow and the new micro receivers as well,
I just don't want to get it and then have to wait another week to get the binding loop????
Please let me know,
Thanks Bro,
-Shookie <><
#1470
http://www.horizonhobby.com/Products...ProdID=SPM1014
That's the Pro Series Module and Receiver for the 3PK.
http://www.horizonhobby.com/Products...ProdID=SPM1114
Module Only
Shookie, the SR3500 comes with the bind plug you need. There's nothing else you need to buy to make it work with your module. By going with the Pro system instead of the HRS, you'll just have a slightly higher latency is all. And neither the HRS nor the SR3500 do telemetry, so that's a moot point there
Module Only
