Like Tree1Likes
Go Engine USA 2011 Thread
Old 04-28-2011 | 09:06 PM
  #1351
rider313's Avatar
Originally Posted by inferno13
not a problem! you can disagree, but i agree with my therory. if you try to puor somthing that has no air getting to it, its not going to flow even being forced. exhaust doesent allow air, it forces it causes suction. which restricts flow.
One problem I see with your theory, our engines are not fed by a gravity tank for there to be any pouring involved. On a motocross bike the tank is above the motor and fuel line goes down as with the fuel so air needs in so it doesn't vapor lock like you describe.
On a nitro RC the fuel pick up is well below the inlet to the carb. So for the fuel to go up hill and threw all the twists and turns some ppl have it needs a pressure to push it. Hence the pressure line. If you had no pressure line the motor does not have any suction so it gets no fuel. And sine the pickup is below the carb gravity is factored out. Why do you think air leaks cause tunic issues? Extra air is getting in and and tank pressure is reduced so you ge less fuel to the motor. The pressure line is basically a simple fuel pump on these cars.
It's nice to have a civil debateabout our opinions online for once. no name calling or what not.
rider313 is offline
Old 04-28-2011 | 09:08 PM
  #1352
So*Cal AFDude's Avatar
Originally Posted by Flanno
How long do you sit in the pit being fuelled ??? LOL I'll film a fuel stop for ya if I can, We always and my pit man always fills me rite to the top and snaps the lid shut as dropping the car into pit lane, think of your bottom end as a nozzle on a hose that is set correctly, turn on the hose tap and the flow throu the nozzle should be the same, also have your pressure line longer than your fuel line helps absorb the extra pressure as you snap the lid shut.
I think I'm quite fast at putting the fuel in the tank...or on the pipe killing the engine.
So*Cal AFDude is offline
Old 04-28-2011 | 09:15 PM
  #1353
Suspended
i agree! but i think alot of guys look out of the box...per say, like i do. weather im right or your right, i think its great that guys can make or give there opinion here without a big agruement like most threads ive seen. just makeing assumptions here, but still lov'in the GX5R..., never a problem for me. and if there is i can come here and get the problem solved in minutes!!
inferno13 is offline
Old 04-28-2011 | 09:22 PM
  #1354
deadmancourt's Avatar
yes this is also very true...i keep forgetting to lengthen my pressure line a little...i dont find it an issue at all for me...i just make sure its running while bieng fueled and clear it out right before i get dropped
deadmancourt is offline
Old 04-28-2011 | 09:25 PM
  #1355
i think your an idiot! ....JUST KIDDING!....for real..just a joke....yup, pressure line=fuel pump
Old 04-28-2011 | 09:27 PM
  #1356
Suspended
but i have ran atleast 20 minutes with the fuel presure line off???? now what??
Old 04-28-2011 | 09:48 PM
  #1357
Suspended
anyway................i love my GO ENGINE!!!!
Old 04-28-2011 | 10:04 PM
  #1358
jnc011994's Avatar
get the best, get a 2072
hi flanno,
thanks for the tip... will follow the GO Tech TIp on break-in
http://go-racing.vpweb.co.nz/Tech-Tips.html
Also, is the 2072 tough? I had a 0801 pipe and after some time the stinger is not very strong and dented.
Thanks,
jnc011994 is offline
Old 04-28-2011 | 10:12 PM
  #1359
Flanno's Avatar
Now thats the smartest thing I'v seen/read all afternoon
Thou I'd add another 2-3" to that pressure line between the cooler and the lid
Also, aren't calibres directional ??? at least it'l stop well
Flanno is offline
Old 04-28-2011 | 10:21 PM
  #1360
Flanno's Avatar
Originally Posted by jnc011994
hi flanno,
Thanks,
No probs bud
The other 2 pipes you have in your signature will work well for certain tracks/conditions too, but the 2072 is the best suited to the GX and GXII for all-round performance without having to keep changing pipes to get a certain result.
Flanno is offline
Old 04-28-2011 | 10:47 PM
  #1361
jnc011994's Avatar
No probs bud
using 2047 on Stock v-spec is also very good.. my ride during a race here in PHIL which i won in B-Main. Imagine a V-spec that high on the losi, the GXII would be level with the body
Old 04-28-2011 | 11:32 PM
  #1362
shotime's Avatar
I'm bringing sexy back............yep!!
shotime is offline
Old 04-28-2011 | 11:45 PM
  #1363
Flanno's Avatar
^ sure is
Flanno is offline
Old 04-28-2011 | 11:53 PM
  #1364
asaraneta's Avatar
Agree on this.
asaraneta is offline
Old 04-29-2011 | 08:13 AM
  #1365
bigmatt's Avatar
Originally Posted by PUDDIN
Matt I got the carb i will check it out and run it on my motor next weekend.
Good luck!! If you slowly slide the lsn assembly in and out you will notice it has a catch in it. Also look under the carb boot it should still have oil residue in it from the nitro. To me the whole slide assembly seems loose. I also put a new seal on the lsn. Thanks for taking the time to look at it Puddin. I know you have been watching what you eat,but you have earned 1 bonus pudding cup of your choice! Don't get the low fat one either, they are worse for you then regular.
bigmatt is offline
