Like Tree1Likes
Go Engine USA 2011 Thread
Old 04-16-2011 | 07:53 PM
  #1171
Suspended
Originally Posted by bigmatt
just an update,got tank 7 through seems like it all fell in place. running rich but was able to tune a little so it sounds smooth. I will say that we really don't need to make a big change from flush on the lsn/hsn. I am 1/4 turn in on the hsn and maybe 3/4 on lsn set idle/ perfect. The old ways of adjusting our go-tecs is out the window. so below is a list of mistakes I made in order.
1-I opened the package and immediately felt dizzy causing me to babel!
2-I disassembled the engine to flush out any metal debris[not necessary]
3-reassembled engine without sealing like I do on every engine.
4-thought I had engine heated enough to start. did not
5-when piston locked in place took screw driver to force flywheel to get piston back down. While talking to my son realized I had turned fly wheel 360 on crank.
6-disassembled whole engine thinking c-clip had fell out. what really happened was I needed to heat engine more plain and simple.
7-needles do not need to be moved that far from flush. on all my go-tecs and mg-66 the needle settings are exact for all engines.hsn1/2 turn in/lsn 1-1/2 turns in give or take a few hours. Like I have stated before when I go to the races I usually go alone so all my engines MUST idle for long periods,no-one wants to try to adjust your equipment.
so I hope this helps all the people who get the new engine and think they have a problem you don't it's most likely the nut behind the wheel!!
But if you go back to our old engines every thing that I thought and tried would have been true,not so with new engine.
The only problem i have is that you always call them GO TEC'S, they are not go-tech's. they are GO-ENGINE now! i dont know why but that just irratates me....LOL
inferno13 is offline
Old 04-16-2011 | 07:59 PM
  #1172
bigmatt's Avatar
Originally Posted by Kolunatic
Hey Trey, can you help and tell me starting point of idle on 3 port. I was chasing tune all day and went back to factory settings. Will. Get to track early to dial it in hopefully, long day today.
with the hsn/lsn seals you can use silicon fuel line to make new ones till you get the new ones. cut the fuel tubing to the width of the seal your replacing. as you screw it in it will cut the excess off. I like to put some soap on the outside to make it go in easier. but not really needed. It works was a trick Grizz told me. To me you have an air leak which is common on the older go-tec models. I would get some lucky 7 or go to kragens pepboys and get some red atv silicon sealant and seal back plate carb.
bigmatt is offline
Old 04-16-2011 | 09:08 PM
  #1173
grizz1's Avatar
Hey Matt - glad it all came good for ya
Yep, the new LSN taper definitely makes a difference to the needle settings.
Like you, my GX and MG needles were all pretty close to what you described, but with the new GXII my LSN is pretty much flush, same with HSN. I´m still a little on the rich side as I still have some metal pinch on the motor, so when it´s fully bedded in I am guessing an hour or two in on the top end and maybe a 1/4 turn in on the bottom will see it at it´s best.
Wait until you have a few more litres through, you will like it
grizz1 is offline
Old 04-17-2011 | 06:17 AM
  #1174
bigmatt's Avatar
I'm loving the engine.with the new carb this GO ENGINE is what I call dummy proof Even tho I had to move the needles a bit to get it to run at the end of it all it was not as much as I thought it should have been. Like our older models.
Looking back if I had just installed engine, heated it up more it would have fired and idled right through it's first tank. There is no reason to clean out readjust carb. It is a whole new Go ENGINE.
bigmatt is offline
Old 04-17-2011 | 05:36 PM
  #1175
Kolunatic's Avatar
Talking
Originally Posted by inferno13
you might need a carb rebuild kit (o-rings) the older GO ENGINES had crappy seals in the carb, you need the updated ones. i had problem with mine as well, untill i got some new ones from trey. then all was good again
thanks for the help guys. i found some orings in my set and sealed carb and backplate and i took second place today with that 3 port!
thanks trey for stocking the shop with the new 5 port,cant wait to get my hands on it
Kolunatic is offline
Old 04-17-2011 | 05:39 PM
  #1176
Suspended
congrats on the second place finish!!!!
Old 04-17-2011 | 05:44 PM
  #1177
Kolunatic's Avatar
thank you sir.
i'm still in sportsman,never placed before.had some battery issues so i missed the first 2 heats,2 minutes left in 3rd and finished the main.great weekendGo Engine USA 2011 Thread-bug2.jpg
Old 04-17-2011 | 06:16 PM
  #1178
rider313's Avatar
Contests on the finish. Get some more track time and you will jock out that #1 spot.
I remember my first sportsman race. Me and one other fellow swapped heat race wins but he got the TQ by 1 second. Come main he bobbled in the first turn I took the lead and never looked back. He ended up with a dead servo so I won by four laps against 5 other drivers in a 20 min main.
Let's just say sportsman wasn't for me. ever since I have been hooked on RC racing.
rider313 is offline
Old 04-17-2011 | 09:13 PM
  #1179
Default Engine Break-in
Hey guys. Just got a new GX-5R from Nitro North. What is the proper break-in for this motor? I've been reading up on heat cycling and this seems like the "new school" way of break-in. The instructions provided with the motor say to idle the first two tanks etc. Coming from a motorcycle back ground, we always heat cycled new race motors on the dyno before races. This is my second nitro motor, the first being a Traxxas 3.3 (don't flame me it got me back into RC). They recommend heat cycling. What's the best way to get the best performance out of this motor? Sorry if this has been covered before but I searched and had no luck. Thanks for any and all help.
Mototech is offline
Old 04-17-2011 | 09:24 PM
  #1180
Suspended
everything you need to know.......... http://go-racing.vpweb.co.nz/Tech-Tips.html
Old 04-17-2011 | 09:46 PM
  #1181
Thanks inferno that's exactly what I was looking for. I have a copper washer that came in the kit. Is that a break-in spacer for the head? Should I use it? I saw some mention of a spacer when browsing this thread. Thanks.
Mototech is offline
Old 04-17-2011 | 09:50 PM
  #1182
Suspended
YEP, stick it in there, always preheat engine to 210 to 220 before starting during break in.
  #1183
deadmancourt's Avatar
do it just like you would your race bike engines....thats where the heat cycle method came from ...as long as you preheat to atleast 200f and let cool to ambient temp before each fire( for the first 2 litres of fuel)...you should be good to GO
deadmancourt is offline
Old 04-17-2011 | 09:57 PM
  #1184
Suspended
no problem! thats why i decided to run GO ENGINES this year! the guys here are awsome!! and support is the best in the BIZ! they will go out of their way to help you out and that is what i look for in a company!!!! simply awsome!
Old 04-17-2011 | 10:29 PM
  #1185
Thanks again guys! I should have my new buggy Tuesday and hopefully have everything to finish it by the weekend. Does the heat cycling have to be done all at once or can it be broken up? Can I run two tanks Wednesday after work, two tanks Thursday after work, etc?
Mototech is offline
