Like Tree1Likes
Go Engine USA 2011 Thread
Old 07-22-2012 | 10:32 AM
  #2536
bigjayjay1's Avatar
I remember someone saying that the go rod fitted the OS this was a long time ago thou
bigjayjay1 is offline
Old 07-22-2012 | 11:08 AM
  #2537
Suspended
I have run a Go rod in a v-spec and ran perferct. Also have run one in a nova n21r and a reedy. All ran good with no problems
alwayswin is offline
Old 07-22-2012 | 01:24 PM
  #2538
Default Runtime
I took a little time to swap restrictors and test for runtime, and was really surprised. I've run this motor every weekend since about the end of November or mid December so it's totally worn in. I'm running a GXII/2072/2needle carb in a Losi buggy with Losi clutch, 2 alum/green and 2 composite/black, steel flywheel, on a really large, fast track. I've heard some people talk about going to a larger restrictor and getting better runtimes on a big track, so I pulled the 6.5 and dropped in the 8mm venturi, switched from Byrons to Nitrotane, and was able to baaaaarely make the 10min pit stop for the first time. Previously I was dry at about 9minutes, maybe 845. I did not hesitate to push the loud button down the back straight or whenever I needed, no nursing it around the track to mess with my test, just going for broke. The tires and clutch were a bit worn and I could have leaned it out some more on top, so I'm optimistic I could make it a reliable 1-pit plan. More time will tell, but I'm really glad I took the time to tinker with this, it's like getting a new motor without spending a dime.
Nitrotane has a reputation for longer runtimes so I'm not sure which made the bigger difference, but man that thing is an absolute missile with the 8mm restrictor. It was plenty fast with the 6.5, but the 8mm required a whole different throttle position so I didn't overshoot jumps, and I chewed up a lot of traffic on the back straight. Won the club race, which is always cool. Next week is the final round of the KBRL series, we'll see how it finishes.
AZTman is offline
Old 07-22-2012 | 10:59 PM
  #2539
deadmancourt's Avatar
hey guys...i finally broke a mounting tab on my gxii that has ALOT of miles on her...i just ordered a new p/s/r kit for it, a couple of days ago and then this happens...oh well...i have an old gx5r case..i should be able to just swap cases right?...im pretty sure i can, but i thought i would ask to get a for sure answer.
deadmancourt is offline
Old 07-22-2012 | 11:04 PM
  #2540
Ruune's Avatar
Yeah bro... It'll work. I still have a gx5r that I put the GXII PSR in.
Ruune is offline
Old 07-29-2012 | 11:08 AM
  #2541
KBRL series finals were fantastic. Finished 4th in truck with the GX5r I bought in Feb 2011, ended up 3rd in points overall. Finished 1st in open buggy with the GXII I've had since about December 2011, ended up 2nd in points overall.
I stripped out a clutch shoe screw on the steel flywheel and had to run an aluminum one for the buggy main, so I didn't shoot for the 10minute pit. That flywheel makes a huge difference, going from about 10minutes runtime last week to about 8min30. The weather was also very different so it's not exactly apples to apples. It was crazy fast all day, needing only a small change on the LSN before the main.
AZTman is offline
Old 07-30-2012 | 08:53 PM
  #2542
hey guys...just a heads up..im selling my backup engine. I bought a brand new P/S/R, crank, case, bearings and backplate. i put a used gxii, 2 needle carb that is in great condition on it and used head and head button, that is not bent nor all gouged or scratched up.NEVER BEEN FIRED! I recently picked up a new motor sponsor and will no longer need this motor. pm me for pic, im letting it GO for cheap i only posted in here cause i would like it to GO to a real GO enthusiast i just really need the money..otherwise i would keep her
Old 07-30-2012 | 09:08 PM
  #2543
22Racer's Avatar
Gonna run the Arrow? I am testing one right now, then testing some mods on it.
Rex
22Racer is offline
Old 07-30-2012 | 10:02 PM
  #2544
Rex
No, i was going to. But im gonna run picco motors
Old 07-31-2012 | 02:31 PM
  #2545
I noticed Amain added the G5T to stock. Does it really live up to the old GX5R?
thanks guys
AZTman is offline
Old 07-31-2012 | 07:21 PM
  #2546
monteman1970's Avatar
2 go gx5r parts motors if anyone is interested
http://www.rctech.net/forum/r-c-item...r-engines.html
monteman1970 is offline
Old 07-31-2012 | 07:51 PM
  #2547
thanks guys
In a word YES.
I ran mine last weekend for the first time.
It has a heaps of punch and doesn`t lack anything on the top either.
This is an excellent motor for the $$.
Run in was easy, the pinch is a lot less than the old GX5R, I got a race tune on after 8 tanks.
In fact I like it better than my GXII`s.
ben1970 is offline
Old 08-02-2012 | 12:00 AM
  #2548
grizz1's Avatar
Hey Ben, glad your liking that new G5T
The G5T is a wicked motor all around for the price. They also look really swift with the GXII head and finned button on the grey crankcase .
If you want one of these little honeys you will need to be quick though.
As of a couple of weeks ago GO are not making them anymore. Management changes at GO have seen the G5T dropped from the line up.
I think A-Main and us got the last batch. Wish I had ordered more now
Worth grabbing one and keeping it as a spare or back up. They are totally competitive. Like Ben said, lots of punch and very smooth. Plus they take all the GX model spares - bearings, 21-0600 rod, carb, etc etc.
grizz1 is offline
Old 08-02-2012 | 02:21 PM
  #2549
MassiveMods's Avatar
there is a 0.5 mm difference in the sleeve chamber between the GX 5 R and the GXII case. your old PRS set from the 5R will sit lower into the case on a GXII so if you put it in and wonder why its so tight or the pistom hits the head button ,, thats why . just make sure its shimmed correctly and you may be fine.
my advise is to get an original 5R case
cheers M
MassiveMods is offline
Old 08-22-2012 | 11:48 PM
  #2550
Titian2010's Avatar
Hello hello hello any one here lol jk. Hope someone can help. I'm in a bit of a crunch here and can't pin point the issue. Ok here is the Quick run down. new out of the box Go with Go pipe broke in with idling, figure eights then slow runs half throttle around the track keeping temps at 220 with quick full throttle down the straight. That's my break in method. 1/2 gal felt good, 2/3 gal motor was awesome even ran rich with tons of smoke and now at 1 gal I get flame outs. I know what to look for when flame outs happen. Plugs, leaks, sucked dirt ect... All is well. Things that changed from 2/3 gal from 1 gal are new fresh buggy(mugen us spec), Go pipe got sold during time off to a friend, went back to stock settings and plug brand being changed. Broke it in with 97t. I run os motors so when that 97t died I put a p3 which was in my stock but it didn't last at all and not sure why. Went back to 97t and flame outs are less but still flaming. I used the stock setting from the info given a pages back because I couldn't figure why it was flamming with the p3. I have the 2 needle carb so I did flush and flush and tune from there. Bottom as good power but you can hear the clearing out while throttling with tons of smoke. If I go any leaner on the bottom then it bogs. I spend last practice tuning it myself then asking for help from pros. I feel top is great, bottom has good power but motor has tons of smoke as if I'm breaking it in. And for the flame outs, they just happen. One min it can be upside down and still run, the nxt it only takes a few secs then it's out. Even with fuel. I can go a few laps with no issues then come in to pit and it dies when refueling even with fuel left. From new to 2/3 gallons the motor never never never flammed not even while on my lid for a few secs. Where should I start or what should I do? I loved it new but now I'm too scared to even club race it let alone dare use it for a trophy race.
Titian2010 is offline
