HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 11-29-2013, 09:28 PM
  #4891
Lead-Lobber's Avatar
Location: Currently live in southern AZ, or closer to northern Mexico if your a realist.
Default DOOOOH!!!
Originally Posted by froggie22
The Trackstar is made by Turnigy and sold by HobbyKing.
HobbyWing is a completly different brand (which this thread is on).
Thats why you couldn't find it by searching.
The Trackstar esc's lack quality and features.
The hobbywing stuff is great quality and great value. I would take a look at some of the hobbywing stuff instead of the Trackstar (hobbyking) stuff.
As for the question, sorry I don't have the answer for that one. It should have the instructions in the manual.
And that would be egg on my face! Thanks for the education. I'll def look into their gear when I upgrade to go from novice to more competitive stock and mod racing.
Lead-Lobber is offline
Old 11-30-2013, 04:33 PM
  #4892
Originally Posted by sonspit
both are v2.1 escs and im using the latest pc program version downloaded from falcon sekido.v3.3.
this is the firmware the esc came with V103_130806_Beta. im not sure if thats a older version... i hope it is.. because im using a 6pole motor and reading the info on the web lately the newest firmware has issues with 4-6pole motors (i know the older firmware had no issues). so im worried to use my rc (havent driven in a while).. dont want to damage brand new goods... do you know if this firmware is older version?
Well I hooked everything up and ran it on the bench .... Seemed fine.. But can anyone tell me if the firmware is a older version and about how old is it?
Thx in advance
sonspit is offline
Old 11-30-2013, 04:48 PM
  #4893
COBRARACING's Avatar
Thx in advance
Its the new version but after an extensive testing program i did find that 60% of all sensored motors from alot of manufacturers are not shimmed properly from factory thus the rotors alignment to the sensor board hall sensors is way out.Many make the mistake of not shimming after swapping to different rotors or after maintenance.
The hobbywing esc's and the software are not designed to be on/off switches like other esc's they are designed to be linear racing esc's so all basics must be met for the esc's to function as they should .
Remember many brushless motor factories in china dont liase with escs factorys and are more copy a product and sell etc.They understand how to manufacture the motor but not to design the motor to work like it should.
COBRARACING is offline
Old 11-30-2013, 06:15 PM
  #4894
I purchased a new v3.1 last week and installed it today in a new buggy. When I went to plug the battery in the capacitor board got fire red and was smoking. I unsoldered the capacitor and the speedo came on fine. Any ones input would be great. It sucks being brand new and already having problems. Thanks.
ronallen is offline
Old 11-30-2013, 06:20 PM
  #4895
Maybe a spike from your battery pack damaged the cap or im sure just a faulty cap board which shorted.Just replace the cap board and it will be fine.
Can you please send me a photo of the cap board to [email protected]
Old 11-30-2013, 06:30 PM
  #4896
Ok thanks.
ronallen is offline
Old 11-30-2013, 08:13 PM
  #4897
Ok thanks for the response.. I run a sensorless 6pole motor.. Is this firmware ok with that? Thats my concern.
sonspit is offline
Old 11-30-2013, 08:17 PM
  #4898
No issue but you will not be able to run turbo timing.
Old 11-30-2013, 08:33 PM
  #4899
pword's Avatar
Trader Rating: 30 (100%+)
what's a good esc/motor combo for 1/10th 4WD buggy? track size is medium to large indoor. thanks!
pword is offline
Old 11-30-2013, 08:41 PM
  #4900
Zero timing the justock esc is a good unit can run down to a 8.5T.
Turbo timing the stock spec or the v3.1 120 amp is perfect runs down to 3.5T but also csn run in zero timing mode.
Old 11-30-2013, 08:45 PM
  #4901
Perfect! Thank you.
sonspit is offline
Old 11-30-2013, 08:46 PM
  #4902
FastPete's Avatar
Trader Rating: 44 (100%+)
Theres Cobra! +1
FastPete is offline
Old 11-30-2013, 08:55 PM
  #4903
I have a 4068 2250kv sensored motor, what size bearings are in it? I'd like to replace them.
Hinecken is offline
Old 11-30-2013, 08:58 PM
  #4904
pword's Avatar
thanks for the super quick response.
pword is offline
Old 11-30-2013, 09:09 PM
  #4905
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default This is a great setup for 4WD Buggy!
This is the combo I would suggest for a 4WD Buggy, this is what I run in my B44.2 and it is ultra smooth and killer fast!
XERUN 120 Amp V3.1 ESC
XERUN V10 6.5 Turn Brushless Motor
If you don't have it I would pick up the programming box as well as they are amazing and can program any setting you need pitside without a laptop!
Good Luck!
JFuel11 is offline
