Like Tree4Likes
Viper RC -
Old 01-28-2015 | 11:46 PM
  #11521
Originally Posted by nikos2002
Great question -- there isn't a perfect set up, unless you fine tune it for yourself -- If your racing start with Profile 5, run the truck, see what temps your getting, and what you need more of - power or speed. If you need little more bottom end power, Raise Punch slightly - lower Motor Timing slightly. If you need more speed on straight, Raise Motor Timing slightly - lower Punch Slightly. But keep an eye on your temperatures (motor and speed control) to make sure your not running too hot.
Nick/Viper
Hey Nick - you raise a really good point here. How does one go about tuning their ESC and Motor combination for the track?
E.g. I was on a 7.5 and my mates were on 10.5 and my car was really edgy and super punchy; it was almost undrivable. I also have an AE B5 - with a 10.5 motor, it was so graceful around the track but with a 7.5 it became a lot more slippery.
I can't help but think if I knew what I should be changing on my ESC and motor timing, I could help myself out a bit. Ideally would still like the responsiveness in the trigger finger, but at the same time for the punch to be a bit lower so as I came up on the throttle, it wasn't causing the rear tires to lose traction.
WagwanBumba is offline
Old 01-29-2015 | 04:26 AM
  #11522
wagwun
Run blinky
Raise throttle pwm freq
Lower throttle punch
Lower physical timing on motor
kwiksi is offline
Old 01-30-2015 | 12:03 AM
  #11523
Originally Posted by kwiksi
wagwun
Run blinky
Was a bit difficult on an LRP X20, when the timing is changed by inserts and 27.5 degrees is the lowest! I've changed motor for now
Old 01-30-2015 | 09:36 PM
  #11524
nikos2002's Avatar
In your case - guess your using VTX10 or 10R -- There is actually a Punch setting under Throttle. Lowering Punch is kind of like traction control - it will help keep the wheels from spinning if you get on the throttle too hard. But you still get top speed at the top end. Also you can reduce Forward Power under the Misc Tab. This will limit overall power to the motor to slow it down - make it more controllable. Try one step at a time and don't be afraid to try big switch like 15-20 points to really feel the difference. That's what testing is all about.
nikos2002 is offline
Old 02-01-2015 | 01:44 PM
  #11525
Cain's Avatar
Tech Legend
alright got a question for the viper crew.
has anyone noticed an issue where the chimes that the VTX8 makes stops? Curious if that is a sign of anything to watch for in general.
Also, anyone using a Futaba FHSS receiver and an Xpert servo with a VTX8, one of the higher voltage brushless ones, please shoot me a pm as I have a question for you.
Cain is offline
Old 02-01-2015 | 01:51 PM
  #11526
bds81175's Avatar
Moderator
From what I understand, any noise made by the ESC is made by pulsing the motor. So I suppose it's possible that there is a problem with the connection to the motor or the motor itself could be damaged? I think you still get the tones even if the sensor wire is unplugged so I don't think that is it (check it anyway....I'm old and forgetful).
bds81175 is offline
Old 02-01-2015 | 01:57 PM
  #11527
Any issue running a vtx10be in a dex410 with either a 9.5 or 13.5? Brand new to the 4wd world. Thanks.
nordfink is offline
Old 02-01-2015 | 03:06 PM
  #11528
I have a question I have a vtx10 and was running a 13.5 in the factory 13.5 boosted profile in my b4.2 and it ran pretty good but everyone else is running 7.5's & 8.5's so I put my 8.5 in & tried it on the non boosted profile and the 8.5 is not as fast as the 13.5 tried the 8.5 in the 13.5 boosted profile and it is a little better and I have the timing turned up on the 8.5 any ideas what I need to do.
Tas4 is offline
Old 02-01-2015 | 08:16 PM
  #11529
bds81175's Avatar
Moderator
You should tell us what boost settings you are using and what gearing you are running for both the 13.5 and the 8.5. Also, what type and size of track you are running on.
bds81175 is offline
Old 02-02-2015 | 05:51 AM
  #11530
I am running on a medium sized indoor hard packed clay dirt mixture running a 81 - 22 on a b4.2 I am running the factory profiles that are loaded in the control that are in the instructions.
Tas4 is offline
Old 02-02-2015 | 06:15 AM
  #11531
bds81175's Avatar
Moderator
You will need to gear the two motors significantly differently. I've never run a 13.5 before and it's been a while since I ran an 8.5 buggy but you should use the gearing chart for the B4.2 as a reference point just to get started. I end up gearing to temp and feel. If they are both Viper motors you could probably go up a tooth or two in pinion from whats on the chart. Anyone else run either of these combos want to chime in?
On a related note, do you feel like you need more power? If you are a relatively new racer and the fast guys are blowing you away on the straight, don't fret it until you can run good consistent laps without crashing. Races aren't lost of the straights, they are lost in the corners.
bds81175 is offline
Old 02-03-2015 | 01:25 PM
  #11532
nikos2002's Avatar
Sorry guys - couple days without wifi slowed me down some:
Tas4 - you should be quicker with a 8.5 than a boosted 13.5 -- I have seen pro drivers gear 81/23 with 7.5, so might need another tooth on pinion. Also is the motor new or is it old. If its an older motor, rotor may have lost some of its magnetic power. Also check your esc settings - default should be pretty close in Profile 2 - maybe adjust Punch depending on traction and driving style.
Cain - noise is actually generated by the motor. Any issue on motor or with connection can cause noise not to happen. Looking into the other things as well will email you about it later.
nordfink - VTX10 is good down to 6.5, in a 4wd car a 9.5 or 13.5 would be ok - would be extremely careful if you try and use boost that could be little tricky if not set up right.
Old 02-03-2015 | 03:58 PM
  #11533
boborc's Avatar
Nick are there 2 different fans for the VTX8 ordered a 30mm viper30hvfan right size but it has a different connector on it and will not fit in the vtx8 esc
boborc is offline
Old 02-03-2015 | 04:11 PM
  #11534
boborc's Avatar
Spoke to amain seems to be missing connector, What do you call that plug that goes into the esc fan port
boborc is offline
Old 02-04-2015 | 04:45 AM
  #11535
Default vf8 motor
Today, i had a chance to try my 1900kv on my xt8 truggy. i mate motor with sct pro esc and gear ratio was 18/44. i am using 50k silicone oil on center diff. i drove it on little rough grass surface. Car performed very well but power delivery was much smoother. i was using 1515 2200kv castle motor with rx8 esc and16t pinion and vf8 gives me same punch. very impressed. however, motor temperature was 185 degree fahreneit which is 24 degree more then the castle motor. Overall, i am happy with that. i will probably buy another xt8 and put this setup to use it with my brother. i will upload a video of first use as soon as possible.
murat61 is offline
