Go Engine USA 2011 Thread
#1819
The stock front bearings are SKF, so no need to upgrade.
Like Matt suggests, run seals on both sides if you can. They come from the factory only sealed on one side these days, but it's easy to slip a spare seal in before you install.
That's a nice stable of race cars you have there inferno
#1820
Front is 7 x 19 x 6. Main is 14 x 25.4 x 6
Looking GOOD !!!
Looking GOOD !!!
#1825
hi monty, whose rex welch? anyway, question on GXII. Practice run and engine runs good. Idles great. I wanted to put some more low end grunt. Using Losi 2 alum/green 2 comp./gold. So i adjust 1 hour on low speed needle, blip blip blip blip / WOT and engine dies... returning back to its setting 1 hour back, engine runs good. Why is that so?
Thanks,
Thanks,
#1826
Thanks,
Thanks,
I suspect the way you have your engine tuned, you are going too far in on the bottom end. Do you lean or richen the bottom end when it dies ?
The GXII (like the GX and it's predecessors) has a long tapered low speed needle. This tapered needle sits well inside the receiver jet. If you set it too far in, you can actually completely block off the receiver jet with the taper.
Craig (curacing2) our GO team driver here posted some info on this a few pages back somewhere too.
Race tune generally on the GXII will see the bottom needle screw flush or maybe 1/2 a turn in from flush with the cap. High speed needle the same.
I suggest you go back to flush on both needles, set the idle gap to .7 mm max, and tune from there.
The GXII has mega bottom end, so you shouldn't have a problem getting the performance you want.
#1828
thanks shane, rider.. yeah i've seen 22racer here. Yes shane i have leaned the bottom, engine dies; richen up and it engine ok. From what you've describe. Will restore back to flush settings and start from there, and also the .7mm idle gap.
many thanks....
many thanks....
#1829
Check out our tuning guide and other info here -
http://go-racing.vpweb.co.nz/Tech-Tips.html
1Likes
