Speed Passion Thread
#1786
Wondering if anyone has some tips for a B44.1 running 8.5? Trying to maximize the 2.0 gt2. Right now it's on mod, but factory settings. I'm also using a 3pks radio, and I could use some assistance theresa well.
High traction, clay, somewhat small with one moderate straight.
Once I free up some money, I'll likely pick up the new reventon. So for 4mod, obviously the pro, but what do people like for 17.5?
Momo
Momo
#1788
you can play with the DRRS (punch) and other settings at will to see if you can tweak it a bit for a feel you like best. the factory firmware should be 205mod and will work great for that car with minor adjusting. You could try other firmware as well. There are some driver setups to get some ideas from on the website. you can copy one of those and then adjust settings for personal preference as well. (speedpassion.net)
I would probably say to gear it around 21/81 for a smaller track.
Momo
Momo
#1789
The early 1/10 scale GT V1.x speed controls could also run brushed motors. Now everything is only brushless. All SP motors are brushless.
#1790
Just got done installing a GT2.0 Pro in my new Losi 22sct with an LRP 10.5.
I updated to 428 Mod Software
I have been running 328 Stock in my SCTE 4pole and my SC10 17.5 and it feels great but figured a 10.5 is a mod motor so I opted for the Mod software.
IS the only difference in between Mod and Stock software the default values?
#1793
Cain, do you remove all the default boost and turbo that the stock software has?
I run 0 turbo and 5 boost for the Hobbywing motor and 0 turbo 10 boost for the Tekin Pro4.
I also turn the DDSS(punch) down to 5 or 7 depending on the track.
#1794
yup. I turned everything basically off or to a really low setting. No boost which if I recall correctly is timing throughout the whole RPM range, etc. I used about 5 - 10 degrees of turbo starting at I think 3000 RPM or whatever was factory default. The Pro 4 really didn't need much more than that and was very fast with lots of power.
I also run a lower DRRS setting too, I think it was 6 or 7. I tried 9 but it seemed to use more juice for little benefit.
#1795
Reventon Pro, does run a blinky softawre "Stock0".
#1796
Here's a pic of mine in my DEX210.
#1797
The boost I do run is because I ran an RX8 with the pro4 for almost a year before putting in the GT2.0 Pro.
The only change I made was ESC and it felt slower. So I added some timing and it really woke up. I think its smoother with the GT 2.0 Pro and with the added timming just as fast and runs about the same temps as it did with the RX8.
The Hobbywing did not feel as flat as the Pro4 did but 5 on the boost makes a noticeable difference. I think I could add more timing to the Hobbywing and still have safe temps but its faster than the Pro4 so why push it.
#1798
#1799
328 Stock is the software that the GT2.0 Pro was running
So there is more difference to 428 Mod and Stock than just the default profiles?
The other software always had different numbers so I figured they were different.
#1800
I'll give 428 Mod a look and see how it feels. I went 428 stock though since 323 stock was recommended previously when I asked and one of the setups, well, probably like theonly one for SCT 4x4 uses 323 stock (memory here, could be wrong).
So, am I correct in assuming then that 428 Mod is less aggressive in comparison to stock?
4Likes
