Like Tree1Likes
Palmaris engine thread
Old 12-13-2006 | 12:46 AM
  #2461
ziggy12345's Avatar
Originally Posted by EdwardN
Hi Jerome.
I remeber it very well.
I just sent you PM back
Edward
Hi Ed. I have 2 of the 4 liners you sent and they are all the same. I tried machining 0.3mm off of the bottom of the liner flange and still the same. Any ideas?
ziggy12345 is offline
Old 12-13-2006 | 07:23 AM
  #2462
EdwardN's Avatar
Hi Ziggy.
Can you please describe more, I didn't get what you try to descibe. Can you please give small hand drawings-it will be way easier for me to understand and give to you idea Please download attached pic and make sizing on it and put it back so I can see it.
Edward
EdwardN is offline
Old 12-13-2006 | 09:44 AM
  #2463
ziggy12345's Avatar
Ed PM
Old 12-13-2006 | 10:09 AM
  #2464
kitracer's Avatar
Originally Posted by kitracer
I have been using 0.3mm head shim down from 0.5mm( sorry no clearance.. too lazy to buy a solidering iron ) for 25% Nitro.
I finally manage to measure the head clearence
25% nitro, 0.52 head clearance (0.3mm head shim)
Air temp 20 C, 6m above sea level, 80% humidity.
Will see how my power up against Shimo's and Team Kyosho this weekend.
kitracer is offline
Old 12-13-2006 | 03:52 PM
  #2465
Good luck with your race KitRacer. I'm sure you won't be down on power. Looking forward to hearing what happens!
Surge is offline
Old 12-14-2006 | 12:04 AM
  #2466
kitracer's Avatar
thanks Todd
this week Temp will drop from 23c to I think 12C tomorrow. Have you tried going with Plug #5 in this condition?
kitracer is offline
Old 12-14-2006 | 03:37 PM
  #2467
Yeah, #5 works great. I really liked the hotter plug. Last I ran it was around 20C or so. I also dropped the head a little for the cooler weather. .35mm shims for 30% nitro. Ran like a champ! I recommend you try it.
Surge is offline
Old 12-14-2006 | 05:08 PM
  #2468
uniquexme's Avatar
guys, i have just removed the front bearing, there is this marking on the case, is this where i should do the mod?
uniquexme is offline
Old 12-14-2006 | 10:39 PM
  #2469
razzor's Avatar
That mark is correct but there is a groove on the side of the hole.
When I had my leaking problem Kitracer suggested i check if the groove was on the casing.Here is a pic of mine.
razzor is offline
Old 12-15-2006 | 06:20 AM
  #2470
kitracer's Avatar
Picture speak for thousand words.
try to make the groove evenly deep
kitracer is offline
Old 12-15-2006 | 06:24 AM
  #2471
kitracer's Avatar
Yes, tried Plug 5 works perfect. Crazy Torque.... just insane
tks
kitracer is offline
Old 12-15-2006 | 06:27 PM
  #2472
uniquexme's Avatar
guys, the groove of 0.6-0.7mm, i assume its just a few light cuts on the crankcase would do ?
Old 12-15-2006 | 11:15 PM
  #2473
razzor's Avatar
You could use a needle file to make the groove.
razzor is offline
Old 12-16-2006 | 06:14 AM
  #2474
kitracer's Avatar
it will take more than few light cuts because you need a small needle file like Razzor suggest. but should take no more than 5 mins to file that groove.
Make sure clear it properly after, in and out side.
kitracer is offline
Old 12-16-2006 | 07:45 AM
  #2475
I used a triangle file to make the groove. I went to the hobby shop and bought some .020 piano wire as a measurement device. I slowly filed the groove until the wire fit inside the groove flush with the crankcase. That way it didn't go too big and affect pressure in the case.
Surge is offline
