Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-03-2017 | 05:19 PM
  #9316
Hi guys I used to run the plus 21 4 in 2009 with my Losi 2.0 buggy and it screamed. I'm getting back into it again and buying the Losi 4.0 and I'm looking at the Keep Off 21-4 and not sure which pipe to get either the 9901 or 9886 with the 41021 manifold. I want lots of bottom end for clearing jumps but I want top end for long straight aways.
A friend keeps telling me to get the SH PT-2016 xbg, but I know nothing about the SH motors and I remember how great that Novarossi engine ran and I'm reluctant to buy something I don't know anything about even though it's cheaper.
Rico54 is offline
Old 01-03-2017 | 05:27 PM
  #9317
Maximo's Avatar
A 41021 will give you the mildest power , a 41033 will do better as would a 41001
Maximo is offline
Old 01-03-2017 | 05:52 PM
  #9318
Rampokker's Avatar
Maximo, how would the werks 2058 compare to the mentioned nova combos? I've got the 2058 on my keep off 21-4 and really like it!
Rampokker is offline
Old 01-03-2017 | 06:45 PM
  #9319
And which pipe for the Losi 4.0 buggy. 9901 or 9886?
Also is a 3 needle carb harder to tune than a 2 needle carb.
And what's the difference between steel and ceramic bearings? Which is better for longevity?
Rico54 is offline
Old 01-03-2017 | 07:33 PM
  #9320
Guys got a question on pipes? I run a mito 4 and was wondering what is the difference between and ultimate pipe and the novarossi based pipes? Is the ultimate 2123 a mimic of a nova pipe? Has anybody tried an ultimate pipe on a mito 4?
Ofna2005 is offline
Old 01-03-2017 | 10:36 PM
  #9321
cczjordan's Avatar
I run keep off 4 with 41021/9886 and it has all the power it needed especially short run up to jump, excellent top end with 6.5mm venturi.
4bttwc 41033/2096 smooth n better top end. As for 9901/41021 combo is very flat on top imho.
Ceramics will give better response n longevity, main bearing only.
3 needles carb will tune the same as the 2 needles carb, just dont tune the mid range if u dont understand how it works. I dont feel/find any difference with both carbs
cczjordan is offline
Old 01-04-2017 | 01:06 AM
  #9322
dan_vector's Avatar
In buggy I run the Keepoff 4 with the 9901/41021 manifold. It's a great engine and I agree with you stick to Novarossi! The 9886 pipe is not allowed in my region as it's a 2 chamber pipe. The 9901/41021 combo is what the NR team drivers such as Adam Drake run in buggy.
dan_vector is offline
Old 01-06-2017 | 10:35 AM
  #9323
So nobody knew the comparison between the ultimate pipes and the novarossi pipes?
Ofna2005 is offline
Old 01-06-2017 | 12:08 PM
  #9324
Never even heard of it here.
Chris Reilly is offline
Old 01-08-2017 | 07:33 PM
  #9325
cczjordan's Avatar
Not sure but novarossi based engines wont have much difference
Old 01-09-2017 | 05:32 AM
  #9326
Default Answer by Novarossi
Originally Posted by houston
the newest batch i got not long ago are new redesigned more like the old R4 rods of 2005 or so ... R7/16 it seems as though the aluminum is harder in these newer rods ... not sure yet ... havent had one failures from any customers with em ... soo i am thinking they may be good
the rod is literally the weak link in these little 2 strokers ..... all manufacturers are susceptible ..... too heavy they dont run right ... too light and they are weak and both effect the reciprocating mass ..... whatcha gonna do
Hy, This is the response of NOVAROSSI Italy with regard to the question on the last connecting rod commercially available.
aulin79 is offline
Old 01-09-2017 | 01:02 PM
  #9327
can you translate this reply to english please?
would like to see what novarossi have to say
as they did not give a reason why my rod failed.
rick oxley is offline
Old 01-09-2017 | 03:15 PM
  #9328
I don't know why they don't answer you..I wrote Nova and my question related only to know the latest rod produced. Sorry, I don't help you.
aulin79 is offline
Old 01-09-2017 | 04:19 PM
  #9329
fizzy's Avatar
Aulin79 pretty much explained it, he messaged Novarossi just asking about what the current batch of r7 conrod numbers are and they replied with a number that's pretty much it
fizzy is offline
Old 01-10-2017 | 01:17 PM
  #9330
thanks, got it now i was thinking the writeing in blue was reply from novarossi
