Go Engine USA 2011 Thread
#2552
Hello hello hello any one here lol jk. Hope someone can help. I'm in a bit of a crunch here and can't pin point the issue. Ok here is the Quick run down. new out of the box Go with Go pipe broke in with idling, figure eights then slow runs half throttle around the track keeping temps at 220 with quick full throttle down the straight. That's my break in method. 1/2 gal felt good, 2/3 gal motor was awesome even ran rich with tons of smoke and now at 1 gal I get flame outs. I know what to look for when flame outs happen. Plugs, leaks, sucked dirt ect... All is well. Things that changed from 2/3 gal from 1 gal are new fresh buggy(mugen us spec), Go pipe got sold during time off to a friend, went back to stock settings and plug brand being changed. Broke it in with 97t. I run os motors so when that 97t died I put a p3 which was in my stock but it didn't last at all and not sure why. Went back to 97t and flame outs are less but still flaming. I used the stock setting from the info given a pages back because I couldn't figure why it was flamming with the p3. I have the 2 needle carb so I did flush and flush and tune from there. Bottom has good power but you can hear the clearing out while throttling with tons of smoke. If I go any leaner on the bottom then it bogs. I spend last practice tuning it myself then asking for help from pros. I feel top is great, bottom has good power but motor has tons of smoke as if I'm breaking it in. And for the flame outs, they just happen. One min it can be upside down and still run, the nxt it only takes a few secs then it's out. Even with fuel. I can go a few laps with no issues then come in to pit and it dies when refueling even with fuel left. From new to 2/3 gallons the motor never never never flammed not even while on my lid for a few secs. Where should I start or what should I do? I loved it new but now I'm too scared to even club race it let alone dare use it for a trophy race.
Try leaning the bottom again but richen the top too to get rid of the bogging, you may find you can reduce the idle too once the bottom is rite, it should take off smooth without sounding like it needs to clear it'self out before it produces power.
#2553
Hello hello hello any one here lol jk. Hope someone can help. I'm in a bit of a crunch here and can't pin point the issue. Ok here is the Quick run down. new out of the box Go with Go pipe broke in with idling, figure eights then slow runs half throttle around the track keeping temps at 220 with quick full throttle down the straight. That's my break in method. 1/2 gal felt good, 2/3 gal motor was awesome even ran rich with tons of smoke and now at 1 gal I get flame outs. I know what to look for when flame outs happen. Plugs, leaks, sucked dirt ect... All is well. Things that changed from 2/3 gal from 1 gal are new fresh buggy(mugen us spec), Go pipe got sold during time off to a friend, went back to stock settings and plug brand being changed. Broke it in with 97t. I run os motors so when that 97t died I put a p3 which was in my stock but it didn't last at all and not sure why. Went back to 97t and flame outs are less but still flaming. I used the stock setting from the info given a pages back because I couldn't figure why it was flamming with the p3. I have the 2 needle carb so I did flush and flush and tune from there. Bottom as good power but you can hear the clearing out while throttling with tons of smoke. If I go any leaner on the bottom then it bogs. I spend last practice tuning it myself then asking for help from pros. I feel top is great, bottom has good power but motor has tons of smoke as if I'm breaking it in. And for the flame outs, they just happen. One min it can be upside down and still run, the nxt it only takes a few secs then it's out. Even with fuel. I can go a few laps with no issues then come in to pit and it dies when refueling even with fuel left. From new to 2/3 gallons the motor never never never flammed not even while on my lid for a few secs. Where should I start or what should I do? I loved it new but now I'm too scared to even club race it let alone dare use it for a trophy race.
#2554
Magpie- it was dumb to let it go but I put RC on hold due to a slight Heli bug but I'm trying to do both until my bank says other wise. Idle I'm not sure. We had a heat wave a few practices ago and lights went off. Couldn't clean my gear so I prefer not to pull the filter off. Headed to the track tonight and I'll check and note. I usually start with it opening the size of a thick zip tie to keep it running then i tune low end and then top and maybe go back to low end. Pipe I have on now is the werks 2013. Haven't tired my 2058 or 2060. Just want to get it tuned right first.
Flanno that's what I thought and still think but and have gone back in forth with leaning bottom and riching the top. Gonna try again tonight and hope the power stay on. Power outage cut practice down early so I couldn't try again.
Hey Rob what's up. Yeah haven't seen you or any of the agama crew out. Wanted to pick up another carb of rodney or someone incase this one is any good. Also congrats on the little one. I have 3 little ones so I know all about putting Rc on hold. But it's a great break when needed. I look fwd to thurs practice and sat trophy or club races. Lately it's been flying and repairing but that's on hold due major repairs.
Anyhow I'll try the old tube pinch test. Haven't done that in awhile.
I don't want to turn in the needles right in fear of losing my last starting point but I'll note it tonight. I'll bring my phone and check back with replies. Thanks
Here pics- bottom seems one turn in from flush
Top seems to be 1 1/2 to 2 turns in
#2555
If the low speed is set close to the right spot, the motor should only idle up a tad bit and die before 7 secs. If it dies before , or idles up high..you are too lean... If it takes longer than 7secs and does not idle up, you are tooo rich.... This test can only be done before the crank case gets to normal operating temps....
Granted it's late here and I'm checking the forums because I can't fall asleep just after finishing work.
Check the compression as well. Obviously 1 gallon is too short to simply wear out a sleeve but if there has been any tiny amount of damage to the motor it can decrease compression and cause some of the symptoms you describe. It's too simple not to check just to make sure you're not chasing your tail.
ARG- Just read you're not using the Go2072 pipe. I don't know if that pipe will work with the GXII but I do know getting the right pipe is critical. I used a couple pipes and they were terrible, never could get the tune or power to work correctly. Hopefully someone else can help on that one.
I ran my first club race with the new truck motor last weekend and won despite going about 1/2 speed down the back straight. It already has loads of pop on the first few feet of acceleration and is just beginning to stretch out a bit when I let it eat. Very happy with the motor and I'm slowly getting used to the 3-needle carb.
#2556
Ok so I ran it last night and was back and fourth with the top and bottom. So going off the needle settings above I first tried rob's suggistion. The pinch test gave me a high idle up and took for ever to die. But I left it knowing the bottom was rich and top was lean. Ran a few laps to tune by ear. Down the straight it was on fire. I could hear it at top rpm about mid way down the straight. I knew it was way too lean then and bottom was ok but still had a load up issue. Brought it in and it was 296 ouch. I know that took some long term life out but im glad the rod didn't snap. Came in opened the high speed needle about 1/2 turn to get me in the 200-220 temp area and did a few slow laps to cool it. That half turn was actually really good and I kept it there for the night. The bottom is where I struggled. 1 to 2 turns lean I would get a slight bog as if it wanted to cut off. 1-2 ours rich I had now bottom power. I would have to take wide turns for it to clear just to make baby doubles. So when I put it back to the setting in the pic above the motor ran ok for a practice motor but I would've race it as is. The mid to top was awesome and bottom I could make the smaller doubles but barely. You could hear it clearing out from 5-15 percent throttle and after take off like a bat at out off hell with plenty of smoke. I'm gonna try to get my GO pipe back or maybe post for another. I know pipes play a big role in power band but didn't think it would make or break a motor. But I'll find one and try it again.
Thanks for the feed back and I'll drop in with updates.
This is a long post but wanted to also know how many gallons are these motors getting if ran right and are the newer carbs worth getting? This is my first 2 needle carb. My old Go had another type of carb but I can't recall which. It 1 1/2 years ago. In fact the time I meet rob for him to check the insides. The intech br5 days lol.
#2557
Don't worry about motor life after a short hot run like that. If it's already fully broken in it's fine. It has happened to me and mine is still strong. They last a long time, how long depends on how you treat it. Biggest thing I do is to pre-heat and get that tune figured out. My GX5R lasted me from Feb2011 to August2012, tons of racing. My current GXII5RHO from November 2011 has run 20minute mains every weekend, except maybe 4 missed weekends, plus a points series and Nitro Challenge. I've stopped keeping track at this point, but that's a lot. The GX5R finally has started to get really picky on tune and I think it's time for a new PSR. I already have a new crank so it should be nearly a new motor.
One thing, when you get close to the right tune on that 2needle carb, make adjustments to the LSN by half-hour increments. It is very sensitive compared to other brand needles. This LSN also affects the mixture up through almost the entire throttle pull. And get the 2072 pipe, yes it makes a huge difference.
#2558
hey guys its been forever since i've been on here, anyways i'm out of RC for now and i have a brand new sealed box gx5r and pipe combo if anyone is interested in it let me know and we can work out a deal
#2560
Got 6 gallons on my gx2 before it became a backup.....as long as amain keeps selling them parts should be easy enough to find....the 3 needle carb has a larger throat than the 2 needle and if I'm not mistaken has a slightly different low end needle for easier (like it was hard in the first place) tuning....I'm sure others will chime in with more info....as long as you run the right pipe combo you can't go wrong.....I recommend the alpha 2090 over the 2072....seemed to stretch out the power band and improve mileage
#2562
we have found the GXII responds best if not too lean on the lsn and with the 2 needle carb don't go any leaner than flush on the lsn, the hsn does run a fair bit in from flush compared with the older GX motors, just tune as you have.
I think the pipe 2072 will help the bottom end also, the motor likes a clutch thats not too early, I run the 4 shoe ascendancy with 1mm spring and all alloy shoes.
Fisherking, the 3 needle carb does perform a bit better than the 2 needle and is not hard to tune, like the OS motors the 3rd needle is really an adjustable fuel intake tube, you can run it at the factory setting or do a 1/2 turn adjustment in or out and the lsn needs to be moved with it then re-adjust the lsn from there...as you may have read they like the GO 2072 pipe.
#2564
Alturn USA AEG21... is it the same piston/sleeve as the Go GX? No info on their website.
http://www.ebay.com/itm/140829590999
1Likes
