Speed Passion Thread >
Like Tree4Likes
Old 02-12-2012 | 10:13 AM
  #1036
Does anyone know if the speed power batteries come with the balancer connector or do i need to order one seperately.
cm.stites is offline
Old 02-12-2012 | 02:32 PM
  #1037
I'm in need of a replacement capacitor set for a 2.0 LPF esc, but the only thing I see on the site is the optional high power cap bank. Is that the only thing available?
KSimmonds is offline
Old 02-13-2012 | 11:29 AM
  #1038
DoubleRJef's Avatar
Ayone know if the GT2.1 Prostock esc has a blinky feature? I have boost and timing shut off and no blinky, is there another setting that needs to be changed or does it not blink?
DoubleRJef is offline
Old 02-13-2012 | 11:50 AM
  #1039
You would need to change the software to the no timing for it to operate in blinky mode.
Old 02-13-2012 | 02:35 PM
  #1040
Lenman73's Avatar
I changed the software on it via computer and what not, have no timing but it still doesn't blink. Is this normal?
Lenman73 is offline
Old 02-13-2012 | 03:51 PM
  #1041
if you changed it to the non timing blinky mode it should be flashing but it may be hard to see because the light is usually towards the bottom. which firmware did you put on it?
Old 02-13-2012 | 04:06 PM
  #1042
Lenman73's Avatar
I put this 110323STOCK on the esc and this V1.07_110119 on the programmer box.
Lenman73 is offline
Old 02-13-2012 | 04:11 PM
  #1043
That's the boost program. You need the no boost firmware. I forget the number offhand.
Dave H is offline
Old 02-13-2012 | 04:16 PM
  #1044
Lenman73's Avatar
Oooops. I thought I did the right one. Is it the esc or the card I got wrong?
Lenman73 is offline
Old 02-13-2012 | 04:19 PM
  #1045
ESC
Dave H is offline
Old 02-13-2012 | 04:22 PM
  #1046
Lenman73's Avatar
That might explain why it don't blink then. lol
Lenman73 is offline
Old 02-13-2012 | 04:23 PM
  #1047
i believe 508 is the non timing firmware its on version 1.35 i believe
Old 02-13-2012 | 04:32 PM
  #1048
Racecrafter's Avatar
528?
Racecrafter is offline
Old 02-13-2012 | 04:42 PM
  #1049
Lenman73's Avatar
Thanks I will give it a try.
Lenman73 is offline
Old 02-13-2012 | 05:50 PM
  #1050
MOmo's Avatar
Originally Posted by Jake S
sounds backwards.
Originally Posted by Dave H
Just kidding, it's late, yes, I agree, the motors seem backwards.
Here is the way I see it. I race on a smaller tight Indoor track with a straight that might be between 80 to 100 ft. Come summer, when many will switch to an outdoor track, I can see the choice in motor changing.
With the 2wd, i figured I would need to go a tad faster. Talking with a pro, he said that he was almost at the max running 7.5 in 4wd, so i figured if I up the timing and changed to boosted software, an 8.5 in 4wd could be made quick.
Originally Posted by cm.stites
I run the lpf in my dex410 but im only running a 8.5 i have ran a 6.5 on it in the 4wd with no issues but if your wanting a-lot of boost i would use the pro.
What's a realistic amount of boost one needs in 2wd and 4wd?
MOmo
MOmo is offline
