Viper RC -
#8716
have a issue with my motor. its the 8.5. Was runnign fine earlier in the day but seemed like it was cogging a little after I crashed. So when I started the main it was good then I lost power to the motor, then it would go again then it started cogging and I pulled it off the track. Got back to the pits and I tryed it again and all it did was make like a beep nosie coming from the esc and I could feel the motor try to turn and it started cogging and again and then it stopped and I seen just a little smoke come from it. What could be the issue? Im very picky about my equipment and Im running blinky and with bascially all the standard esc settings. Motor wasnt hot and the esc was not either. runnning it in a 22 buggy with the stock spur with a 23 pinion. If the motor is bad what is the warranty with the motor? I have not had it a year yet.
#8718
Could someone here tell me what's up with the viper VSE motors?
I cannot find any info on these motors? Are they still for sale? How do they perform?
I know they are two pole and larger than most 1/8 motors, but it's almost like no one ever dared to try one, what gives?
#8719
. It explains all of the adjustments very well and I reference it often. Heck, if I can understand it, they made it VERY easy to understand
#8720
This has nothing to do with Viper, or RC for that fact, but if you can't appreciate these lunatics, then you have something wrong with you!
http://www.youtube.com/watch?v=FOuh6D5Q_4I
#8721
ok so I messed with my car after getting home from the track. The sensor wire was kind of on a bad bend the way I have it mounted but still have the same one on there just changed the bend. The motor seems ok and no cogging and runs fine but.... it seems like I have 10-15 percent drag brake on but Im not running any drag brake. Took off the pinion and the tranny is free nothing binding. Sugesstions?
#8723
tony - if you are used to taking them apart (not everyone is), take the motor apart and look at the rotor, it should have no marks, scratches, grooves or anything on it. Second, look at the wiring in the motor, it should be copper color, its starts out as shiny, gets a little duller from heat as you use it. If it looks dark brown or black (even on just one side), it means at some point the motor got too hot. Either one these can give the same effect because the magnets in the motor are not allowing it to spin properly.
some guy - VSE was our first attempt at 1/8 motors and we really had 2 issues. 1) we were coming out with 2 pole motors when everyone was making 4 pole motors. 2) we got bad feedback on how the motors performed in testing. Sold some to the public and it was not good. We only sold a few, some had issues. We shelved the whole project and focused on 1/10 stuff.
Now with the VTX8 such a success, it was time to re-visit 1/8 motors. We have spent the better part of the last year running the motors, to make sure they were fast, consistent, and durable. Even now as we are doing production, we keep testing and found another thing we are "changing" in the final design before the public gets them. Our goal is to make a product that is fast and durable for you. We want it right the first time, not sell it make money and figure it out later.
#8724
#8726
I was able to run my Caster racing Rapture 4wd sct with the Viper 4 pole motor and vtx8 esc. After gearing the motor down again and gave the sct more steering the truck was amazing... Here is my A2 run and as I did get 3rd I was only about 1 sec behind 1st
This motor has SO much power that I now have a 12t on it, I was running a 4600kv tenshock with a 14t and this Viper 4500kv still has more power then the tenshock and I have my punch at 80%
#8727
I picked up a VTX8 and Tekin 1900kv motor to run on 4s in my Mugen techno v4 buggy. I read a couple hundred pages of this thread and did not see anyone post any settings for this combo.
Whats a good place to start? I'm running 14/46 with 80 punch and the rest standard settings on profile 1. It runs amazingly well and stays nice and cool. Motor/esc both around 110.
The brakes were a bit weak to start, and I've turned them up to 100 and played with the PWM some to get it to feel better.
#8728
That's the combo I have in my Tekno buggy too. I haven't mucked around too much, I'm not sure what my settings are for a lot of things.
I have punch at 100 but I am thinking of turning it down to 80 as I can take the big jumps at my track too easily now, when I line it up and get everything right.
Profile 1 is a good place to start, just set your LVC to suit.
#8730
Make sure forward power is set at 100, and as always keep an eye on your motor temps until you are confident that you have the proper gearing.
4Likes
