Like Tree1Likes
Go Engine USA 2011 Thread
Old 05-03-2011 | 03:20 AM
  #1396
Flanno's Avatar
Nice track.
Flanno is offline
Old 05-03-2011 | 07:07 AM
  #1397
Suspended
Originally Posted by Ruune
have you put a plug in the ignitor, outside the engine to make sure that it's glowing?
Is there fuel in your fuel line?
how much pinch do you have at the top of your cylinder?
yes
yes
just pulled it apart again, and hardly has any pinch, only 14 tanks through this engine preheated to 215-220 before every start and already low compression????
inferno13 is offline
Old 05-03-2011 | 09:41 AM
  #1398
Ruune's Avatar
so, with it assembled you can turn the crank a full rotation? I dont understand how you are able to tell with the engine apart, unless you're able to push the piston through the sleeve entirely.
Can email me some pics? I need to see the inside of the sleeve and the piston.
Ruune is offline
Old 05-03-2011 | 09:45 AM
  #1399
Ruune's Avatar
Actually, I think I figured out what is wrong. The OS stroke is longer than the GX-5R. when you put the go conrod in your OS, you probably made the rod slightly shorter (crank pin swings wider, so the rod needs to be shorter). You cant eyball this- you need a micrometer to tell for sure. This can be enough not to push the piston all the way to the top, and what youre seeing is a direct result of that.
Ruune is offline
Old 05-03-2011 | 01:39 PM
  #1400
Suspended
the problem is with the gx5r, the OS motor with the GO rod in it runs great. this is the last engine i just bought from you that im having problems with, ill get some pic's tonite and send them to you. i can turn the flywheel very easy when all assembled.
Old 05-03-2011 | 01:59 PM
  #1401
Ruune's Avatar
you should have a spare rod from any of the GX engines you bought. please try a fresh rod before doing anything else. That could save you some money.
Ruune is offline
Old 05-03-2011 | 02:01 PM
  #1402
Suspended
sent you pm!
Old 05-03-2011 | 04:35 PM
  #1403
Suspended
Originally Posted by inferno13
sent you pm!
Old 05-03-2011 | 10:18 PM
  #1404
jnc011994's Avatar
Default Track
Originally Posted by Flanno
Nice track.
Hello flanno, yes very nice track. Using the GXII and Losi spur. What clutch bell would you recommend? I'm using stock 13 but i don't think its enough for that track.
Thanks,
jnc011994 is offline
Old 05-03-2011 | 10:34 PM
  #1405
Flanno's Avatar
If you'v got time between each round, do one with 13 and next with 14 and next 13 and so on and so on and check your lap times as what is faster and lower averages, (see wich is better for the obsticles) and fuel usage for each round.
Idealy you want to be set up for 90% of the track, yes that straight is very long but is still only less than 10% of the bigger picture, (short shots and jumps etc) concentrate on being smooth and precise -hugging the inside line along the straight and around the sweeper rather than all out speed and you will be just as fast with the 13 bell as you would if went flat out as normal with a 14 bell...hope I'm making sence.
Flanno is offline
Old 05-03-2011 | 10:49 PM
  #1406
jnc011994's Avatar
noted on this.... will test in-between elimination on the 13/14 tooth on which is better.
Thanks,
Old 05-05-2011 | 08:39 AM
  #1407
Ruune's Avatar
Hey guys... just a heads up. We are SOLD OUT of GXIIs here in the US. There is a shipment of GXIIs and GX5Rs leaving Taiwan on the 11th. Still have parts, with more coming.
We will also have the flywheel/clutch combos, and most of the new accessories.
Ruune is offline
Old 05-05-2011 | 08:51 AM
  #1408
Ruune's Avatar
UPDATE... we will also have GXII-5RHO COMBOS with the polished EFRA 2072 pipe. Havent set pricing yet, but it'll be good.
Ruune is offline
Old 05-05-2011 | 01:43 PM
  #1409
Kolunatic's Avatar
Well I guess that's good and bad.
I just snagged the last gx11 5rho that fth had, need a pipe for it
It's all good, my first gx11 5r hasn't really "dropped " yet has around 25 tanks or so.
Kolunatic is offline
Old 05-05-2011 | 04:11 PM
  #1410
Ruune's Avatar
Make sure you're getting it nice and hot: 240-ish.
Full Throttle Hobbies and RCHQ are both getting the last two from this batch. FTH is also getting a 1 or 2 pipes.
Fortunately, I preordered more and they're scheduled to leave next week. Will probably add some more GXII combos on there as well.
T
Ruune is offline
