Like Tree4Likes
Viper RC -
Old 01-04-2015 | 04:57 AM
  #11386
Originally Posted by nikos2002
Great little combo for the Slash - its what it was designed for. Has the performance of some competition systems at 1/3 of the price. You can even get an EZLink and adjust the settings if you like - don't need it, but its a tool if your racing with it. As with any system, gear it right, keep an eye on the temperature of the motor and speed control - it will be a great upgrade.
Thanks for the reply. Also meant to ask about pinion choice, since I currently don't have any 5mm ones. What would you recommend picking up ? 13, 14, or 15? I'm running a 54T on my diff. Thanks again for any insight, I appreciate it.
speedracerbg is offline
Old 01-04-2015 | 12:44 PM
  #11387
afm237's Avatar
I solved my heat issue, used 4321mAh ov a 4.6mAh> Motor was at 127deg when I pulled in
Steve
afm237 is offline
Old 01-04-2015 | 02:06 PM
  #11388
Graham11's Avatar
No - none of the competition units I have ever seen do -- too bulking to put into the system. Novak did it years ago with a brushed esc, but I still fried some soldering wires on batteries backward.
Well I ask because I put one bullet in wrong and just barely touched the other bullet to the battery and it seems to have fried not only the ESC but also the brand new battery. I assume the vtx10r is done as well as the battery? No warranty I assume
Graham11 is offline
Old 01-04-2015 | 02:35 PM
  #11389
Ordered ! Just placed my order for the Viper VXR.45 combo.... ordered a 14 and 15 tooth pinion to try out too. Super excited to try it out in the Slash 4x4
Should be here in a couple days.
Old 01-04-2015 | 03:07 PM
  #11390
That should not have killed the battery.
micrors4guy is offline
Old 01-04-2015 | 04:07 PM
  #11391
Baja-Boy's Avatar
Voltage is more like a force than time related like current, so it's like putting 1000lb force on a piece of wood for a split second, it will still break the wood.
Batteries for sure do not like to be shorted, for any amount of time. I am not sure if the reverse polarity would allow for a short of the pack via the esc.
Baja-Boy is offline
Old 01-04-2015 | 04:31 PM
  #11392
Graham11's Avatar
Well it def shorted the battery a killed a cell... Brand revtech x formula too... Sucks but first esc and battery I've ever broke/fried so as much as it sucks... It happens
Graham11 is offline
Old 01-04-2015 | 06:30 PM
  #11393
nikos2002's Avatar
Is it possible the battery was bad? I had a local driver ask me about an issue a few months back. He put in 4 speedos and overheated all of them. We figured out the battery had a short in it. Once he used a different battery. All 4 units worked without issue. It was a 'big name' battery company. Yes it can unfortunately happen.
nikos2002 is offline
Old 01-04-2015 | 11:46 PM
  #11394
I still can't understand why battery manufacturers don't make the positive a 5mm bullet and the negative a 4mm built connector, would prevent this ever happening!
Badger5 is offline
Old 01-05-2015 | 07:19 AM
  #11395
@Nikos,
sorry to ask for something that may have been asked before, but Im still not looking threw which C rate should be the minimum for the VTX8, will I have an advantage taking the highets possible C rate, and if I do that, how should I get loads of amps through 12 awg wires? Will I need XT 90 connectors then instead of XT 60 ? My thoughts are, that if there is one piece not big enough for maybe 150 amps, a 200 amps esc, a lipo with 65 to 130 C discharge are worthless. Wouldnt in the ral world a lipo with 5000 mah and 45 C be more then enough?
AEWER is offline
Old 01-05-2015 | 07:23 AM
  #11396
Wildcat1971's Avatar
I did that last night to my orion. It is dead now. It just takes a tap. My fault for not wiring my car to make it impossible to screw up.
Wildcat1971 is offline
Old 01-05-2015 | 07:51 AM
  #11397
King DORK's Avatar
I'm looking for an "honest" opinion here. First off, LOVE my Viper escs and Nick is one of the best guys to deal with. So, looking to get back into 4x4 corr racing. Had a Tekno SCT410 and likely going that route again. Started with a Pro4 4600 motor which was okay but switched to a Hobbywing 4700 (545 can) and really liked the grunt this motor had over the Pro4. I'm curious if anyone has had actual experience of running a Hobbywing an then the Viper VF4 4500 and how it compares. There is a $50 or so price difference between them.
King DORK is offline
Old 01-05-2015 | 08:05 AM
  #11398
The vf4 4500 is a great motor and a SUPER value for the where they have them prices currently. I would compare them directly to the pro 4 4600. For the price difference you could really scoop up a 4000 and a 4500.
Old 01-05-2015 | 08:40 AM
  #11399
Cain's Avatar
Tech Legend
yeah, the viper direct price sold me to give it a try.
Cain is offline
Old 01-05-2015 | 08:50 AM
  #11400
Baja-Boy's Avatar
Originally Posted by AEWER
@Nikos,
Is this for 4s or 2s?
The vtx8 is listed as a 220amp esc. Bullets are probably the best connector for high amp situations. If you are using 12awg wire high strand count means lower IR but I'm not sure how much of a difference it makes. I used deans plugs and 25$ hobby King 4s batteries in my E buggy and could genuinely say guys running 180$ high C rating packs had no real advantage.
Baja-Boy is offline
