Like Tree1Likes
Go Engine USA 2011 Thread
Old 08-31-2012 | 08:33 AM
  #2566
bigjayjay1's Avatar
Originally Posted by Rsickles
Alturn USA AEG21... is it the same piston/sleeve as the Go GX? No info on their website.
http://www.ebay.com/itm/140829590999
No it isn't
bigjayjay1 is offline
Old 08-31-2012 | 09:50 AM
  #2567
Default Bought GT5
Hey guys.. I guess it's a bit late to ask but I bought GT5 on a whim from Amain. Product info states engine is the same p/s/c as GX. I'm wondering if anyone has any thoughts. The engine was only 100 bucks so I'm not to concerned, but I haven't heard much information on that engine. To date the best engine I've owned was a RB B10. I got 13 gallons of fuel through it before it started getting finicky. I sent it to get pinched and got lost in the mail. My current engine is Dynamite V2. Good engine, but only 5 gallons of life. I got it repinched and seems to be working good, but after only 1/2 gallon of fuel it seems to be acting goofy. What is everyones thoughts on buying the cheaper engines?
FisherKing is offline
Old 08-31-2012 | 11:22 AM
  #2568
d45
Default GX II HO, 9mm insert, 2058 pipe & manifold
I have been running go engines the past few years and think they are great!! To date the best combo I have tried is
GX II HO .21 with Novarossi 9mm insert, werks 2058 pipe, #5 werks glow plug and M2C flywheel (no Weights)
Pipes I have ran the go 2072, werks 2013, ofna 086 and nova 9901
Power delivery is crisp and has a hard hitting electric feel to it. Very impressed with run times at 11 mins with fuel to spare
just thought i would post it if anyone wants to give it a try
d45 is offline
Old 08-31-2012 | 12:14 PM
  #2569
Fisher king,I am running a G5T in my truggy.It is a very good motor,heaps of bottom and doesn't,t lack on the top either.
It is basically a GX5R with an updated crank,quality bearings etc.
You can expect the same life out of it as any other motor out there,just at a very low price.
I heard that GO we're discontinuing this motor,so I recommend grabbing a backup or two I have
ben1970 is offline
Old 08-31-2012 | 12:17 PM
  #2570
Will a dynamite 053 pipe work with gt5 gotech? I also have RB concept 2045. Which is better?
Old 08-31-2012 | 12:22 PM
  #2571
I have only run the GO2072,not familiar with the others you mention.
ben1970 is offline
Old 08-31-2012 | 12:27 PM
  #2572
I had a Dynamite 053 on a Caster Grenade(which was a modified Go GXR 5-port), and it was awesome.. A bit of a light-switch, but I liked it a lot..
Herrsavage is offline
Old 08-31-2012 | 03:06 PM
  #2573
Rsickles's Avatar
Originally Posted by bigjayjay1
No it isn't
What did the sleeve porting look like on yours? Any pictures? I found out they produced a 7 port with DLC, so it might be a variation of the Precirotate style then.
Rsickles is offline
Old 08-31-2012 | 03:49 PM
  #2574
22Racer's Avatar
That engine looks like the Arrow case and carb, maybe it has the longer stroke crank like a Go.
Rex
22Racer is offline
Old 08-31-2012 | 04:00 PM
  #2575
Rsickles's Avatar
It's definitely out of the GO factory with that carb and Arrow-influenced case, but it's long stroke like the newer GO's.
This is all I've found:
http://www.scanner-rc.com/specification/SEG-21Race.pdf
http://www.scanner-rc.com/specificat...21Race+DLC.pdf
I'd at least buy one just to see what it is if nothing else, but I'd like to know if there's some interchangeability. I just hope it wouldn't have the same case/front bearing problem as the first-gen Arrows... then come to find out it's a unique sleeve, so it's useless.
Rsickles is offline
Old 08-31-2012 | 04:06 PM
  #2576
nitroexpress's Avatar
The listed bore and stroke of the Alturn is the same as the Go GXII-5R and the GX-3/5/7R series.
16.26mm x 16.80mm
nitroexpress is offline
Old 08-31-2012 | 07:11 PM
  #2577
jrz93's Avatar
Ok so tell me this, is the only recommendation a 2072? I have ten other pipes non are good? Jp2, jp3,9901,086,053,057,re10,re11,2060 or 2013?
jrz93 is offline
Old 08-31-2012 | 07:15 PM
  #2578
Suspended
the 086 and 053 do very well!!
alwayswin is offline
Old 09-01-2012 | 09:18 AM
  #2579
22Racer's Avatar
An 086 works on everything. I have 2 2072 in great shape if you want to try one.
http://www.rctech.net/forum/r-c-item...ipes-sale.html
Rex
22Racer is offline
Old 09-01-2012 | 04:52 PM
  #2580
hustler777's Avatar
The alpha 2090 seems to work really well....
hustler777 is offline
