Tamiya Championship Series
Panda,
You do not use a new set of sticker F1 tires every run?
You know the degradation of these F1 tires!
Watch out for the "Clag Field Off Line"
Just like the Pirelli F1 tires they go off after 5 laps then come back?
Remember how do you make a small fortune in F1 you start with a large one!
I hope we do not go to these spec tire rules like sedan?
Steve
Steve
In hindsight, our decision to switch from Renault to Mercedes power in 2014 was a wise choice and allowed us to log many miles in preseason testing. Through our data, we have come up with a comfortable but quick set-up on the harder prime tires. This has allowed us to get surprisingly good tire wear with only minor graining issues on the right front.
We will be participating in the FIA approved in season Pirelli tire tests (some call it the Speedtech GCR 8) to further test the softer option tires. If rumor is correct and Fred Ecclestone does later announce mandatory pit stops and the requirement to use both the prime and soft tires during each main race at the nationals, the data on the softer options at the Pirrelli tire test could be invaluable.
Panda
Tcs
Hi Steve,
Panda
Panda
Jon McLean
In my trips out there I have found if your car is working on used/broken in tires you really don't need more than a couple sets. I tried new tires but unless your car is working on brand new tires your car may be bananas until the tires have several runs. Pit tires last a long time in general. Mostly used tires will get greasy at the end of a run if they are too used up.
Figure out which way you want to go and either break in sets of tires or get your car working on freshies.
2014 TQ Carpet Championship Summer Series Round 1 is up this Sunday.
Track will be open at 8am, Race will start at 10am.
It will be a great warm up race for TCS on May 18th.
Click the link below for the race details.
http://www.tqrcracing.com/race/race_...asp?race_no=27
Thanks.
Thanks.
Tcs
Thanks.
Thanks.
Round #7 is on the same day as the TCS Nats at Tamiya Aug.23rd and 24th
1/12 GT at RC Madness TCS
We are going to run the RM-01 class at the RC Madness TCS race on May 10th, what's a good place to start with gearing, the last time I raced 12th scale was with 4 cell packs and brushed motors.
Thanks!
Thanks!
Here's a great resource for the RM-01. http://www.rctech.net/forum/electric...ng-master.html
Rollout suggestions HERE
Hello TCS racers!
I am releasing info about some new stuff on this thread since the racers that support TCS are so gun ho about new stuff.
Here's a list of what to expect in the coming months.
1. NEW M-05 VERSION 2 (NEW one-piece arms, motor moved, droop screws, square pack compatible, lighter weight, lower roll center)
Heyyyy everyone.
If anyone is planning on attending the TCS race at E-Mergent RC (AL) on May 18th, get yourself signed up ASAP!! It's only a little over 2 weeks away, and we need your registration information.
Racetrack Details:
E-Mergent RC
2118 Highway 72 E, Suite 4
Huntsville, AL 35811
256-852-6833
No. The M05v.2 will be allowed in TCS racing as soon as it becomes available. This also includes the TRF101W as well as the TB-EVO6
Racetrack Details:
E-Mergent RC
256-852-6833
Fred,
for the TQ race, is it ok for mini to use any tamiya tires or does it have to be the premounts?
thanks...
thanks...
General Rules; Clause #41
41. M-Chassis classes must use the Spec 60D Pre-mounted tire sets available. Items: 1016 (Super Grip Radial w/foam insert-firm), 1028 (60D Type-A w/foam insert soft) and 1029 (60D Type-A w/foam insert hard) All tires are mounted on Suzuki Swift wheels. Note: Any combination of these tires may be used to tune your car.
