Like Tree1Likes
Go Engine USA 2011 Thread
Old 04-08-2011 | 08:03 PM
  #1021
Flanno's Avatar
Originally Posted by grizz1
Hey Flanno mate - whatīs happening with the GXIIīs in your neck of the woods. You sorted yet ??
Not sure if they'v arrived here yet bud, so no not yet.
seen the Aussie thread lately
Flanno is offline
Old 04-08-2011 | 08:05 PM
  #1022
Suspended
Right on Matt. I always try and help customers and others with tuning etc when I can, but sometimes you just canīt fit it all in without it being detrimental to your own racing.
Hmm, I holding off on the GXII inferno. I wasn't meaning you had adjusted the idle yourself, but looking at the low speed needle in the pics, there is no way that puppy would sit there idling with the LSN screwed out like that without the idle gap being a little too wide. Maybe it came from the factory like that ? Every motor I have ever run-in needed the idle gap cranked up some for the first few tanks to keep them running - which is cool when you are running rich during the run-in period, but when it comes time for race tune, that idle gap needs to be knocked right back. With the longer needle carbs (or standard needle carbs for that matter), the relationship between the idle gap and the low speed needle setting is critical and must always be balanced out when making adjustments to either.
I am sure when you do the pinch test you will find it chirps up to pretty high revs, requiring a tweak or two on the idle screw to set things right.
LOL, was just kidding, i would never take a free engine from anyone!!!! i would atleast pay shipping.....
Originally Posted by Flanno
after a high speeed run, pull in and stop, the idle should sit with NO change when you stop, if the idle starts to drop any time after you stop then it is still too fat on the bottom.
We aren't having a go at you so please don't take offence, we are only trying to help
no worries here, like'in the help and tips forsure! i did notice the idle does drop down about 10 seconds after stopping! all this info is awsome!! even with the tune all screwed up, this GX5R still runs better than the engines i ran last year!!!
inferno13 is offline
Old 04-08-2011 | 08:08 PM
  #1023
Flanno's Avatar
Damn my keen eye...damn damn damn
also, has anyone else noticed what page we'r on
Flanno is offline
Old 04-08-2011 | 08:16 PM
  #1024
Suspended
LMAO!! you must be a rc racer!!
Old 04-08-2011 | 08:37 PM
  #1025
grizz1's Avatar
Iīve always said one good turn deserves another, and I canīt think of a better way to express that sentiment
grizz1 is offline
Old 04-08-2011 | 08:51 PM
  #1026
grizz1's Avatar
Your a legend bro !!! A sponsors dream
Are you sure you donīt want to move across the ditch
grizz1 is offline
Old 04-09-2011 | 08:07 AM
  #1027
Flanno's Avatar
Cheers Grizz
Flanno is offline
Old 04-09-2011 | 12:26 PM
  #1028
Thanks for the tune section on the last page, I have the same issue of it dropping the idle after I come in to pit. (avg 7 seconds till it wants to stall) I'll play with the idle/ls next time out. Never looked at the idle. Thanks.
buglite62 is offline
Old 04-10-2011 | 12:20 AM
  #1029
grizz1's Avatar
No worries . If you want the full tuning spiel, go to the ĻTech TipsĻ page of our website at http://www.go-racing.co.nz
Scroll down past the run-in section to the tuning info.
grizz1 is offline
Old 04-10-2011 | 12:39 AM
  #1030
speed demin's Avatar
Default GX-5R
Well got my motor all back together with the help of shane [cheers man] had my first run today at hamilton track but was having heaps of trouble with the tune always changing just the low end would always fatten up evertime i restarted it from a good tune, i had to turn in the lowspeed needle 3 full turns to stop boggin down, also blew 2 glow plugs witch has never happened before so was thinking my motor might be low in compresion causing all my trouble and not enough head shims? but if my motor was low in compression would it still blow glow plugs like that? it still has resistance when turning flywheel when in truggy thow, how do i tell if it is low in compresion? got it to last the main at least.
And on a good note won the A truggy final today had an awsome run am stocked with that even with tune trouble YEH HA
Is it worth getting a pinch done if it is low in compression just to get me threw till i can get a GX11-5RHO.
speed demin is offline
Old 04-10-2011 | 12:41 AM
  #1031
Flanno's Avatar
Glad to help, pretty soon everyone will be getting 13min run times too
Flanno is offline
Old 04-10-2011 | 03:37 AM
  #1032
grizz1's Avatar
The GOīs always run a little fat for the first couple of minutes until they heat up. I think by going in 3 turns (which is a huge adjustment) you would have ended up very lean after a few laps, which probably accounts for the blown plugs.
Check the compression by taking the motor out of the car when itīs cold and holding the motor by the flywheel. Tilt it over to one side. If it will hold itīs own weight without slowly turning over and flopping to the bottom then the compression should be ok. If it will hold itīs own weight with the pipe still attached it is sweet. If it wonīt hold itīs own weight and just turns over either slowly or quickly, then itīs time for a pinch, or a new PRS set. or a new GXII-5RHO
Nice effort with the win mate. It must have been running half decent to pull that off
grizz1 is offline
Old 04-10-2011 | 04:15 AM
  #1033
Flanno's Avatar
Keep with it speed demon, you'l get it, one thing to remember is if in daubt, richen high end to flush and start all over again with the bottom end first and only once that is happy can you start going in on top in small adjustments untill you start getting power, do 2-3 consecutive tanks to saturate the chassis with heat before fine tuning for optimum race tune.
Flanno is offline
Old 04-10-2011 | 04:29 AM
  #1034
Yeh that was massive adjustment with low speed needle but if i didnt have it in that far i would not idle and just cut out when hitting throttle it was like a new motor setting just choking up it was that rich until i got to 3 turns in, i ran a full tank out once i got it to run ok [still a little rich on bottom] just because the most i would usually have to turn in would be 1.5 turns max from flush and seem to run ok didnt lean out if anything got richer, i tune my motor exactly like you posted hsn was just under flush idle gap was set by pinch test [first] then set lsn last but i think the compresion would be getting low as it only holds it weight on its side [without pipe] for a few seconds then drops, i think i might have to send it up to you and you can check it out and if you think it would be ok give it a pinch as no point gettin new psr as i am wanting the GXII-5RHO in a couple of months anyway and would just keep this for a backup engine [got to wait a couple of months to keep mum happy]
Cheers man, yeh once it was tuned it was good well good enough to get me threw the main anyway its once it cooled down and restarted it was a differant tune.
Old 04-10-2011 | 04:39 AM
  #1035
Cheers flanno i won't be giving up on these go engines they are great out of a hole season racing this is the first time with issues so its done heaps of hard work so im more than happy with its performance usually they are great to tune i think these are the easiest motors i have had yet to tune thats why i think its not tune related but low compression or something like that.
