Like Tree4Likes
Viper RC -
Old 09-07-2012 | 08:37 PM
  #5476
Originally Posted by mugenlife
Just took second place overall (should have had first place was in first place long enough lol) with viper copperhead 5150 and 4500 at Stateline's Friday night summer points series for SC4x4. 5150 in a OFNA NEXX 10SC and 4500 in a Losi SCTE.
Scratch that I won by 1 point so 1st not a second.
mugenlife is offline
Old 09-08-2012 | 06:51 AM
  #5477
ridgerunner1's Avatar
Nice WTG on your wins.
ridgerunner1 is offline
Old 09-08-2012 | 07:12 AM
  #5478
tony montana's Avatar
Originally Posted by DanielHolloway
From my experience, the Copperhead 4500 combo will put you where you want to be in the SCTE. That's the truck that I run, and that's the system I'm running. I can run with all the Pro4/RX8 combos all day, and mine is 30degrees cooler than theres. If you get that combo, go ahead and get the proguage at the same time. You won't go wrong with it.
thanks for the reply, My concern is that for one is its not sensored. Does the esc have a sensor plug in case I wanna get another motor that is sensored? Again my biggest concern is reliability is the number 1 priority. I know all systems can go up in smoke from user error.
tony montana is offline
Old 09-08-2012 | 03:48 PM
  #5479
nikos2002's Avatar
tony - its the smoothes unsensored system you will find. The software gives you control to adjust the starting power of the motor, which takes away the majority of the "cog" feeling. Our team drivers have been using them at events around the country and running with and beating more expensive systems. Like anything else, watch the heat, don't run longer than the length of your races in practice, it will last you just fine.
nikos2002 is offline
Old 09-09-2012 | 01:44 PM
  #5480
monteman1970's Avatar
what size/brand bullet connectors do you recommend for the copperhead motor to esc connection for a real nice tight fit?
monteman1970 is offline
Old 09-09-2012 | 04:24 PM
  #5481
stu541's Avatar
vper vtx10's with a55 firmware ran flawless again yest. tq and 1st in stock truck and bumped to get 7th in stock buggy. My VST 17.5 ran ice cold all day. I'm running 75/30 in buggy and 80/26 in truck.
stu541 is offline
Old 09-09-2012 | 06:21 PM
  #5482
nikos2002's Avatar
4mm should be it. I have heard some people slightly squeeze the end on the esc to help make sure its tight as well.
Old 09-09-2012 | 06:22 PM
  #5483
nikos2002's Avatar
Stu - congrats, glad you liked it
Old 09-10-2012 | 10:05 AM
  #5484
Getting ready to buy the copper head combo. Question thou, will it work ok with savox servos and spectrum rx's? Also is the pro gauge really needed? Prob will buy it in a month or so but do I need to it run it out of the box on my scte or is it ready to roll out of the box
Old 09-10-2012 | 10:07 AM
  #5485
DustinH's Avatar
I run mine with a voltage protector (cap). You can run it out of the box.
DustinH is offline
Old 09-10-2012 | 10:46 AM
  #5486
stu541's Avatar
Nick did you get my email?
stu541 is offline
Old 09-10-2012 | 11:36 AM
  #5487
Yeah I have a spectrum cap. Went ahead and got it ordered. Hopefully it last a good while. I went the cheap route last time with a cheap esc and it didn't last 2 batteries. So hopefully this one will atleast last me till the spring
Old 09-10-2012 | 12:17 PM
  #5488
Grasschopper's Avatar
Ahhh yes another BH to Viper convert. FWIW my LT4 didn't last 60 seconds (BEC died) and when I took it apart the soldering and care taken to layout the chips on the main power board was laughable. And then there is his "customer service".
Yea...glad I'm running Viper now.
Grasschopper is offline
Old 09-10-2012 | 12:58 PM
  #5489
Ok since the copperhead is sensorless can I run other sensored motors sensorless?
Old 09-10-2012 | 04:29 PM
  #5490
AndrewTom's Avatar
on friday night i ran my losi XXX-SCT at my local track in the stock division (17.5 w/ boost)I took second place! i was leading for a bit, but i made a few mistakes.
i ran 22/84 gearing with the ball diff trans (2.43:1) 15 deg. on the can.
30 degrees boost
start rpm 3500
finish rpm 12000
level 5 in slew rate, 22 degrees top speed timing.
A55 firmware
what does level 5 equivilate to in degrees/1000rpm.
i went from A19 to A55 firmware.
AndrewTom is offline
