Viper RC -
#4022
these caps aren't like the others were u need another one on the receiver. even with the stock capacitor in b44.1, i don't need an extra with a savox servo, were others need to put a cap on the receiver along with one on the speedo.
btw 21 81 on a b44.1 8.5 is a speed demon, i am just as fast as full timing 7.5 and just behind a 6.5. Got 2nd in the a with my viper setup in 4wd.
#4025
Looking for some thoughts here. Ever since ive switched to the copperhead esc/5150 combo, i cant finish an 8 min main in my scte.....so yesterdays race i put in my castle 1410 motor w/ 16t to assure myself i could finish. I had tq for the day and did not wanna dump at 7 mins or so as i have been. Needless to say last lap and i dumped. Ive tried 3 different lipos that i use, 2 nano 6000 65c and a promatch 60000 60c.......ive used thes for some time and dont think they are worn out yet. Ive got the lvc set to 3.0v/cell. Is there other changes to the esc i should make? Like punch control,etc.....ive set timing to 0 already.....im so frustrated w this lately dont know what else to do except try a new lipo
#4026
Have you balanced your LiPo's lately? Do you verify that they are are fully charged to capacity. Just because they read 8.4 volts doesn't always mean teu are at max capacity.
If the same thing happen with both systems it sounds like battery? Maybe gearing down? As stated before there are a couple different factors that can effect overall run time.
#4027
#4028
1st try gearing down - make a jump of 2-3 teeth and see the results= run time, speed, battery length.
As for the speed control - you can try running a little lower all around with Punch, Timing and Power. Even high brake settings can cause a system to be inefficient.
Just seem strange that it happened on two different systems and the only common part was the batteries.
#4029
really silly question here but your not running lights, or multiple fans are you?
#4030
Nitro im running the vx4r51 to on 2 different tracks (prcr,trcr) and i have no problems making 8 min at all in fact i could run 10 min mains with 3-4 practice laps. Im running gens ace 5000 40c packs, i normally only put 3800 to 4200 back in depending on if i was pushing it hard or not. Im running the aaron lane setup tweaked to my liking a 14t pinion. Here is the settings i have for the most part it is just profile #5 tweaked to my liking.
brake strength- 10
brake curve- linear
drag brake- disabled
throttle punch- 7
throttle curve- linear
dead band- narrow
motor timing- 7
run mode- fwd only
start power- 10
fwd power- 10
battery cut off- 3.0v
Hope that helps you some!?!
Btw i ran one of my buddies promatch 6000mah 60c lipos last night and only had to put 3500 back in there. Shouldnt be a reason you cant make a main. I would do a tear down of your truck and see if you have some bad bearings or diff gears/pins going out!!
brake strength- 10
brake curve- linear
throttle punch- 7
dead band- narrow
motor timing- 7
run mode- fwd only
start power- 10
fwd power- 10
#4032
hi guys
i am having a bit of trouble with my both of my ESC's 10 & 10r
when i turn them on after i turn on the radio they will not link but if i turn the radio off then back on while ESC is on they link and this is not just happening to me the same thing happens to a fellow racer. also some times i can not turn them off with the button i have to disconnect the battery.
any idea's
cheers
any idea's
cheers
#4035
hi guys
any idea's
cheers
any idea's
cheers
Also, if you are running allot of expo in the throttle it will multiply it.
Widening the Dead Band in the ESC can help. Also, try re-doing a calibration (make sure your brake and throttle EPA is at 100%), then trimming down 2 or 3 percent or up 2 or 3% from neutral.
Or, you can turn the car on first.
4Likes
