Viper RC -
#4276
I have one small issue, so I think.
Copperheadr4.5
Coming down the straight or any decent size jump when I hit the brake trigger the truck comes to a stop. I have to go reverse 3 times for it to go forward again. I checked the pro gauge and it says forward/reverse. Did i put the wrong setting? It wasn't doing it before its just becoming more and more often. So far the esc has only 10 packs
I got fed up with it and took out reverse and it seemed as it stopped, but I still want reverse though
Copperheadr4.5
#4277
i use the 2 stage reverse setting. Which means the brake has to be pushed twice to activate reverse. this way I can use brakes - hard if needed, but still pull reverse as well.
One thing to remember because its unsensored - if you are rolling in reverse and try to pull the throttle - the system needs to think about it a second to realize what pole to apply the power to start forward - so it will seem like it stalls. Same thing can happen if you spin out or bounce backwards off a pipe. That's the only downfall of the sensorless system.
#4278
#4280
I run a VTX10r in my SC104x4. I don't run a viper motor at this time. My combo is the VTX10r paired with a novak ballistic 6.5 turn 540 motor with a 14mm rotor. This combo for my track has more then enough punch (I'm dialed down to 80%). I've wanted to try the 550L motor, I just have not because what I have is smooth fast and cool. I have my ESC protection set to 200° and have never hit it. I'd look into a 550 motor because your talking about a larger track. The 540 motor would be plenty for your small track.
Make sure you buy the 550l motor, not the 550xl for your sc104x4. Viper makes 2 550 motors, one (550l) was built for the sc104x4
I really wish there was a Viper sponsored guy in Denver so I could see some other products. It would be nice to bounce ideas off another guy in person. As it stands now, I seem to be the only guy running viper stuff.
#4282
After two rounds of qualifying at the 26th Annual Cactus Classic,Billy Fischer's Viper powered cars are running strong. Billy is 3rd in 4wd Modified after a great 3rd overall finish in round 2, that could have been a 2nd if not for getting tangled with a broken car on the last lap. He is also 10th overall in 2wd Modified after a 6th place finish in round 2. Billy is also 13th in Mod Truck, with striking distance of the A Main.
Bryan Eady is 2nd overall in the 13.5 2wd class with a 2nd and a 3rd in the two rounds. Qualifying is so tight that less than a second has separated the top 3 cars in each round. Bryan was actually in a TQ pace most of his 2nd round run until he got caught up in some slower traffic.
Nate Lavery is 9th overall in 17.5 2wd buggy. Good lap times but he needs to get a clean run in the next two rounds.
There is also a driver in the top 10 in the 4wd SC class, who appears to be using Viper products, but I haven't seen an 'official' announcement yet, so we will just wish him luck!!
Hope I didn't miss anyone. I don't know all the west coast drivers or if we have any customers using the products the this weekend.
2 rounds of qualifying today can make a big difference so fingers are crossed for good results and a fun day if racing for everyone.
#4284
#4285
Its a very, very tight fit. I have seen it done but you need to really shoe horn it in. Or cut the chassis a little to get it to fit. It doesn't effect the chassis.
Or you can get the 5.0L motor which we made to fit the sc10 4wd, slight less torque (how can you tell with 550), good fit for the truck.
#4286
Cactus Final Qualifying
2wd Modified
8th Billy Fischer
9th Travis Amezcua
13.5 Buggy
3rd Brian Eddy
17.5 Buggy
8th Nathan Lavery
Modified Racing Truck
12th Billy Fischer
4wd SC
7th Travis Amezcua
4wd Modified
5th Travis Amezcua
7th Billy Fischer
2wd Modified
8th Billy Fischer
9th Travis Amezcua
13.5 Buggy
3rd Brian Eddy
17.5 Buggy
8th Nathan Lavery
12th Billy Fischer
4wd SC
7th Travis Amezcua
4wd Modified
5th Travis Amezcua
7th Billy Fischer
#4289
I could be wrong but in 4wd sct i dont see a CC roar approved http://www.roarracing.org/?page_id=251 i did not think any 4 pole 550 or 540 was
4Likes
