Like Tree1Likes
Go Engine USA 2011 Thread
Old 09-14-2012 | 02:14 AM
  #2611
grizz1's Avatar
Originally Posted by Rsickles
That likely just has to do with distribution rights. A Main Hobbies is a GO distributor, so they can't sell to Europe and infringe upon the European distributors' market, by undercutting their prices because of a favorable exchange rate, etc.
100% correct.
The G5T was only a limited edition motor. It is no longer being made.
A-Main and us down here in NZ got the last order out of the factory - we only have 18 units left ourselves.
Great little motor for the price. You guys have summed it up pretty well as far as the bottom end and top end.
It's not the GXII crank minus the epoxy as far as I know.
At that price you could afford to throw a GXII crank and 3 needle on one.
By the way, the G5T with the grey crankcase looks very cool with the GXII head and finned button fitted too - very exotic looking.
GO have something new coming out very soon to replace the G5T. Along the same lines - affordable entry level, but still competitive. 4 Port (4 + 2) sleeve I am told. Should be out in the next month or so.
grizz1 is offline
Old 09-14-2012 | 02:06 PM
  #2612
Flanno's Avatar
Hi Grizz
I knew you'd be onto it
Flanno is offline
Old 09-14-2012 | 04:32 PM
  #2613
grizz1's Avatar
Originally Posted by Flanno
Hi Grizz
Hey Flanno - hows it going bro ?
I've not been on here much lately, so thought I would drop in and catch up with the gossip.
Will pop up from time to time when I hear any news from the factory that will be of interest to the GO faithful on here .
The GXII's are still kicking arse around the traps over here. Smooth and reliable as always
grizz1 is offline
Old 09-14-2012 | 09:08 PM
  #2614
Flanno's Avatar
I'm still here Bud.
Still having fun.
Have had some bad luck of late,
but still giving it my best effort,
looking forward to NSW Titles in 2 weeks.
Flanno is offline
Old 09-15-2012 | 08:58 AM
  #2615
hi all, how mm of shims should i use for the GO GXII? im running 25% nitro and engine fully broken in.
rossham46 is offline
Old 09-15-2012 | 01:48 PM
  #2616
Flanno's Avatar
They still run great with the stock shimming on 25%
But if you want to take out a shim....
Take out the very thinnest one (brass 0.10)
Flanno is offline
Old 09-15-2012 | 04:05 PM
  #2617
Mine stock has 2 shims. 0.3 and 0.2mm.
Old 09-16-2012 | 02:01 AM
  #2618
Flanno's Avatar
alloy 0.3 and brass 0.2 ?
total of 0.5
did it come with a brass 0.1 in the box ?
replace the 0.2 with a 0.1 for a total of 0.4
Flanno is offline
Old 09-18-2012 | 07:58 AM
  #2619
d45
total of 0.5
Use a good quality glow plug, I was running a .4 shimming and it seemed to knock the coils out of the glow plug. I suggest a werks #6 ... OS p3 &p4's don't last more than half gallon. These are just my findings.
d45 is offline
Old 09-18-2012 | 01:01 PM
  #2620
Flanno's Avatar
Quite possibly not FULLY run in yet...
or
It's not plug quallity thats the issue, but rather the fact that a Werks 6 is colder than OS P3 and P4s
The Hotter the heat range of a plug the wire element is thinner, and cooler it is thicker, therefore stronger.
I use O Donnell plugs with no issues Medium and Cold T97 and T99s
Hope that helps
Flanno is offline
Old 09-18-2012 | 02:36 PM
  #2621
curacing2's Avatar
I would stick with the std 2 shims while the motor has lots of compression and run the OD 97T plug if you can, the GOs love them aye Flanno
curacing2 is offline
Old 09-18-2012 | 10:59 PM
  #2622
Flanno's Avatar
see post 2616 above.. first sentence.
True that Craige
Flanno is offline
Old 09-20-2012 | 09:08 AM
  #2623
McD44's Avatar
Is there a place to source GX-7R cooling heads in the US? I'm having a problem with the fins breaking at an alarming rate.
McD44 is offline
Old 09-20-2012 | 09:14 AM
  #2624
Suspended
i have found a few on ebay for 5 bucks brand new.
alwayswin is offline
Old 09-20-2012 | 09:27 AM
  #2625
McD44's Avatar
Thanks! There are a couple 5R cooling heads on there now are they the same? Will any other manufacturers' cooling heads fit?
McD44 is offline
