Like Tree1Likes
Go Engine USA 2011 Thread
Old 07-12-2011 | 04:31 PM
  #1801
bigmatt's Avatar
Originally Posted by CORRRCR
Is there a tutorial on how to remove the bearings without damaging anything? Or just a simple how to?
you need a bearing pller/installer. I got the ofna one which is okay. The one I should have gotten is the Hudy ultimate tool. You will be surprised how often you use it. The ofna one you will need a heat gun to warm up around the bears/case to take out. I would not even think of using the ofna tool with out heat. I would imagine in a pinch you could try it with out heat.
bigmatt is offline
Old 07-12-2011 | 05:02 PM
  #1802
nitroexpress's Avatar
There are a number of tutorials on YouTube. Here is a two part tutorial. You can search for others.
http://www.youtube.com/watch?v=Whpws...8A023BC11267F8
http://www.youtube.com/watch?v=Q3xIW...8A023BC11267F8
nitroexpress is offline
Old 07-12-2011 | 06:48 PM
  #1803
BMenard17's Avatar
Thanks guys, very helpful stuff here.... so easy even a caveman can do it!!
BMenard17 is offline
Old 07-12-2011 | 08:03 PM
  #1804
Jeauxkor's Avatar
My front bearing was pretty wet too. I wonder if thats what led to the demise of my motor? Anyone know where i can get a p/s and ceramic front bearing for my GX-II? Nitro north wont respond to my e mails.
Jeauxkor is offline
Old 07-12-2011 | 08:15 PM
  #1805
Suspended
its possible, with a leaky front bearing it will make you tune differnt thinking the tune is not right. it will make the engine sound blubbery makeing you tune it leaner and leaner. moto at nitro north must be out of town, he normally responds really quick! i dont reccomend a ceramic bearing for the front, they dont like dirt and dont last as long, just a stock bearing with both inner and outer seals will fix ya up. now the rear inner bearing being ceramic will give you a little more horse power and smoother throttle, (very hard to notice) but will. smoother=better run time.(30 seconds or so). give moto a day or 2, he will respond.
inferno13 is offline
Old 07-12-2011 | 08:34 PM
  #1806
+1 on the give him a day. I've alway's gotten a response back and very quick shipping. Maybe he's celebrating a big race win.
buglite62 is offline
Old 07-12-2011 | 08:52 PM
  #1807
Jeauxkor's Avatar
He responded. And you are correct. He had been busy with an event. All will be taken care of soon and i will begin round two with my GX-II.
Jeauxkor is offline
Old 07-13-2011 | 12:33 AM
  #1808
grizz1's Avatar
The front bearings do leak from time to time, but they also get blamed for a lot of bad running that actually comes down to incorrect tuning
If the bearing is seeping a little after a run (especially if you are running rich) it's probably ok. If the front of the motor is covered in oil and dirt as well as the underside, then you may have a leak.
A leaking front bearing won't make your engine sound blubbery, it will make it sound really lean - because it is. Air leaking in through the bearing makes your mixture lean, and your motor run hot.
Normally this is signified by a fast pulsing, high revving combination when you come to an idle (machine gunning it's called).
Rule of thumb would be:
If the motor is at idle and then starts to pulse up in revs quite high and erratic - you have an air leak (or you are way too lean somewhere).
If the motor comes in reving high and then drops suddenly after 10 seconds or so, you are too rich on the bottom end and your idle gap is too wide.
This normally results in your top end being very lean too (in order for the motor to run like this). The motor will run ok, but at WOT you will be too lean, resulting in blown plugs and maybe engine damage if you are running really hard.
grizz1 is offline
Old 07-13-2011 | 01:05 AM
  #1809
Flanno's Avatar
Flanno is offline
Old 07-13-2011 | 03:11 AM
  #1810
Jeauxkor's Avatar
Yep Grizz, your last statement pretty much describes what was happening to mine.
Jeauxkor is offline
Old 07-13-2011 | 06:19 AM
  #1811
jdg_rit's Avatar
Round #1 of Northeast Pro Series was run on 6/24. CRC built a new track for the Pro Series race. Tires of choice for the new track were the VP Pro Turbo Trax in Ultra Flexx compound using VP Pro wheels. The ZX-1.5R buggy felt great. The track is very technical and set-up is critical. After a few practice rounds I was getting more familiar with the layout and a few adjustments to the car made it perfect.
Round #1 I qualified 3rd overall. Round #2 I qualified #2. Round #3 I qualified #1 just missing the elusive 10 lap run. Round #4 I qualified #2 to lock up the TQ. The car was getting faster every run. I stayed with the Turbo Trax for the main.
During the warm up for the Main my car had an issue with the rear drive shaft coming loose and lost the support bearing. My pit guy and I worked hard to get it back together, but I started 3 laps down. We got it fixed and went back out. I worked my way nack up tp 6th, when I got clipped by another driver and landed funny on a landing jump. I snapped my front arm. A disappointing finish, but I was happy with the TQ.
The GO GX-5R Engine had tons of power with no issues. Running temps were low all weekend using S&W Fuel Trophy Blend 30%.
It was a great day for Caster Racing USA, GO Engines USA, S&W Fuels, and VP Pro tires.
Next race is in Rome, NY on 7/21.
jdg_rit is offline
Old 07-14-2011 | 03:28 PM
  #1812
deadmancourt's Avatar
sorry guys,i havent been able to post on here in a while... i just got a new job and am still in the process of moving at the moment..and both my computers took a crap!....i havent stopped my racing schedule, but have just not had the time to get on here and post up results and whatnot...or even help with anyones problems....but i have not forgotten about the GO FAMILY....talk to you guys soon
deadmancourt is offline
Old 07-14-2011 | 06:10 PM
  #1813
Jeauxkor's Avatar
What size front bearing for the GX-II? Is the stock bearing as good as the many after market brands?
Jeauxkor is offline
Old 07-14-2011 | 06:14 PM
  #1814
Suspended
http://nitro-north.com/frontbearing.html, just as good as other brands, just leave both front and rear seal on.
Old 07-14-2011 | 06:15 PM
  #1815
bigmatt's Avatar
don't know the size,do know the stock is just as good if not better then most.
bigmatt is offline
