Like Tree4Likes
Viper RC -
Old 05-12-2013 | 11:43 PM
  #7846
nikos2002's Avatar
Depends how "hard" you hit the cut off. If there is a big spike or drop in voltage, it will shut off. If its getting really close to cut off, but not quite, it could stutter slightly or even slow down power - because its trying to protect the circuit.
nikos2002 is offline
Old 05-12-2013 | 11:44 PM
  #7847
nikos2002's Avatar
Interesting comments about the capacitors -- guess I don't land hard enough
That has to be a pretty big thump, or several thumps - those things are soldered on pretty good (if you ever tried to get one off...)
Old 05-13-2013 | 04:37 AM
  #7848
Jim Hustins's Avatar
The one I saw had already been damaged from getting caught in the drive shaft. Then the force from landing was causing the previous damage to cause problems.
Jim Hustins is offline
Old 05-13-2013 | 05:28 AM
  #7849
Originally Posted by godofcable
i'm leaning heavily toward the voltage on the batts, when you punch the throttle the voltage drops, it would be very easy for it to trick the LVC on the ESC and cause it to stop.
Let us know if it happens again
It was overheating...After running 4-5 more batterys through it, im sure the voltage is not the issue. The batt voltage just threw me for a loop.
It has overheated a couple times now. I am geared 13/54 on my slash and I dont want to gear down but threw a 12t pinion in. I also reduced punch to 2 and starting power to 2. The top end really suffered so I upped the timing and it seems to be running ok. I was only able to overheat it once by going WOT for 45sec -1 min.
I will have to change out my electronics to suit my driving style on a 3s setup.
boostem is offline
Old 05-13-2013 | 10:06 AM
  #7850
eper's Avatar
i got to hand it to nick.. I just started following this thread about 2 weeks ago and he is really on top of it.. Hats of to you nick,very impressive and makes me look forward to running the viper line up. Placing my order tomorrow at like 4am when my electronic funding hits.. lol.
hustins and medina are you guys running the goshen race? Trying to get a 2wd mod sc class going. the surface is mostly very low cut grass so a couple guys who have run the viper equipment may come in handy as heat becomes a issue with any esc and motor combo.
eper is offline
Old 05-13-2013 | 03:01 PM
  #7851
Whats the info on the Goshen race?
Old 05-13-2013 | 05:46 PM
  #7852
Any idea when the VTX8's will be back in-stock?
J_Fowler is offline
Old 05-13-2013 | 06:30 PM
  #7853
I heard about 2 weeks. It is worth the wait. I am waiting for my 2nd one to put in my new Ebuggy. The one in my SC8 is so smooth.
Nick will chime in when he has a better idea of when they will be in stock.
Old 05-13-2013 | 07:03 PM
  #7854
pal00's Avatar
I was also told about 2 weeks. it will be cutting it close for the short course scramble.
pal00 is offline
Old 05-13-2013 | 07:05 PM
  #7855
pal00's Avatar
Tom is that Race 1 or 2 days?
pal00 is offline
Old 05-13-2013 | 07:09 PM
  #7856
pal00's Avatar
Lol. totally my fault Nick. I did not have is zip tied properly. the new Losi 4 by 4 is much longer for the sensor wire and I did a quick fix until I got a new one.
pal00 is offline
Old 05-13-2013 | 08:40 PM
  #7857
nikos2002's Avatar
Hey guys, thanks for the nice words Tom, its all part of the service!!
Traveling to the home office in beautiful Redmond WA tomorrow, will pass along any updates I get when I arrive.
Old 05-13-2013 | 08:47 PM
  #7858
Yeah I have to order my VTX8 when they get back in stock again.
Bob Barry is offline
Old 05-13-2013 | 09:13 PM
  #7859
Derry's Avatar
I have a couple vtx 10s that are experiencing the same issues. One is a warrenty replacement. After landing a jump they reboot. This usually only happens once a day and the first time on the track. But a couple times it has cost me a race. Any ideas of what it could be? Also fyi this is not always after a hard landing sometimes even over something like a stepdown it will happen. Although it has happened after hard landings as well.
Derry is offline
Old 05-13-2013 | 09:26 PM
  #7860
silvalis's Avatar
I would be checking your battery connections and your sensor wire.
Replacing the latter fixed my reboot issues on jump landings.
silvalis is offline
