Viper RC -
#6346
I want to run a VST 4.5T motor on a large outdoor track, where high RPM is more important than torque. As I understand, the 4.5T comes with a 12.3mm rotor and a fan.
- Should I remove the fan form the rotor to achieve higher RPM? Do you think that might damage the motor?
- If I replaced the rotor with an optional 12mm, would it suit my track better?
Thanx!
Thanx!
#6347
$189.99 for the VTX8 w/o ProGauge and IN STOCK!!!
And $209.99 for the VTX8 w ProGauge also in stock.
#6350
My progauge does not "connect" when I try to use it. I hook everything up according to the directions but when I hit the "ok" button to go into the menus the "connection failed" message appears.
I've hooked it up all sorts of different ways just to be sure. I've re-checked everything to be sure it's done properly all to no avail.
HELP!!
HELP!!
#6352
HELP!!
HELP!!
I had this happen once but I forget why...and it only happened once.
#6357
#6359
Wires will be per-soldered on esc for you. Just have to add the type of plug you are using for the battery and solder to motor (A-A, B-B, C-C).
#6360
Two biggest mistakes we normally see when people plug in the ProGauge is:
- car has to have power to start with
- after gauge is plugged in, push the Vport (power) button one time. You will see the orange and red lights on the VPort, then choose link device.
You don't have to hold the button down but you do have to actually press it. Don't worry, it can take it.
4Likes
Didn't work any of the multiple times I tried. Thanks for trying to help. Any other ideas?
