Like Tree1Likes
Go Engine USA 2011 Thread
Old 04-04-2011 | 03:32 AM
  #931
speed demin's Avatar
Default GX5R
Hi guys hay i have a question, i have a go gx5r and was trying to get rear bearing out using the heat method [have not replaced bearings before] and was super tight heated up for about 15-20 mins in oven to try and get out anyway finally got it out but noticed some scratches inside crankcase were backing plate goes into, will this cause any issues or will it be alright to use still i have sanded the high spots so nothing will catch. any help would be great and tips on what i should have done thanks
speed demin is offline
Old 04-04-2011 | 03:44 AM
  #932
Has anyone ever had the Go "Big Block" pipe? How is it? Recently got it with an engine on ebay.. Wondering if it's worth trying...
Herrsavage is offline
Old 04-04-2011 | 03:58 AM
  #933
Flanno's Avatar
Hi Herrsavage, I noticed your post on other thread, I haven't answered because I can't/won't comment on things I have no personal experiance/knowledge of.
Hopefully someone can shed some light on your enquiery soon.
Flanno.
Flanno is offline
Old 04-04-2011 | 04:07 AM
  #934
Flanno's Avatar
Since your in NZ, hopefully Grizz will see this one..............it depends where, what angle, how deep etc as to wether or not you may get an air leek there now, you may need to use an engine sealant if it is where is supposed to be sealed by the O ring ?????
Telling you what you should have done differently would depend on how you did it, you only mentioned the heat method, but you didn't mention how you managed to scratch it.
photo's speek a thousand words
Flanno is offline
Old 04-04-2011 | 02:05 PM
  #935
grizz1's Avatar
Hi mate,
As Flanno said, if you can throw up a picture it would be great.
Otherwise I don't think you will have a problem, as the O Ring seal on the back plate seals that area very well. As long as there are no gouges under the O Ring area you should be right.
Next time you want any bearings done, just post the motor to us at GO Racing NZ. We will replace the bearings and give the motor a good look over at the same time for a minimal fee of $15 inc gst (plus the cost of the bearings of course ).
Any problems just give me a call. Contact details on the web site at
http://www.go-racing.co.nz
Where are you located ?
grizz1 is offline
Old 04-05-2011 | 12:07 AM
  #936
Default GX5R
hi guys,
yeh i didnt say how i got the scratches did i! i didnt want to sound like a tool anyway i heated the block up for about 20 mins at 180 in oven and taped the back of block on a wooden board to pop out but it came out sideways an got stuck half way out so heated back up but wouldnt budge so me being impatient i grabed the bearing with pliers [stupid move] and thats how i got scratches in block but got bearing out ha ha as for photos i am not very computer minded at all!! so thats way to complex for me.
hay grizz1 yeh i think i will do that next time i like to do try things for myself but i will leave this to the experts i think, i live in matamata and am a member of the hamiton rc club am there every race day when its not raining!
Attached Thumbnails Go Engine USA 2011 Thread-dscf1171.jpg   Go Engine USA 2011 Thread-dscf1173.jpg   Go Engine USA 2011 Thread-dscf1169.jpg
Old 04-05-2011 | 12:10 AM
  #937
Wow have just seen the photos dont know how i actually did that but thats good hopefully they are clear enough to see the scratches in it
Old 04-05-2011 | 12:58 AM
  #938
grizz1's Avatar
I don't think those scratches will cause any problems.
Do you have new bearings ready to go in ?
If you don't, I have a perfectly good 2nd hand crankcase with two new bearings installed that you can have for the cost of the bearings if you want ? That will save you fighting with it to get the new bearings in as well.
Then you can just keep that case as a spare. Let me know and I can post it down.
I must have met you, as I raced every meeting at H-Town last year bar one.
grizz1 is offline
Old 04-05-2011 | 01:11 AM
  #939
Yeh i must have meet you to i race the yellow d8t what do you race? no i dont have bearings yet and that block sounds awsome man that would be great, i will send ya and email and go from there thanks shane
Old 04-05-2011 | 02:00 AM
  #940
Flanno's Avatar
the 2 on the bottom (3rd picture) look quite deep I think Grizz ? and go rite across where the O ring should seal, I wouldn't be too confident of a good seal and the offer for the case sounds like the better option.
I personaly wouldn't use the scratched case without using a engine sealant as security.
Flanno is offline
Old 04-05-2011 | 02:46 AM
  #941
grizz1's Avatar
Cheers Flanno. I should put my reading glasses on eh bro
No worries, as we are sorting the speed demin out with the case and new bearings . That will get him through a few more meetings until he picks up his GXII-5RHO, eh Paul
Turns out we pit about 20 metres away from each other normally at the Hamilton track. Paul drives a mean truggy, and gets his GX-5R powered D8 around the track real quick
grizz1 is offline
Old 04-05-2011 | 03:51 AM
  #942
Flanno's Avatar
All good Grizz, you know me, just tryin to help
Not an issue anyway as your hookin him up with a case.
Ahhhhh a fellow truggy driver Coming over for FEMCA ???
Flanno is offline
Old 04-05-2011 | 06:14 AM
  #943
Ruune's Avatar
hi guys,
Scratches look cosmetic to me. Not enough to create a leak.
However. Look real closely at the part of the case that the rear bearing pushes up against. Theres visible scarring. Also, the reddish brown deposits have me wondering what fuel you're running, as well as air filters. Please post pics of your piston, sleeve, and crank. I'm interested in deposits on all of the above, and condition of the surfaces.
Ruune is offline
Old 04-05-2011 | 07:17 AM
  #944
Ruune's Avatar
actually... pls dont mention your fuel manufacturer. I dont want to start another pissing contest. Please try another brand of fuel. I suggest this because I believe those deposits on your case are parafins- i.e. cheap wax lubricants. Your fuel should not be leaving reddish brown deposits on your case like that. The surfaces of the case ports are actually honed (super smooth), which makes it difficult for most anything to stick.
Again, please try another brand of fuel.
Ruune is offline
Old 04-05-2011 | 07:23 AM
  #945
motomatt's Avatar
The case and rear bearing are very close to the exact same size. Of course, if the bearing is at an unnatural angle when removing, it becomes lodged because of the larger diameter now required. Pulling the bearing out while "skewed" stretches the rear of the case ever so slightly.
[IMG][/IMG]
Moto
motomatt is offline
