Like Tree4Likes
Viper RC -
Old 01-02-2015 | 06:25 AM
  #11371
Originally Posted by Cain
I see combo's out there for back orders, which one in particular?
Thanks Cain,
wanted a 2.1 combo, but will wait for the newer stuff. Hope its ready for easter, then again I have a friend in Fl who will take it with him.
AEWER is offline
Old 01-02-2015 | 08:43 AM
  #11372
Cain's Avatar
Tech Legend
nikos: what is the warranty length on the new black edition motors?
Cain is offline
Old 01-02-2015 | 08:46 AM
  #11373
the paperwork that came with my motors says the same 120day free from manufacture defects.
micrors4guy is offline
Old 01-02-2015 | 08:48 AM
  #11374
Cain's Avatar
Tech Legend
okay good to know. Wasn't sure as the VST line was 180 days so wanted to confirm if it changed.
Cain is offline
Old 01-02-2015 | 11:48 AM
  #11375
Default got a problem
I went last night to club racing here in Phoenix and ran practice then got ready for the first qualifier and one min in to qual and my losi sct 22 2.0 mm setup with a vtx10r and viper 13.5 motor just stopped. When I took the truck off the track I checked the temp on the motor and it was 140ish. On the truck I run a 84 spur gear and a 22 pinion with 10 degrees can timing and the 3rd profile loaded on the esc. I swapped out the sensor cable and that didn't fix the problem so I changed the motor to a new black edition motor 13.5 turn motor I just got. The second qual I ran same set up and it was great but when I pull the truck off it was 190 degrees which I know that is way to high. So I changed the profile in the esc to blinky so I had no boost from the esc and put the can timing to 30 and ran the main like that and after the main it still temped at 190. Is there something wrong or should I really change the gearing or do you think there is a bearing hanging up or what?
jdutch03 is offline
Old 01-02-2015 | 12:00 PM
  #11376
Is it the motor of the esc getting that hot? if this is the 1st time running that gearing I would suspect it would be the gearing. if not i would look at the wires.If they are old try some fresh wires as well as checking the bearings in your drivetrain.
Old 01-02-2015 | 12:18 PM
  #11377
Wildcat1971's Avatar
22/84 should not run 190. check your mesh and check for binding. how was your traction and slipper? excessive slip of the slipper or tires can raise temps. SRS is pretty high bite, so I doubt your tires were slipping.
Wildcat1971 is offline
Old 01-02-2015 | 04:46 PM
  #11378
Cain's Avatar
Tech Legend
if I recall correctly, the new black edition "spec" motors use a 12.3 rotor right?
wonder if that includes the 13.5 as a "spec" motor and hence I would think the motor would be more RPMish if using a 12.3 rotor.
Did the motor come with any gearing ratio suggestions?
When running in blinky mode, did you happen to notice where the vehicle was topping out down the longest straight?
Cain is offline
Old 01-02-2015 | 05:12 PM
  #11379
Default Feedback
Hey all, strongly considering getting the Viper Copperhead VXR.45 motor/esc combo for my 4x4 Slash which is brand new. I've another Slash that I've raced with the Castle 3800/MMP combo and like it a lot. I'm looking for more insight on this Viper setup...... I really like the price too...... anyone have extensive use with this setup in a Slash 4x4 ? Thanks guys.
speedracerbg is offline
Old 01-03-2015 | 09:00 PM
  #11380
Graham11's Avatar
Does the viper vtx10r have reverse polarity protection or are you SOL if you put bullets in wrong holes even when power is off?
Graham11 is offline
Old 01-03-2015 | 09:01 PM
  #11381
DustinH's Avatar
Do any esc's have that feature?
DustinH is offline
Old 01-03-2015 | 10:44 PM
  #11382
Baja-Boy's Avatar
I have not read anywhere that it has that protection, as in general any esc should never be plugged in the wrong way. I guess if you really worry you could use plugs instead of bullets.
Baja-Boy is offline
Old 01-04-2015 | 12:33 AM
  #11383
nikos2002's Avatar
No - none of the competition units I have ever seen do -- too bulking to put into the system. Novak did it years ago with a brushed esc, but I still fried some soldering wires on batteries backward.
nikos2002 is offline
Old 01-04-2015 | 12:35 AM
  #11384
nikos2002's Avatar
Great little combo for the Slash - its what it was designed for. Has the performance of some competition systems at 1/3 of the price. You can even get an EZLink and adjust the settings if you like - don't need it, but its a tool if your racing with it. As with any system, gear it right, keep an eye on the temperature of the motor and speed control - it will be a great upgrade.
Old 01-04-2015 | 12:41 AM
  #11385
nikos2002's Avatar
All the spec style motors (10.5 to 21.5) come with 12.3 rotors.
Would need some more information - when it stopped were there any error lights flashing to show overheat? Was the 190 measured right after the main, how long was the run? What other settings were using with Profile 3, it can make a difference. As mentioned, any issues with drive train, gear mesh etc. All the BE motors are tested before delivery (its how we put the KV numbers on the box, so if there was an issue with a short or something, we would find it then. You can PM me the settings or email me at [email protected] if its easier.
