Like Tree1Likes
Go Engine USA 2011 Thread
Old 04-15-2011 | 11:17 AM
  #1111
teeforb's Avatar
Originally Posted by inferno13
the GO GX7R is the best for a buggy, sent you pm.
what about truggy?
teeforb is offline
Old 04-15-2011 | 11:25 AM
  #1112
Suspended
Originally Posted by teeforb
what about truggy?
GX5R or GXII HO, for truggy, awsome engines with a 2072 pipe!, the GX5R does well in buggy as well if you have a little finger control.
inferno13 is offline
Old 04-15-2011 | 11:39 AM
  #1113
teeforb's Avatar
jus curious, why not the 7r for truggy?
teeforb is offline
Old 04-15-2011 | 11:43 AM
  #1114
Suspended
has alittle less bottom end in truggy, buggy is a little lighter and gives it better low end and tons of top end as well, the GX5R has tons of low end for those heavier truggies, MOTO at NITRO NORTH is a super guy to deal with, just received stuff today from him!
Old 04-15-2011 | 11:51 AM
  #1115
teeforb's Avatar
what's the difference between the HO 5r and older 5r? is the older 5R just as good?
teeforb is offline
Old 04-15-2011 | 11:54 AM
  #1116
Suspended
i havent ran the GXII HO, just the GX5r, im very happy with it! someone might be able to awnser that for you that has ran it. I heard it has the bottom end grunt like the GX5R and the top end likr the GX7R, kinda the best of both worlds.
Old 04-15-2011 | 12:19 PM
  #1117
deadmancourt's Avatar
Difference in power is the new motor is smoother bottom and whloe powerband...and has a ton of top....almost like a 7port.......difference in looks, the new motor has a lightened head with finned head button, factory porting on the sleeve, factory epoxy filled and ramped crank and a harder material piston
deadmancourt is offline
Old 04-15-2011 | 12:34 PM
  #1118
teeforb's Avatar
Is there a combo with the new motor if so, how much?
teeforb is offline
Old 04-15-2011 | 12:45 PM
  #1119
Nope
Old 04-15-2011 | 01:34 PM
  #1120
bigmatt's Avatar
I'm going to need some help with the new go-II ho. I cleaned it out reassembled/ re-oiled/installed new glow plug/preheated/engine is froze!!!!!!!!!!!!!!!!!!!!!! Tried to turn over thought it was going to fire right up[sounded like it] I used my snap-on 3/8th drive breaker bar with 8mm socket on it to get it to go around. Thought for sure I lost a c-clip. Taken engine apart nothing,no shavings no c-clip off piston not scored/sleeve great no lost glow plug tip. Only thing I can think of is the front bearing seems notchy in 1 spot but I don't think that would cause engine to lock in place tdc. Or is it that the engine is just that tight? any one have any trouble? I am going to put it all back together and try again.
bigmatt is offline
Old 04-15-2011 | 02:01 PM
  #1121
Suspended
my GX5R did that, just have to pre-heat to higher temp. i even had to put a
6S lipo in my starter box to get it to turn over!
Old 04-15-2011 | 02:11 PM
  #1122
Your not getting it hot enough before starting it....I had that problem once with the gx5r and never had it again....make sure its at least 200f....I didn't have any issues with the gxii pston and sleeve that I broke in yesterday....just made sure it was over 200f everytime it was fired up
Old 04-15-2011 | 03:17 PM
  #1123
motomatt's Avatar
Greatest thing for nitro engines since.........................well since nitro engines.
I know a guy that sells them.
It's been said he's a little goofy though.
motomatt is offline
Old 04-15-2011 | 04:34 PM
  #1124
22Racer's Avatar
I love my Competition heat but it doesn't get a motor hot enough for break in in my opinion. On a tight motor I get it up to 240 degrees or so at the head and about 180 at the block witha heat gun.
I am getting a GxII from Trey to try out.
Rex
22Racer is offline
Old 04-15-2011 | 05:08 PM
  #1125
bigmatt's Avatar
Rex
that was it,heated that baby up to 240 then it fired up. Was able to get 1 tank through. took back out resealed. I had a bad air leak. so I will try again 2marrow.I will say this is one very touchy carb. Rex if you could please pm me your addy so I can send you the money I owe you. I do want to apologize I have completely forgotten about it until I saw your post.
bigmatt is offline
