Like Tree1Likes
Go Engine USA 2011 Thread
Old 09-05-2012 | 01:58 PM
  #2581
Hey guys. I've been running a GXII-5R that I picked up from Amain when they were clearing them out. I've been having problems with tuning. I'm running the 2072 pipe with VP 30%. The past few weeks it's been running good but would bog on the bottom. If I tried richening the bottom I would get flame outs between 4-5 minutes into a tank. I had the LSN about 1 1/2 turns in from flush and the HSN was 2-3 hours in from flush. This weekend after a couple of flame outs a friend with 20+ years experience helped me with the tune. He also runs GO engines. He ended up raising the idle, fattening the LSN, and leaning the HSN. It ran good but felt like it wasn't making as much power. I've gone back and read through here and it seems like some people say 1-1 1/2 turns in on LSN and a couple hours in on HSN to the exact opposite. I'm getting really frustrated with this motor and need some advice. Thanks
Mototech is offline
Old 09-05-2012 | 02:02 PM
  #2582
Suspended
your LSN is in way to far, from flush your low speed needle should not be more that 4 hours in. your hsn from flush should be about 3 hours in, try that and give feedback, make sure your idle gap is .07 to 1 mm
these engines tune kinda funny, you want them to run a little fat at first and the longer you run them they will richen up
alwayswin is offline
Old 09-05-2012 | 04:58 PM
  #2583
sickpuppy1's Avatar
Another carb question. I have a silver head 5 port Go, like maybe gen 4? It has a 2 needle carb. Anyone think it would be advantageous to go to the new gxII 2 needle carb. someone has them at a ridiculous price right now....
sickpuppy1 is offline
Old 09-05-2012 | 05:04 PM
  #2584
curacing2's Avatar
Mototech, your friend and Alwayswin seem to have it right, if you turn the lsn in much past flush you will starve the engine of fuel when the slide is closed, test this with the fueline pinch test.
to get the power back lean the hsn, i'm guessing its a 2 needle GXII carb, I have run them (hsn) 1 to 1.5turns in from flush without any problems, you will know if you go too lean, it will get a bit hot and flat out of the corners so richen a bit then, also if the straights are very long do the same.
curacing2 is offline
Old 09-05-2012 | 05:28 PM
  #2585
Suspended
it sure wont hurt anything, might be a little easier to tune with a little better run time. if they are cheap......doesent hurt to have a spare
Old 09-06-2012 | 04:48 PM
  #2586
sickpuppy1's Avatar
GOTGXII21-2000-P2 carb for under 14.00 bucks??!!
Old 09-07-2012 | 02:18 AM
  #2587
Default Losi pipe
Has anyone tried the re12 pipe on these engines. Just curious
stevolicious is offline
Old 09-07-2012 | 05:24 AM
  #2588
Well they're the same stroke as the novarossi engines, and afaik the re12 is similar to a 9901 pipe, so you'd think it might work. But I don't know.
Eivind E is offline
Old 09-08-2012 | 07:29 PM
  #2589
Suspended
i have and dint like it, seems to take away lowend and highend power. kinda like running the jp pipes on these engines, the jp2 was the best jp pipe. the 053, 086, 2072, or 0801 pipes are the ticket
Old 09-10-2012 | 05:40 AM
  #2590
McD44's Avatar
Quick question on the GX-7R. I just picked up a Serpent Truggy with this engine and I'm looking for suggestions on glow plugs. What are the highest recommended as well as most redily available plugs out there? Thanks in advance!
I'll most likely be running O'Donnell Speed Blend 30%.
McD44 is offline
Old 09-10-2012 | 06:16 AM
  #2591
hustler777's Avatar
OD 97t (medium/hot) or 77t (hot)
hustler777 is offline
Old 09-10-2012 | 06:27 AM
  #2592
McD44's Avatar
Awesome, thanks!
McD44 is offline
Old 09-10-2012 | 06:39 AM
  #2593
O.S. P3 and P4, P3 for "normal" temperatures, P4 for warmer summer days
Eivind E is offline
Old 09-10-2012 | 09:13 AM
  #2594
McD44's Avatar
Thanks to you too! I love this hobby!
McD44 is offline
Old 09-10-2012 | 10:27 PM
  #2595
Flanno's Avatar
30% Nitro
OD T97 med or T99 cold
OS P4 or P5
Flanno is offline
