Go Engine USA 2011 Thread
#1366
I got my shipment from Trey today. Besides my usual restocking parts I got two XXL T-shirts and some GXII low speed needles. Oh, and another GXII with the included rear ceramic bearing.
My markup on the shirts will be minimal.
The markup on the needles will be astronomical!
(to make up for the shirts!)
Just Kidding!!!
(this stuff isn't on the site yet, so PM or Email me if you've been waiting)
Moto
(to make up for the shirts!)Just Kidding!!!
Moto
#1367
Just Kidding!!!
Moto
Moto
GUYS... if you're running a Go motor in expert or pro at the nats, pls message me.
T
#1368
whats the stock shimming on the GXII,same as the old engines?
still awaiting delivery of our GXII engines but the prototype one has been running very well until last weeekend where it cut about 6 times in the final..its finally broke in and lost its pinch and the idle dissapeared as you would expect..what i couldnt fathom out is that its gone mega rich on the bottom end and i have had to lean the lsn in by a full turn,i guess its in about 2mm from flush now.
ive put an old GX-R carb on it to test today to see if its the carb..only thing i can think of is that the lsn tip etc has got damaged by an over zealous pitman on needle duty
causing it to not seat properly making it run rich.
#1369
well,.....not a good day today with the GX5R, flame outs all day!! smoke'in plugs all days, put the OS speed in and snapped a conrod
, dint have a extra rod for the OS, so measured up and compared the two, and hmmm..........threw a GO GX5R conrod in the OS SPEED and ran perfect all day, so if any one tells you the GO rod does not fit the OS speed, they are lying
#1370
causing it to not seat properly making it run rich.Check everything external to the motor. If it's been running fine it's a lot more likely to be something other than the motor. One full turn in from it's normal position doesn't sound right. Tweaking the needles by that much when it has been running ok previously may explain the flame outs etc. I think you will find it is somethng external.
All the GXII's were hauling at our 2 day event over the weekend. Making wicked power, and sounding very sharp. Tuned mine in on Friday afternoon and never touched the needles again all weekend.
It was very cool and overcast all weekend, so the engines were making lots of power, which when added to a moisture laden sticky track made for a lot of fun
Made it directly into the A final for the first time, so I didn't care what happened after that
. Just tried to keep out of the way of the gun drivers and cruised around to a 10th place finish. New 808 11 Spec and GXII-5RHO were superb, so a great weekend
#1371
I wanted to let ya'll know that GO-Engines made two podiums today!
Qualifed 2nd A-main buggy, finished 2nd running the GX-7R.
TQ'd truggy, finished 3rd running the New GXII-5R.
I'll post pics later today or tomorrow after work.
GO-Engines ROCK!!!!!!
#1372
Yes, stock shimming is .5mm (1 x .3 alloy and 1 x .2 copper).
way rep
#1373
Guys,
just wanna ask if anyone uses the 7 or 6.5 venturi? I have finished; 15 tanks or so my new GXII and wanted to race tune with a 6.5 venturi. Will the power drop? wanted to make the 10 minute quali without pit. Stock shimming.
Thanks,
Thanks,
#1374
. Motor reached the 50 tank mark on Sunday.You won't get super economy with only 15 tanks through, but you might be able to crack 9 minutes (dependant on driving style and track size). 10 min might be pushing it a bit too lean with that limited amount of fuel through.
I put a reasonable race tune on my HO at the 15 tank mark, and it was more than happy to go along for the ride.
#1375
After a record rain fall this spring in central New York the local track finally
opened the season yesterday. The track was supprisingly dusty and loose. Once I settled on a good set-up and finished tuning my new GX-5R it was time for racing. The first and second heats went well even with the engine still rich. This motor rips! Going in the the final I qualified 3rd in the A. I leaned the motor a little more and switched to a new set of tires. The engine ran perfectly throughout the entire main with tons of bottom end grunt and top end speed. A great first weekend for GO engines.
#1376
#1377
Hey man... Assuming you dont have an air leak- you're either running too lean, not enough shims, or plugs are not hot enough. Add a copper shim, go one step hotter on your plugs, or change fuel. You could also go with less nitro content on your fuel. Basically your plugs are getting too hot. This can be alleviated by reducing compression(add a shim), reducing nitro, or using a more heat tolerant plug. You could also richen your mixture.
thanks trey! it did start acting up when i took the break in shim out, i use 97t plugs, i tried a 77t and did the same thing, so i put the break in shim back in, (seems to run great with it in). going to also change front bearing today.
#1379
1Likes
